how to make a password protected SSD accessible
  • breezer
    • Mar 2020
    I want to reset a password protected Samsung NVMe SSD from an Lenovo Thinkpad to make it accessible to reuse the SSD, the password is unknown.
    If the SSD is plugged into the Thinkpad I cannot boot up the Laptop because the hard drive password prompt block it. I can only reach the BIOS settings if the SSD is plugged out.
    I tried to reset the SSD via "Parted Magic" live Linux with "Secure Erase" and PSID revert on an other PC where I can skip the password prompt but nothing worked. The drive is still inaccessible.
    I also tried to use the Lenovo Erase Utility: https://support.lenovo.com/us/en/downloads/ds019026
    The problem is that I cannot boot the Lenovo utility because the hard disk password prompt blocks all.
    I'm worried about that the SSD is forever locked and bricked.
    Anybody got a tip for me to solve the problem?
    • 31291
    Re: how to make a password protected SSD accessible
    you could boot from a second harddrive in the optical bay maybe.
    or look on the russian site for low level utils
    https://www.usbdev.ru
    • outsider
      Panasonic FZ-G1 MK5 - BIOS password returning
      by outsider
      Hello
      I removed the BIOS password thanks to the help of one of the friends of this forum.
      https://www.badcaps.net/forum/troubl...61#post3637661
      The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
      06-17-2025, 12:51 AM
    • Syseng
      Lenovo P14s Gen 5 SVP unlock
      by Syseng
      This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
      The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
      06-22-2025, 07:44 AM
    • Tegarr
      Dell Inspiron 15 5578 Password-protected
      by Tegarr
      Hi, I recently got a Dell Inspiron 15 5578 for free because it has a BIOS password.
      Service Tag: G66PBL2
      BIOS chip: MX25L12873F
      I've already tried the usual solutions: Removing the CMOS battery, finding a jumper pin, and using https://bios-pw.org/. No luck.
      It seems my only option left is to flash the chip, but unfortunately I made a mistake and corrupted the BIOS when I tried to flash it the first time.
      I got a dump of the BIOS before I corrupted it and would appreciate it if someone could either remove the password or provide a new, clean...
      02-05-2024, 12:34 AM
    • mnciks11
      Hp ZBOOK 15u G4 password protected
      by mnciks11
      Hello guys
      I'm working an hp that is bios password protected, with Hp start Protection.
      Allows you to scan with a fingerprint or password.
      I used the hp tool but didn't work at all , the computer still turning On fine and ask for a password
      Below is the 2 bin files hoping someone might assist me
      Thank you...
      04-27-2022, 07:18 AM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
