Command for checking response of remote unit
+ More Options
Posts
  • japlytic
    • Oct 2005
    • 2086
    When I was writing code for a remote HF preselector, I implemented a serial command (AHOY) for checking if the preselector responds which this command is used for checking communication between the remote head and the main unit of a Philips FM91/92 transceiver.
    Do you know of any other commands for checking response of a remote unit?
    2
    AHOY
    0%
    0
    BAT (basic acknowledge/answer test)
    0%
    0
    HELLO
    0%
    0
    AT (attention)
    0%
    0
    AREYOUTHERE
    0%
    1
    Something else (please specify)
    0%
    1
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Command for checking response of remote unit
    Howdy Pard!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Marco!
      (And the remote unit's ping: Polo!)
      sigpic
      (Insert witty quote here)
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        on irc they also have the "ping" command to check the response of their irc bots and the reply from the bot would be "pong".
        • cstout
          DeLonghi AC Remote only accepts 3V
          by cstout
          Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
          The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
          I can't find any schematics...
          06-03-2024, 03:53 PM
        • Mc_Millian
          Toshiba 50lf711u20 fire tv remote not pairing
          by Mc_Millian
          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
          The Tv model number is: 50lf711u20 Rev B.
          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
          I've tried 3 different remotes which should be fully compatible with this TV.
          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
          The power button, along with the volume,back,select, and directional...
          04-07-2022, 12:15 PM
        • ngml
          Repair of an LG split AC system indoor unit PCB
          by ngml
          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
          This indicates an error in the communication between the outdoor and the indoor unit.
          The outdoor unit is fine, so the problem is the indoor PCB.
          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
          Does anybody have the schematics of this board,...
          02-01-2025, 12:55 PM
        • valvashon
          Repair Success! Middle Atlantic UPS2200R-IP
          by valvashon
          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
          02-06-2024, 12:54 PM
        • rustinjust
          Please help, where can I get a remote for my subwoofer?
          by rustinjust
          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
          Is there...
          10-28-2023, 03:43 AM
