best cheap/free scores 1.1
This is a sticky topic.
    Re: Your Best Dumpster Finds
    Just got a HP 6820s, it's been sitting outside for a while (there were earthworms on it lol), but it's complete and in pretty good condition. I'm cleaning it completely, there is water trapped beneath the BGA chips of the motherboard so I'll let it dry. None of the components seem damage, just dirty, and a tiny bit of rust on some of the steel parts. The worse seem to be the WiFi card but who knows. I have quite a few of those anyway.
    Inside is a Core 2 Duo T7500, 2x1Gb of DDR2 and a ATi X1350 with 128Mb of dedicated memory on a 17" screen, and a 160Gb hard drive. I have good hope to get it back to life since it doesn't have the bad GeForce chips from the same era. It could be a pretty good machine. The GPU is old, but at least it can play games like Source engine games (I could play L4D2 with a X600M and a Pentium M 750).
    EDIT : the HDD works, that's a good sign ^^
    EDIT2 : Yay the motherboard works !!! One more laptop, and a pretty good one. The flat panel has water in it though, I'll try to clean it but I have two spare ones so it's not a big deal.
      Re: best cheap/free scores 1.1
      Scored an HP officejet 6500 for $8. Included ink.
      sigpic
      (Insert witty quote here)
        Once you run out of ink, that printer is going to become a big paperweight (as I bet the ink for it is quite expensive). The local CL here is flooded with similar free inkjet printers - and I still wouldn't touch one unless I needed some gears/motors/optical sensors out of it.
        But I guess if you print more than 160 pages out of it with that ink cartridge, then it wasn't a bad deal ($0.05/page).
          Not really. Remanu ink is $12 for a large black tank and $10 per M/C/Y tank. For name brand, $20 per black and $10 per color.
          It's not some throwaway POS one... heck it even has a duplexer and wireless (not to be confused the the base model 6500 which lacked both)... Yeah, it's HP, but a high end officjet HP.
          sigpic
            The question is, how many pages can you get out of one cartridge?
            I hate to break it to you (pun intended), but it is. We had some 8000 series officejets in my workplace and they were all plastic-fantastic inside. Most common problem was a broken plastic toothed ring in the paper feed mechanism. Requires the whole printer to be taken apart down to the smallest bolt and screw to get to it.
            I got a large box of motors, gears, optical sensors, and other goodies out of the 2 we threw out, though.
            The scanner is nice, though. I have a crappy consumer-level Epson AIO, and all I keep it for is the scanner.
              Brand new in 2009 it was a $500 unit... yeah, the insides are plastic, but it looks pretty well built.
              Not sure how the yields are... It uses the HP 920 series of cartridges. Supposedly the high yield 920xl set is good for up to 1200 pages...
              sigpic
                46" Full HD Panasonic Plasma.
                Won it for £71 on eBay listed as not working "half screen distorted".
                Turns out only fault was loose cable between A & D board.
                Has run fine for over two weeks now.
                  Got a free dell c400 for free from another forum. Only paid the post €2.79 = around 4 dollars. Has no hdd and charger, and a broken hinge. Don't know the condition, not tested. It has one of them older 3pin chargers, PA-6 or PA-8. PIII M 1.2 ghz, 1gb of pc 133 sdram. Battery is empty or dead.
                  I can put text here?!
                    I won an auction on eBay last week for five supposedly dead Graphics cards :
                    - HIS Radeon HD5850 with the box and all the bundle (nothing on screen)
                    - Radeon HD4850 (nothing on screen)
                    - Radeon HD4890 (nothing on screen)
                    - GeForce GTS250 (nothing on screen)
                    - GeForce 9600GT (artefacts)
                    All of this for...15.5€, plus 20€ for the shipping (the french postal service is awfully slow and expensive for such a small country). It should arrive this week.
                    Even if I repaired only one of them, it would still be a good deal. If not, well they would be good additions to my collection !
                      Most recent and decent find has got to be my now two spare pc's...
                      First one is and Emachines E4264
                      Intel Core 2 Duo E4500 CPU
                      1Gb DDR2 533mhz RAM
                      80GB HDD
                      Nvidia GS8400 512MB PCI-E Graphics card
                      DVD RW Super Multi Format optical drive
                      Second is a custom Build
                      Intel Q6600 Cpu
                      8GB Kingston DDR2 800mhz RAM
                      2 x Nvidia 8600 GT graphics in SLI config
                      500GB SATA 2 Raptor HDD
                      Multi Optical Writer
                      15 in 1 Card Reader
                      All housed in a ThermalTake Tsunami Dream case.
                      Both systems would not post.... connected speaker to F_panel Jumpers and tried again.... Both system beeps indicated RAM Failure... So popped RAM out of both systems and cleaned contacts and reseated... Emachines booted fine but Custom gave same error... Airblasted the DIMM sockets and reseated RAM.... BAM!!! Booted fine
                        Well well, I've received the cards this morning and so far:
                        the HD4850 works...
                        I've repaired the HD5850 : a little Z08K 5 pin component was gone, found another one on an old dead Ti4400, and bam, started right up
                        It even comes with the complete bundle in great condition.
                        The 9600GT does indeed makes awful artefacts
                        The HD4890 is actually a 4870 1Gb :/ doesn't work indeed.
                        The GTS250 doesn't work either.
                        I haven't looked closely at those three yet.
                          Originally posted by J Riff View Post
                          Spooky, Phaihn - I found the same PC a couple days back. Going to try and fire it up tmorrow. 500GB HD. Maybe there's a reason people toss them. *
                          Found a Toshiba Satellite Laptop - BIOS password locked. Took an hour to read up online, jumper a pin and presto.
                          LOts other stuff, gotta know where to look*
                          i assume it was tossed cause of the bad PSU i havent tried to turn it on yet need to pickup a good PSU for it.
                          My Computer.
                          AMD APU A4-3300 2.5ghz 1mb cache
                          Motherboard GigaByte GA-A75M-S2V
                          Kingston HyperX Blue DDR3 8GB (2x4GB)
                          SB Audigy 2 ZS [B800] Sound Card
                          500GB WD Caviar® Blue™
                          1 Terabyte WD Caviar® Black™
                          2 Terabyte WD Caviar® Black™
                            Gotta be my 512MB Sapphire 3870 I found IN THE BOX with ALL ORIGINAL ACCESORIES.
                              Found a PS2 Slim and first-gen Xbox on a roadside collection tonight. Both systems were missing controllers and other peripherals, however I already have a PS2 Slim power brick (also a trash-find from last year) and many games for my current 'fat' PS2; I won't be able to test the Xbox for a while as I have never owned one before; it's pointless just powering it up with just a figure-8 AC cable alone.
                              The PS2 works, but only with CDs; DVD-based games don't load at all. Good enough for Tekken Tag I suppose.
                                My friend's daughter gave me an iPOD touch 4 with a shattered screen. She told me to "just get rid of it". It also needed a wifi antenna, and home button.
                                For about $30 in parts, I am now the proud owner of a very expensive, overrated, Apple, Facebook, Google tracking device.
                                :P
                                  That one should make it alive too. Just reflow GPU and RAM (don't forget to use flux).
                                  You got a pretty good deal with those video cards.
                                  Classic solid laptop. The only downside is those Latitude C series laptops won't take more than 512 MB or RAM, and even for that you need low-density 256 MB sticks which are hard to find (and will probably cost much more than what you paid for the laptop too )
                                  I got a C600. Still kicking along - even its 13 year old battery holds a 1 hour charge. I use it regularly too.
                                    got for $35 a c2d motherboard and cpu 2x512mb ddr2 a wd 250gb hard drive and a ide opitical drive and a cheap power supply there was a case i just took everything out and tossed the case it looked like crap anyway. looks like it was a MDG special.
                                    My Computer.
                                      ok it might be a Pentium d at least according to the bios someone must have swapped the cpu at some point.
                                      oh well ill switch it out with the Core2Quad i got from my friends computer.
                                      My Computer.
                                        Getting a 1U SuperMicro server with dual quad core Xeon CPUs, 32GB, and four hot-swap SATA bays
                                        Two of these will use a crapton of power, and it's noisy, but I couldn't resist a good deal!
                                        http://ark.intel.com/products/33088/...z-1600-MHz-FSB
                                          Recently picked up a Dell Poweredge 2600 server with a pair of 73GB HDD's, two 2.6GHz Xeons and 2GB ram for less than £50 including shipping!
                                          right now it's running a (kosher) copy of server 2003 I've had laying around forever and SQL 2008 R2 (the latter for a project I'm working on), just need to decide what to do with it beyond this...
                                          when I got it I was hoping it would take a pair of 64-bit s604 processors but it seems these aren't supported by even the latest bios
                                          Guess I'll have to go with plan B: max out the RAM and put another four HDDs in there unless there's someone out there who knows a way to hack the BIOS into working with the later, 64-bit Xeons?
