attacked by leto ransomware
  • steveadenuga
    • Nov 2019
    • Nigeria
    I have been attacked by leto ransomware and my files are encrypted, has anyone get solution to this please
    • 21626
    Re: attacked by leto ransomware
    https://www.bleepingcomputer.com/for...ecrypter-leto/
    • freakyali
      • Mar 2020
      • pakistan
      this tool has virus , i have checked it on virus total.
      • mon2
        Hunting down a virus in an office
        by mon2
        Hi. We have an office client who has been contacted by the local internet provider that one of the office Windows PCs is infected with a virus. The report has been confirmed. Apparently through a remote outside trigger, this virus is performing brute force attacks around the world from this local IP address at varying times. Aside from low level formatting each PC, what is the recommended approach for this case? Running F-prot (suggested by the internet supplier) has come up empty. We are planning to run hijack this. At this time, we do not know which PC is creating this issue. Internet provider...
        01-09-2025, 09:42 PM
      • tommy97
        MacBook A1932 & A2337 MDM - Permanent solution?
        by tommy97
        we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
        06-18-2025, 02:43 AM
      • bohaboha
        DO THERE IS A SOLUTION PREVENT MELTING DIFFUSER
        by bohaboha
        I want to find a solution, perhaps an ultimate, solution to this dilemma with your expertise. As it stands, the diffuser is too close, if not directly on the joint, there must be a way to separate without affecting image quality, I'm thinking with small glass strips or maybe pieces that make it a little distance, melan, them, or what do you suggest?
        03-06-2024, 12:59 PM
      • Fernon@Repair
        Gigabyte B450 Aorus Elite V2 No Display Solution Pls
        by Fernon@Repair
        I Have Gigabyte B450 Aorus Elite V2 Motherboard. it has this problem (Video ADDED)
        I Already reprogram bios , change cpu and rams , core voltages are ok (cpu Heating ), other all voltages are ok and sometime display comes (Randomly display comes properly)
        anyone have solution...
        08-27-2025, 12:54 AM
      • Fernon@Repair
        Gigabyte h310m s2h rev 1.1 Keep Restart solution pls
        by Fernon@Repair
        Gigabyte h310m s2h rev 1.1 motherboard come bios screen and keep restarting .sometime 2 3 times fan spring and off after come bios screen . some time working 15 to 30 minutes .
        I allready checked
        VCCPLL voltage ok
        VCCIO Voltage ok
        VCCIO Enable ok
        VCCSA Voltage Ok
        VCCSA Enable Ok
        VRM IC voltages ok
        Replaced VRM IC
        Replaced LM358 ic
        Re programed Bios
        But sometime motherboard working 20 30 minutes and restarting ......sometime have fan spring and off error ..........anyone have solution...
        07-08-2025, 10:16 AM
