scoren another computer. 99 bucks got me (@ goodwill):
sturdy foxconn case with room for 4 cdrom, 1 floppy, 4 hd (one canbe converted into a 2nd floppy)
shitty allied powersupply- 5 bad caps but thick metal/wire, decent heatsinks, working fan, good guts, yc primarys, jun fu (i think) secindarys, re-solderable pcb
40gb wd hd, floppy, 16x dvd-rw. 24x cd-rw, 50x cd-rom (3 cd drives!)
stock athlon cooler (filled with dust)
geforce2 64mb, clogged heatsink with dead fan
256mb ram
corrupted xp install
amd athlon xp 1800+
asus a7v8x mobo:
integrated sound
6 usb ports
6 pci (one asus bluepci)
agp-8x
2 ide
1ide , 2 SATA raid
gigabit ethernet
2 firewire
also had an upgraded sound card- 5.1 channel e3dx pci w midi/gameport
case had one 80mm case fan in back
case has a 80/92mm spot in back, 2 80mm spots i sise-by side on front, vents on sides, front, and back.
now for questions:
1. did i get a good deal?
2. are allied psus wort recapping?
3. why does the computer only detect 1 hard dirve on the raid controller when i have 2 ide drives on the raid port. drives set to cable select.
i will mpost pics soon. different graphix card (old one has new cooler on it and is in another machine), swapped allied psu for a delta, upped ram to 768mb, removed 40gb hd and added a 320gb and a 160gb. removed sound card. moved case fan to front and added another 80mm in back. cleaned out dust bunnies. re-greased cpu cooler (had thermal-gum on originally)
256mb ram
amd athlon xp 1800+
asus a7v8x mobo:
integrated sound
6 usb ports
agp-8x
2 ide
1ide , 2 SATA raid
gigabit ethernet
2 firewire
now for questions:
