faulty 4850?
+ More Options
Posts
  • pentium
    • Mar 2006
    • 2778
    faulty 4850?
    So I bought a brand spanking new (as in I was the first to open the packaging) Sapphire Radeon HD4850 off my friend (he bought it but never had a use for it) for $100 so I could replace my older 7300GT and this so far has been a f$#@&ng nightmare.
    For starters, It's not sending any signal at all (that I know of) through DVI (even at POST) so I'm stuck with VGA monitors and it is not helping that the linux catalyst drivers, touted to be better than the Nvidia drivers, is complete crap. The interface does not even work and won't even modify the xorg.conf file. I'm also locked at 1280x1024 unless I notch up the refresh rate to above 60, at which point my max resolution drops to 1024x768.
    Still, That's probably a software issue but why no DVI? I tested both the cable and the monitor on an ATI Radeon 9600 Pro in my parents computer and it worked flawleslly so why no here?
    There's no way I can RMA it however it is still under the newegg warranty though but I have never done a return on something like this before.
    Find Nedry!
    Check the Vending machines!!
  • NxB
    • Feb 2009
    • 1595
    Re: faulty 4850?
    Why can't you RMA? I did it with my X850 when it died. Can you enable the DVI in windows? You have to add a second monitor and then make it your primary through catalyst. The setting should hold in linux and through post once you set it up. I have to do this for my NEC plasma.
    Ati driver in linux is better than windows (no smartgart for me). The software they include is crashy. Hit the wrong thing and you can lose all output.
    • pentium
      • Mar 2006
      • 2778
      Re: faulty 4850?
      Apparently this is out of the RMA window now but still in the warranty.
      Also, this card is strictly for Linux and the Catalyst control center is not even detecting a DVI monitor as being connected. It only sees VGA monitors which defeats me even using this nice and newly repaired widescreen LCD panel.
      Find Nedry!
      • sofTest
        • Aug 2008
        • 361
        Re: faulty 4850?
        Your cable might still be the problem, if it's a DVI-D or a DVI-A cable, depending on what output mode your card uses, and what signal type your monitor supports. DVI-D is a digital only cable, and DVI-A is a analog only cable. For a cable that supports both modes, a DVI-I cable is used. Read more about the different different DVIs here. You might also check the menu of your monitor, if you can switch between analog and digital input. If the card is the dual head DVI version, have you tried both?
        Be a mensch
        • pentium
          • Mar 2006
          • 2778
          Re: faulty 4850?
          Well I'm using a regular DVI-D single link cable to connect this SyncMaster 225BW to the card. I already tested both the card and the cable on another system (using a Radeon 9600 Pro) and it did detect and display video on the card however I din't check to see if it had video during boot but I'm assuming that it would so long as nothing was plugged into the VGA connector.
          Another thing I have noticed is that while I can't use DVI monitors, I can still use analog VGA monitors so long as I sue the DVI-VGA adapters and now i'm noq quite sure myself if it really is the card.
          While I was waiting for the night to pass I pulled 4850 and installed a 7300GT and plugged the monitor into its DVI port. Again, the system booted up but gave nothing out of the DVI port unless you have a VGA monitor with the adapter plugged into it. I'm almost thinking the motherboard itself might be somehow switching DVI off but that's not possible, right?
          Find Nedry!
          • sofTest
            • Aug 2008
            • 361
            Re: faulty 4850?
            DVI is on, as the analog signal part of the interface (via the VGA adapter) works. Somehow the digital signal part of the interface doesn't get through. Do you get the "No signal source" on the monitor? I checked the manual for your monitor, which you can find here, and you can set the signal source to auto, analog or digital. There is a troubleshooting procedure in there for testing for signal faults. You might want to try to set your monitor to the digital signal source setting, in case if the auto detection doesn't work. Can you test/borrow another DVI cable, in case your is dodgy? Again, if the card got dual heads, did you test both?
            Be a mensch
            • NxB
              • Feb 2009
              • 1595
              Re: faulty 4850?
              My x850 pro did not switch to dvi by default automatically. It would display nothing until I set it up in windows . Only displayed on the VGA. Install XP on a small partition and see what it does under that.
              • pentium
                • Mar 2006
                • 2778
                Re: faulty 4850?
                I ahve two other DVI-D cables and tried both of them as well on both of the DVI ports and still no dice.
                Can't really do that as I partitioned the two drives (running ubuntu and have one drive as / and the other as /home) in such a way that I can't make room for an additional partition. Still, with most people gettig LCD panels now, I would expect that you would be able to get a DVI signal by default if not by drawing from that analog interface on the DVI port.
                Find Nedry!
                • pentium
                  • Mar 2006
                  • 2778
                  Re: faulty 4850?
                  Oh yeah, I also set the input selection to manual and toggled from VGA to DVI and all I got was a blank screen. I kinda expected that as not even ubuntu detects a DVI panel being plugged in.
                  Find Nedry!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: faulty 4850?
                    maybe your card is a DOA
                    hey, it happens
                    hope thats not the case, but sometimes things die
                    sigpic
                    (Insert witty quote here)
                    • pentium
                      • Mar 2006
                      • 2778
                      Re: faulty 4850?
                      hey, it happens
                      Does not explain why a completely different brand of card also refuses to output a digital video signal.
                      Find Nedry!
                      • KeriJane
                        Mac Enthusiast
                        • Sep 2008
                        • 681
                        Re: faulty 4850?
                        I had this problem once.
                        It was due to the different kinds of DVI condition as described above.
                        I was using an Apple Cinema Display on a Radeon 3850 card (in a PC).
                        No boot, no nothing but would work fine as a 2nd monitor. A different card was OK.
                        Updating the cards Firmware did it for me. The Firmware update was actually intended to correct something else but corrected the DVI issue as well.
                        Ultimately, buying a Mac Pro to go with the ACD was where I went.
                        Have fun,
                        Keri
                        The More You Learn The Less You Know!
                        • pentium
                          • Mar 2006
                          • 2778
                          Re: faulty 4850?
                          So you think a firmware update will fix this?
                          I'm doing a search and so far I have not come up with any firmware updates.
                          If need be, I can shoehorn the card into a spare slimline dell system with a pci express slot for the upgrade as I don't think linux will let me do that (flash the card).
                          Find Nedry!
                          • KeriJane
                            Mac Enthusiast
                            • Sep 2008
                            • 681
                            Re: faulty 4850?
                            Hi pentium
                            I really couldn't say about the 4850.
                            The early ATI-built 3850 cards had a firmware update that corrected the inability to OC using the ATI Catalyst panel.
                            The update was extremely hard to track down and correcting the DVI incompatibility issue wasn't on the list of fixes.
                            After flashing the card it would then boot OK using the Apple Cinema Display and I was then able to run it on only the one monitor. It had always worked OK using a Sony display. Before the flash, I would either have to disconnect the ACD (no display) or have a 2nd monitor connected for the computer to boot.
                            This is what happens when a standard such as DVI is loosely defined. One gets odd incompatibilities. Probably the card will work fine with a different monitor.
                            Good Luck,
                            Keri
                            PS. Bluetooth is another loosely-defined standard with a TON of compatibility issues.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Re: faulty 4850?
                              sorry, missed that
                              yeah, xp it long enough for the flash, then go back to linux
                              sigpic
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Re: faulty 4850?
                                <<PS. Bluetooth is another loosely-defined standard with a TON of compatibility issues.>>
                                so was agp... 1x 2x 4x 8x
                                and the cards/slots that were "universal" so the card fits into the slot (or vice-versa) but was not, resulting in dead cards and mobos
                                and agp pro was funky too
                                sigpic
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Re: faulty 4850?
                                  I remember killing three AGP motherboards with ym Wildcat 3000 before I stuffed it in my Dell and it didn't kill it.
                                  I'll try the shoehorning after I sleep and if the monitor works there.....well. :/
                                  Find Nedry!
                                  • NxB
                                    • Feb 2009
                                    • 1595
                                    Re: faulty 4850?
                                    Bios update on the card won't help you. I doubt they would omit something like this. I've only used them to unlock pipes or overclock and in one case to test a mac 9800 pro (ppc bios is inc.) Boot XP and setup a second display as DVI then switch it to primary otherwise have fun with vga. You have to have some really old or crappy hard drives to install it on. Once you set it up it *SHOULD* hold until you change it, mine does. If it won't run a second display as DVI something is actually broken.
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      Re: faulty 4850?
                                      One thing I hate about nights is I get no time at all anymore to do stuff.
                                      You will have ato wait a few days until I get my time off before I can test this now.
                                      Find Nedry!
                                      • JarzabekPZ
                                        HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                                        by JarzabekPZ
                                        I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                                        08-08-2025, 03:40 AM
                                      • Spudgun
                                        Why doesn't current just bypass faulty capacitors.
                                        by Spudgun
                                        Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                        04-01-2025, 10:33 AM
                                      • b-slayer
                                        Acer A317-53 need help to disable faulty onboard ram
                                        by b-slayer
                                        Hello.
                                        I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                        - first one is to modify le bios to disable the onboard ram.
                                        - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                        so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                        so i found that my motherboard...
                                        10-12-2024, 03:46 AM
                                      • tsavpyn
                                        Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                        by tsavpyn
                                        Dear all,
                                        I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                        Now I have a problem that I am unable to dump my BIOS into bin file.
                                        My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                        I searched for FPT but there is no Linux version and none of them work.
                                        I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                        I would really appreciate it if anyone...
                                        05-28-2024, 11:18 PM
                                      • mr.malcom
                                        HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                        by mr.malcom
                                        this is a very strange Problem:
                                        Notebook hang instantly on Boot. BIOS is accesable.
                                        Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                        Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                        i have tried:
                                        - only one RAM Stick, another working RAM, both RAM channel
                                        - BIOS Flash to newest Version F.50, BIOS Reset
                                        - Memtest86 hang instant at Test 2
                                        - HP UEFI Diagnostic wont find...
                                        02-26-2022, 05:19 AM
