Mac Pro 2009 ipgrade 4.1 to 5.1
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi
    I i've got a MacPro 2009 with 4.1 firmware. As to use a CPU six core, i must to upgrade the firmware from 4.1 to 5.1.
    I've tried to exchange the bios by using a 5.1 bios from another machine, it's working fine but the fan goes to max (the machine don't recognize the CPU fan)
    Maybe i need to exchange SMC too...?
    I know that exist a special tool that solve this problem, but this tool we can find only on netkas.org web site.
    This web site is down so i ask if anyone can help me on this.
    Thanks and best regards
    Luca
    • 21626
    Re: Mac Pro 2009 ipgrade 4.1 to 5.1
    You can still get it,using the waybackmachine https://archive.org/web/
    https://web.archive.org/web/20191208...pic,852.0.html
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      Usually when the fan reaches its maximum on the Apple notebook, it is necessary to check all the connections of the temperature sensors. To get around this problem there is a tool, but now I don't remember where download it. I have it in my lab but next Monday. However, it is possible that the problem depends, as you said, on other causes. What processor mounts, are you sure it's a 6 core?
      • rex98
        HP DMI Tool
        by rex98
        HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
        DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
        The DMI Tool given here are for personal use only.
        DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
        You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
        from it, and that you please credit the author...
        07-02-2025, 05:51 AM
      • Wachenaggo
        any tool or guide to update BIOS ROM Firmware from FD or SCAP file?? from MacOS Installer?
        by Wachenaggo
        i know a tool https://github.com/MuertoGB/MacEfiToolkit is capable of SN change and Clean ME but not updating EFI Version of the BIN file. is there a guide or a BIOS structure to update the firmware??...
        03-06-2024, 01:34 AM
      • TheUser
        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
        by TheUser
        Hello to everyone ,
        This is my first post here, and i would like to share with you a small story in case you can help me.
        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
        02-10-2024, 02:07 PM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • gurj1979
        Ubiquiti firmware help. US-8-150W POE
        by gurj1979
        Hi guys.
        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
        Got New chip and writes good.
        THE PROBLEM...
        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
        Does anyone have a Good Firmware I can have?...
        07-22-2024, 05:13 PM
