I have purchased a "New motherboard and Ryzen cpu" from Amazon. My Question,,, Should a new motherboard have any wear marks where mounting screws are that hold it to case. (compression of solder pads around mounting hole) Board looks good????? but i am leary.
New motherboard??
Re: New motherboard??
Thanks for the reply.
I thought as much but wondered if factory did any testing by mounting the board in a case. It was purchased and fulfilled by Amazon and a replacement is on the way. It was probably returned as new. The small solder pads that encircle the mounting holes show the imprint of screws being tightened in the normal way, I just expect new when I believe I am purchasing NEW.Thanks to all for being__WAR_KITTENS____!
I've handled thousands of new motherboards over the years and have yet to see one with screw marks out of the box.
I know of plenty of items people have purchased as new and they haven't been but that was always fulfilled by a third party not Amazon.
I wouldn't have thought i would be possible to mix up returns and new with the way their fulfilment centres are run but they do commingle stock with certain vendors so it's possible it was introduced then.Comment
by glovecapsHello,
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by DocusHi everyone 😀,
I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:- I already own the exact same model, but its plastic chassis is badly damaged.
by ArchimedesSubject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
Fans are spinning. Blindly could install windows11 and got the device manager... -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
