Directly log into administrator account
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Is there any way to automatically log into the administrator account on windows xp? My instructor for computer tech is fixing a computer for someone, he had to uninstall SP3 due to compatibility issues and it seems the generic USB drivers went out the window with it. USB drives and keyboards work in the bios and on boot, but as soon as windows loads to the logon screen, it won't allow you to type in a password, and the USB mouse doesn't work. Safe mode doesn't work either.
    This is a dell dimension D5150, no PS2 ports for some reason.
  • NxB
    • Feb 2009
    • 1595
    Re: Directly log into administrator account
    It would all require the keyboard. Ps2 to test?
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      restore cd time! there is a torrent somewhere that is dell xp pro install with sp3 slipstreamed. its works like a normal xp install cd except no license code needed (it scans the bios). it has a restore option, but i never use it, as i would rather set it up the normal way.
      i've used it on my gx260 dual-boot project... it works!
      am i allowed to post a link? since it is dell-only, no licence codes are broken.
      sigpic
      (Insert witty quote here)
      • kaniki
        • 514
        first, im not sure what those compatibility problems were, but i do know that most things that will work on XP have updated drivers so they will work with XP SP3. Microsoft did rework the way that some things work with SP3 and some files were changed from SP2 to SP3 to what the file is that is used. I have seen this on network adapter cards.. Dlink if i remember right but could be wrong. but simply went to the manufacturer's web site and got the new drivers and all was fine again.
        Also, you said that the USB stopped working. Did you try "last known good configuration" during the bootup section (Safe mode area) or Safe mode itself to see if you could get the USB to work in either of those?
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Tried that, still doesn't work.
          • seanc
            • Nov 2008
            • 1319
            How long have you left it for after boot? Have you tried unplugging and re-plugging everything? Sometimes Windows takes ages to install drivers on boot, this may be one.
            Try rolling back the registry that System Restore has made (via the Recovery Console) - you can find these backups in System Volume Information. Don't restore the registry from C:\Windows\repair - these are rarely updated and will not work correctly.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              my guess would be malware/virus... disable usb, cripple a machine. find a free av cd and test it...
              sigpic
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                We left it sit for a very long time after boot. Just sits there. If you unplug and replug in the keyboard/mouse the lights flash for a second on the keyboard, then do nothing.
                We used a dell/logitec optical mouse at first, it didn't even light up. The second mouse we tried is a lenovo one, it lights up but still dosen't work.
                We ran a bartpe disk on it, everything works that way. May be malware, but I doubt it for it worked before until he uninstalled sp3. We ran a malware scan immediatly after we saw limewire with the latest AVG, malwarebytes, then superantispyware. Picked up a few odds and ends, but nothing big.
                • seanc
                  • Nov 2008
                  • 1319
                  Is it XP Pro or XP Home?
                  You could enable Remote Desktop in the registry and try and log in over the LAN.
                  What was the reason for uninstalling SP3?
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    There was apparently some computability problems that were causing BSOD's. Don't ask me, it was my instructor doing all that.
                    Remote desk top idea might work, will have to tell him that monday.
                    • kaniki
                      • 514
                      Umm.. how? if the mouse does not work and the keyboard does not work, then how do you enable it??
                      I would love to help out more, but i am kinda at a loss, you can do quit a bit with just the mouse or just the keyboard, but with neither working..
                      I have never tried this so do not know if it will work, but maybe this might. If you get a copy of hiren's boot cd. they have a portable version of XP on it that will load right off of the CD. It does not change anything on the computer, but just loads all info in ram so no changes are made. maybe if you loaded that on the system, you could try to do a system restore, and since you are not loading the version that is installed on the PC, the mouse and keyboard should work. but like i said, never tried it before so can not guarantee anything.
                      • seanc
                        • Nov 2008
                        • 1319
                        You hook the drive up to another PC, load the relevant registry hive, modify it and save it.
                        • kaniki
                          • 514
                          well yea, that would work, but my point is just that if you are going to go through all the work of hooking it up to another pc, and there are known problems as of right now, then you mine as well just back up all the info on it and reinstall everything from scratch. after all, it does not take that long to just reinstall the computer, nor do all the basic updates. not to mention that most people, even computer people do not know how to do that. There are some good ones but i never take into consideration that a person will know how to do it because more times then not, they will not have any idea on how to do it.
                          another thing that slipped my mind.. try doing a repair install from the CD.. that might fix it too and since that is loaded from a repair partition or CD, then you should have no problems with the mouse and keyboard working.
                          • seanc
                            • Nov 2008
                            • 1319
                            You've a fair point, I'm making a huge assumption there. First newb mistake was uninstalling SP3 :P
                            Also, I agree that re-installing Windows is not that hard, but the end user won't understand why their shortcut isn't in the right place or may not have their original discs (or (legal) licences), if you can leave as much as possible alone, the better.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3113
                              The person's computer is some senior girl in high school at my instructor's school, so reinstalling windows will be more of a last resort, as she won't understand why itunes won't work, etc....
                              Well, kind of sums him up in one sentence....(hope he dosen't read this forum )
                              Though he's one of the people that's a "i'm A+ certified, opening a power supply is illegal and you will instantly die"...
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                you mean the kind that pushes powmax? the ones that say "i know a deal when i see one!"
                                its like the dweebs at school that think that having a newer computer= i'm a computer expert!
                                like saying that owning a ferrari equates being a good driver; the number of celebs totaling them disproves it (like the guy who owned one for a week, then split it in 2 when he hit a tree, killing him and his date)
                                sigpic
                                • seanc
                                  • Nov 2008
                                  • 1319
                                  Ah A+ certified, that's all good but it means nothing if he has no experience dealing with this specific issue.
                                  For all intents and purposes I'm Cisco certified, but I've not done any router configurations for so long I'm really out of touch with the CLI.
                                  • madmax_2069
                                    • Nov 2008
                                    • 27
                                    That would be the thing to try, it wouldent hurt. Rolling back doesnt always work though, but if it does it would solve the issue (if its a software issue). But from it BSOD all the time it could be a software issue or a hardware issue.
                                    • NxB
                                      • Feb 2009
                                      • 1595
                                      Most people leave remote registry on. You wouldn't even have to pull out the drive.
                                      Clever on the remote desktop!
                                      How many hours have been spent on this PC? Dude just has to cut his losses. He should have looked at what was causing the BSOD before uninstalling SP3.
                                      He has to reinstall it anyway later on.
                                      • seanc
                                        • Nov 2008
                                        • 1319
                                        The problem with remote registry may be authenticating yourself, which is why I suggested pulling the drive.
                                        • tobeend
                                          Bypass mdm macbook m2 ventura
                                          by tobeend
                                          1. RESET MACOS WITH IPSW
                                          a. Power off MacBook, press and hold the power button to enter Recovery
                                          b. Open Disk Utility, remove Macintosh HD
                                          c. Reboot, connect to the network to Activate Mac.
                                          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                          e. Release the other keys, but keep holding the Power key for another 10 seconds
                                          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                          05-26-2023, 07:18 AM
                                        • Admin
                                          Forum Rules - Updated!
                                          by Admin
                                          FORUM RULES *ALL NEW MEMBERS, PLEASE READ! UPDATED!*
                                          First and foremost, welcome to the Badcaps Part Search Engine & Electronics Repair Forums!
                                          IMPORTANT NOTICE ON FILE ATTACHMENTS
                                          As with any forum, we are susceptible to our users being targeted with malicious attachments in posts. We do our best to remove anything suspicious but need our users to be cautious. If you are unsure about an attachments legitimacy please ask directly under the post and wait for a reply by an Admin or Moderator. NEVER...
                                          12-04-2023, 08:53 AM
                                        • PITERPENY
                                          iCloud macbook account M1
                                          by PITERPENY
                                          I've been wondering for a few days now. Where is the account information stored on a MacBook with an M processor?! Previously, this information was written to the T1, then to the T2. Serial numbers in the EFI chip. I'd like to know how this is implemented on M processors. Is the account on the SSD or on the chips that are on the processor itself?!
                                          09-29-2024, 07:45 AM
                                        • alltvrepairs
                                          QE55Q0TAT BN94-15361X copy account data to hew main board
                                          by alltvrepairs
                                          Hi
                                          Got a new board to repair dead set.
                                          ​​​​customer had some paid accounts that wants to reuse from old board as he has no more access to the original email account for some iptv and other services like Disney etc. Are these stored in spi flash?
                                          I guess they are in a Samsung account storage area.
                                          Tks
                                          02-22-2024, 11:31 AM
                                        • webhost
                                          Google account asus chrombook C214MA-BU0769
                                          by webhost
                                          Hello Guys
                                          Can You help me to remove google account on this bios
                                          Asus Chromebook
                                          Motherboard : C21MA MAIN BOARD R2.4 PCB MADE IN CHINA
                                          model : C214MA-BU0769
                                          SN : NBNXCV03S54545A
                                          CN : LZC6
                                          MFD: 2022-11
                                          thank You in advance...
                                          04-08-2025, 03:22 AM
