BIOS flashing techniques?
  • bigbeark
    • Jan 2010
    • 661
    Last time I flashed a BIOS was about 4 years ago and I used the old school method - A floppy loaded with DOS files and the downloaded BIOS file. I'm a bit hazy on the details now.
    Can anyone here refresh my memory on this or suggest a modern method. I had one of those BIOS programming cards that hooked up to a serial port or a USB port but I never got it to work properly and it seems to have been lost in my house moving.
    I still have a bunch of floppy drives and cables but I only ever flashed old socket A and 370 chips because I feared bricking the BIOS.
    Short of buying a new BIOS chip what do you guys do?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: BIOS flashing techniques?
    It all depends on what needs updating but generally if it's dead I remove it from the board to program. If it's on a working device, it all depends on how the BIOS update is provided as to how it's programmed, some update from Windows executable some USB.
      • 31077
      you can use a program called Rufus to create a bootable dos usb stick.
      then use it just like you used a floppy disk
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        If the board allows physically removing the chip (aka PLCC/DIP socket), then simple. I crank out another board, a 8GB WDC with a 98SE install on which I copy the BIOS file, and then boot to DOS. I use Uniflash 1.40 most of the times, except on newer boards (P4 and up usually) where I use the DOS variant of flashrom.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Loli Popu
          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 03:28 AM
        • drux
          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
          by drux
          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
          These models have AMI/Aptio BIOS.
          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
          11-03-2024, 01:18 AM
        • Timeeez
          X270 - Bios flashing help
          by Timeeez
          I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
          Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
          11-30-2022, 05:17 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
