Need to find caps
  • Phaihn
    • Jan 2009
    • 842
    Need to find caps
    Does anyone know whare i can find 2 of these caps the big orange one.
    Intel D865PERL Socket 478 Motherboard.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Need to find caps
    talk to topcat you need 6.3v (or higher) 560uf caps. must be 560uf since thats the marked value. samxon will work fine or go rubycon if you want the absolute best. since you are in between memory chips, id pay more and get rubycon since it can get hot there
    ps, try to get the physical size right as well. get out a ruler/tape measure and measure in mm of both diameter and height.
    pps. any other nichicon hm/hn on there/ replace any of those as well since those were a bad model. brand on yellow caps?
    sigpic
    (Insert witty quote here)
    • Phaihn
      • Jan 2009
      • 842
      talk to topcat if you are in the usa/canada. you need 6.3v (or higher) 560uf caps. must be 560uf since thats the marked value.
      if not, get samxons from big pope or go to digikey for panasonics (pannys). the board will love you for it
      pps. make sure the the caps are low esr or ultra low esr
      ppps. any other nichicon hm/hn on there/ replace any of those as well since those were a bad model. brand on yellow caps?
      Uhg if i have to replace all the caps its going to turn into an expensive repair job.
      My Computer.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        question- do you want the board to work for sure or not. caps often fail without visual signs. since you have no esr meter, you will have to replace all the bad model/brand ones. remember you get half off caps since you are an active forum member.
        sigpic
        • Phaihn
          • Jan 2009
          • 842
          Half off? whare do i have order them from Topcap?
          yeah want the board to work but ive never replaced caps before and the computer place charges by the hour and the other one is 10$ a cap if i am not in a hurry.
          My Computer.
          • etnietering
            • Apr 2009
            • 379
            make sure to measure the lead spacing on the bottom, too
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              yeah, order them from topcat. he gets them in bulk and even samxons would do fine if money is a concern.
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                do you know how to solder?
                to recap, you need:
                a GOOD soldering iron/station, 30 watt, ones with a tip holder like this:
                that is the international vs of mine, xytronic 258 adjustable temp grounded professional iron.
                it disassembles by a sleeve being threaded over the shaft with a flanged tip in between.
                dont buy one like this:
                the tip is a shaft with a tip held in by a screw. poor heat transfer, bad quality, not grounded, and unlike the one above, no replacement/different tips are available.
                for solder some recommend 40/60- i use silver-bearing. make sure it is thin spooled kind
                for solder suckers, do not use this kind:
                or
                those are pogo stick plastic or plastic-aluminum hybrid suckers. the threads holding it together will strip and fail, often shooting a tip across the room and possibly breaking a window/hurting your self
                admittedly, i use pogo stick myself. mine:
                it is of all aluminum construction
                some, particularly kerijane, like this kind:
                it has a softer touch and if you are not keen with you thumb, you dont have to re-cock it. they spill old solder when turned tip-down and are hard to clean
                some will swear by desoldering irons and guns, but good ones cost a real boatload
                if you have a stubborn joint, mix in a small amount silver-bearing solder, make it melt better
                get a good stand:
                if you are using an iron
                buy your tools online or at a local electronics shop. don't go to radio shack, their tools are flash overpriced crap. i had to replace almost every tool i bought there... the local shop had same prices but better equipment . pay for quality, not flashy-ness and and extra middlemen.
                sigpic
                • Phaihn
                  • Jan 2009
                  • 842
                  uh yeah ill look into that for when i do try to do a recaping but i am just going to send it to Topcat for now
                  plus i tend to get a little shaky with my right hand at times.
                  My Computer.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    good idea. my hand was shaky resulting in many botched jobs. but a good iron and practice made it work.
                    btw, you seem to reply fast. im 17 and i thought i was fast but ive seen nothing i see
                    sigpic
                    • Phaihn
                      • Jan 2009
                      • 842
                      lol i wait for a reply plus i usly get lucky and i am 26.
                      My Computer.
                      • Phaihn
                        • Jan 2009
                        • 842
                        Yeah ill have to practice on a dead board or the one the computer place guy gave me.
                        My Computer.
                        • bgavin
                          • Jan 2007
                          • 1355
                          Sex is the only thing a man does faster without practice.
                          OP, learn to go slow and careful on your recap jobs.
                          Speed comes with repetition.
                          A fast, sloppy job winds up as a DOA board, and a re-do.
                          Pull the new caps you just bought, throw 'em out, go again.
                          Dumb.
                          Like painting, the quality is in the prep work.
                          Use a 450C tip to de-solder and remove your caps.
                          I have good luck with both the sucker bulb and stainless needle for cleaning holes.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            fyi, my iron shown above is a 430C at max temp, it does fine.
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              i thought that was a bad thing, right.
                              sigpic
                              • Phaihn
                                • Jan 2009
                                • 842
                                My Computer.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  You can buy compatible replacements from here, ebay, or at Mouser.com
                                  The caps with the "X" vent and black sleeves/gold stripes are probably Nichicon HN. If you buy caps from here, make sure to mention that to Topcat so he can give you compatible low-esr caps. Or if you buy from ebay, look for Rubycon MCZ or Nichicon HZ as those should be compatible as well. Otherwise you can buy the same Nichicon HN caps from Mouser - and don't worry, it's unlikely that they will fail. Reason why is because Nichicon HN and HM had problems with caps made before 2005, but are okay since then. I doubt Mouser will sell you old caps.
                                  Also, check the brand/model of other caps with "X" vents and black sleeves/gray stripes near the PCI slots. If they are Nichicon HM, they might need replacing too (just look for a 4 digit date code on them where the first 2 numbers represent the year - if it's 04 or less, they can be bad). Anything under 470uF, however, doesn't need to be replaced unless the motherboard's problems still persist.
                                  • Phaihn
                                    • Jan 2009
                                    • 842
                                    I am just sending the board to Topcat any-caps that need to be replaced will be replaced.
                                    My Computer.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      Fujitsu polymers
                                      Good brand
                                      to the left of them is another nichicon, as well as those UCC's look like KZE's from what I could see, those may be from the defective series, maybe not.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        I think only KZG (and possibly KZJ) had heat-related problems. KZE uses different electrolyte and their ESR isn't as low as KZG and KZJ.
                                        On Phaihn's board, the KZG caps seem to be on the high-side of VRM so they probably aren't as stressed as the Fujitsu caps on the low-side of VRM.
                                        • SluggerB
                                          Can't find exact matching caps for replacements, what should I get to prevent video issues?
                                          by SluggerB
                                          I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                                          I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                                          The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                                          04-05-2024, 07:47 PM
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • CdDvdFlash
                                          Please teach me how to find datasheets to obsolete caps
                                          by CdDvdFlash
                                          I've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
                                          (Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...
                                          08-12-2023, 12:29 PM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
