Yellow tint after caps replacement
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Today I replaced the caps of old pcb with pentium4. Now the internal video outputs yellow, where should be white. I had a hard time replacing the caps, it was extremely difficult to unsolder them. I have had no issues with other boards, but this particular was pain in the... I damaged something or what? The PC otherwise works just fine. Its not the VGA cable. Usually it's much easier to replace the caps on mobo. Have experience with other mobos. Even crancked on max temp I was barely able to unsolder the caps. I wasted more than hour on 7 caps. The solder just refused to melt.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Yellow tint after caps replacement
    My guess is you probably created a solder bridge and shorted something or inadvertently knocked a component loose. I'd check it over very closely, even use a magnifier if possible....it could be something VERY tiny. THis has happened to me before...not the 'yellow' symptom, but other symptoms it created. Some of the horrid RoHS solder during the RoHS transition years was extremely difficult to work with.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      I replaced 1 cap near the chipset, that is also the integrated video. Even with 50W soldering iron, crancked on MAX temperature(I almost never go to the max, even when reworking motherboards) it was very difficult to unsolder, even considering the fact that I tried to apply a low temp solder and melt the joint that way. The tip just sticks to the joint, but I cant unsolder the cap. The thermal compound under the chipset was just a thin layer of yellowish residue.
      I looked at the mobo, but saw no apparent solder bridges or shorts. It took me more than hour of cursing to remove and replace just 7 caps.
      Otherwise this is still somewhat capable Pentium IV 3Ghz 3GB DDR2 computer system.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        Maybe something got fudged up between the layers of the board. What happens if you add an external GPU (AGP or PCIe, not sure which it is)?
        Team : 49813
        Join in!!
        Team Stats
        • televizora
          ghettomodmaster
          • Nov 2016
          • 957
          Everything is just fine with external GPU. And Windows7 otherwise works just fine. The problem is not due incompetence, it was just waay to difficult to remove and replace the caps. It's a PCIE board with DDR2 RAM. After I spent an hour with this board, I thought that It will not boot ever again. It booted and works, but with yellow tint on the internal video. With PCIE video card everything is ok.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            You've lost your blue drive on your onboard GPU, which is a classic solder bridge, trace damage, or component knocked off. To create a white raster, it takes an equal drive of red, green, and blue. If you remove the blue, what's supposed to be white will be yellow.
            Team : 49813
            Join in!!
            Team Stats
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              Yep, I know this. But I was no near the integrated GPU itself, but near the power supply of the chipset/IGP/. If it was a power supply failure, I think that much more would be wrong, than a yellow tint. I will recheck the board.
              • televizora
                ghettomodmaster
                • Nov 2016
                • 957
                I found no solder bridges, all caps are soldered with right polarity, every joint seems ok. I lost more time than I can spend on this machine, so I just put a dedicated video card on the PCI-E slot and closed the case.
                  master hoarder
                  • May 2008
                  • 12175
                  ^This.
                  Follow RGB lines from VGA connector back to Northbridge. Somewhere on the way, they should be going through ferrite beads and may also have a few low-value ceramic bypass caps to ground. Check that ferrite beads are not broken off or damage and also check that ceramic caps are not shorted to ground.
                  I've had to do this kind of repair on many discreet GPUs that I got from eBay. Usually the cause is improper handling, but could also be a faulty solder joint from the factory that just appeared now as you flexed the board around while working on it. If this is not the case, also check the RGB pins in the VGA connector. Sometimes, they can become pushed in and short on the back of the connector.
                  • black6host
                    Replacement caps for Samson Resolv studio monitor 65A Amp board.
                    by black6host
                    Good day!
                    I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                    I'm going to replace the caps and I'll be the first...
                    02-06-2024, 08:22 PM
                  • rewease
                    Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                    by rewease
                    There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                    Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                    Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                    09-17-2023, 12:53 AM
                  • nick3092
                    Mid/late 80's Nichicon Yellow Caps
                    by nick3092
                    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                    08-28-2022, 03:56 PM
                    by momaka
                    03-12-2025, 03:42 PM
                  • crosswinds
                    Assistance with identifying replacement caps on ASUS P5VDZ-MX
                    by crosswinds
                    So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                    Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                    Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                    Its a ASUS P5VDZ-MX board.
                    I would really appreciate some assistance on what the best replacement caps would be for these:
                    Panasonic(M)...
                    04-17-2024, 04:25 PM
