I have been attacked by leto ransomware and my files are encrypted, has anyone get solution to this please
by mon2Hi. We have an office client who has been contacted by the local internet provider that one of the office Windows PCs is infected with a virus. The report has been confirmed. Apparently through a remote outside trigger, this virus is performing brute force attacks around the world from this local IP address at varying times. Aside from low level formatting each PC, what is the recommended approach for this case? Running F-prot (suggested by the internet supplier) has come up empty. We are planning to run hijack this. At this time, we do not know which PC is creating this issue. Internet provider...
by tommy97Hi,
we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method? -
by bohabohaI want to find a solution, perhaps an ultimate, solution to this dilemma with your expertise. As it stands, the diffuser is too close, if not directly on the joint, there must be a way to separate without affecting image quality, I'm thinking with small glass strips or maybe pieces that make it a little distance, melan, them, or what do you suggest?
I Have Gigabyte B450 Aorus Elite V2 Motherboard. it has this problem (Video ADDED)
I Already reprogram bios , change cpu and rams , core voltages are ok (cpu Heating ), other all voltages are ok and sometime display comes (Randomly display comes properly)
anyone have solution... -
Gigabyte h310m s2h rev 1.1 motherboard come bios screen and keep restarting .sometime 2 3 times fan spring and off after come bios screen . some time working 15 to 30 minutes .
I allready checked
VCCPLL voltage ok
VCCIO Voltage ok
VCCIO Enable ok
VCCSA Voltage Ok
VCCSA Enable Ok
VRM IC voltages ok
Replaced VRM IC
Replaced LM358 ic
Re programed Bios
But sometime motherboard working 20 30 minutes and restarting ......sometime have fan spring and off error ..........anyone have solution...07-08-2025, 10:16 AM - Loading...
