What microscope to use?
  • Merchlewitz
    • May 2020
    Hi all I've been looking at the amscopes steroscope currently.
    I found this 3.25-225x trinoculur stero scope with a 150w fiber optic ring, the guy is asking $600 would this be good for starting? Should I just buy new because of warranty etc? Any input is greatly appreciated. I really want t hook up a camera eventually too.
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: What microscope to use?
    I think a lot depends on how much you plan to use it, how old your EYES are, how much you can rationalize shelling out for it, etc.
    I spend very little time working/reworking boards. So, I am willing to tolerate a bit more than someone who makes a living at it. I use a rescued ($0) B&L stereomicroscope (with illuminator). It will only magnify to ~30X (it's continuously adjustable from 7 - 30) which is more than enough for me to inspect joints, traces, etc.
    But, the binocular design gets tiring if used for long periods of time (for me) as you're hunched over it, regardless of how you position it and the "work". OTOH, a monocular view misses the depth available to a binocular view.
    If you can afford it, a Mantis may be preferable.
    Also think about how much you actually intend to use the camera capability. Its tedious for me to capture images -- but, I only do so to prove to a vendor that they screwed up some of my boards!
    • lcdcaps1
      INSKAM Microscope USB port issue
      by lcdcaps1
      Hi
      All
      Does anyone have a INSKAM 7 inch LCD digital microscope
      I have a weird issue on the one I have where the USB port does not output enough power because when I connect a USB light or the ring light the light output is always really dim
      The ring light when connected to the microscope USB port is at the lowest brightness and turning the brightness knob makes no difference
      I have tried different cables and different USB power adapters
      I have confirmed there is nothing wrong with the ring light and the other USB light by plugging them into another...
      04-18-2025, 04:16 AM
    • caspian
      Weak Vision due to Eye Strain when using Microscope
      by caspian
      Dear Forum Members,
      Microscope is required for micro-soldering and for measuring tiny components on a mainboard. I have to use microscope because my eyes are not that strong to see tiny IC pins.
      My microscope has light to improve vision. I have attached a photo of my microscope.
      Looking through a microscope gives us eye strain. After using microscope for 5 to 10 minues, my eyes get a bit weak in recognizing close objects. that means close objects look a bit blur. Then, I have to wait for 5 to 10 hours til my eyes get back to normal.
      1. Do you experience...
      08-14-2019, 02:28 AM
    • technotech
      How to disassemble Mechanic Mos-4k Pro microscope camera
      by technotech
      I recently purchased the Mechanic Mos-4k Pro microscope camera from AliExpress, and would like to verify it indeed has the Sony sensor by getting its boot log via UART.
      Unfortunately, I can't figure out how to open the camera, and do not see any exposed screws. Do you guys have any suggestions how to take it apart, non-destructively?
      05-10-2025, 02:55 PM
    • chegueva
      My Andonstar ADSM201 Microscope Review
      by chegueva
      Hi everyone. i'v started learning electronics before the corona hit so that's not very long time ago. but anyways i started with only a multi-meter then i started getting into micro-soldering and soldering in general, got myself hot air station a bench Power-supply and last but not least a microscope.
      About the microscope at first i just wanted to get those 15 usd USB digital microscopes to try but some people talked me outta of it and i decided to go for something better but not professional as i'm just starting out.
      So i had a choice between a binocular & camera , i wanted...
      08-14-2020, 11:08 AM
    • bohaboha
      ADVICE FOR BUYING A DIGITAL MICROSCOPE
      by bohaboha
      Hi I'm thinking of buying this :1080P 4K HD Industrial Microscope 150X C-Mount Lens 48MP/13MP Digital Camera HDMI USB-C VGA Measurement For PCB Soldering DIY it's on ALiExpress : https://www.aliexpress.com/item/1005...av-description
      the one i choose is the D full Set
      maybe you can advise me or maybe someone who has similar who can give feedback on it very grateful for...
      02-24-2025, 07:13 PM
