Flashing BIOS with programmer
  • BigAlNZ
    • Mar 2008
    • 65
    Hi All,
    I was wondering where to go to get a good answer to this question, and this place seems a good spot for a bunch of opinions from assorted PC repair folks who like to get there hands dirty.
    Over the years I have got a bunch of motherboards that passed all the usual VRM and Cap checks but didnt boot in that there was no beeps even with ram/video removed and no video.
    I wonder if some of these simply have a bad bios???
    Anyone here program bios's with a programmer? How often do they come across boards with bad bios's?
    I would like to know before I fork out my hard earned cash on a programmer.
    Thanks in advance,
    -Al
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Flashing BIOS with programmer
    Hmm, well
    Once in a while
    I can recommend the True-USB PRO GQ-4X Willem Programmer (add more adapters if you need of course)
    http://www.mcumall.com/comersus/stor...idProduct=4312
    • BigAlNZ
      • Mar 2008
      • 65
      Hmmm, sounds like its very occasional? I really need to try to get my head around how often I will come across them to justify the expense.
      I was looking at this one:
      http://www.weilei.pl/vp480uk.php
      -Al
      • NxB
        • Feb 2009
        • 1595
        Probably more common to have failed chipsets like all of those emachines. I can't imagine bios going bad unless the customer mis-flashed it. A bga machine would probably earn the money back sooner.
        • everell
          • Jan 2009
          • 1514
          Working with industrial precipitator controllers, I would estimate that 2 to 4 per cent of repairs required reprogramming eproms. As a hobbyist, I have repaired a little less than 50 mother boards, and two required bios reflash.
          Board no. one - I was told that owner attempted reflash but failed. It had some bulging capacitors. Between the two problems, the board would not do anything. I replaced bad caps, and it still would not do anything. Flashed the eprom and board works fine.
          Board no. two would not do anything. No visible bulging caps. Blue esr meter did not find any bad caps. Reflashed bios and board came up working fine.
          The programmer you are looking at looks like it only programs DIP style chips. Most computers these days use a square plcc style chip. Unless you are planning to program Pentium 3 or 8086 boards, you will need a programmer that can also handle plcc chips.
          Unless you will need lots and lots of bios chips reflashed, it would be much cheaper to pay the five bucks or so and let someone else reprogram the chip. Do a search on ebay for "bios" and you will find several people offering this service. I used one of them and was very satisfied.
          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
          • NxB
            • Feb 2009
            • 1595
            You would probably get more mileage out of a serial eEprom programmer these days too. You can remove laptop bios passwords that way. I think the willem has a PLCC adapter. The polish one looks like a carbon copy of the willem.
            • BigAlNZ
              • Mar 2008
              • 65
              Yes they both have PLCC adapters.
              The other thing I was looking at was either a PORT 80 card for desktops or PORT 80 card (mini pci) for laptops. There are some very cheap ones out there, and some VERY expensive ones out there.
              Any thoughts?
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • zlr8r
                looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                by zlr8r
                looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                cheers
                Dell Inspiron 17 (7786) Laptop
                Service Tag: 5J0NHT2
                Bios: 1.9.0
                MOBO: RO 15 17 WHL 2GB MB / 18706-2
                Attached;
                1. My saved bios using a programmer
                2. Dells Bios updater .exe (v1.16)
                3. Dells Bios recovery file
                4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                5. Image of ME...
                12-18-2023, 03:08 PM
              • Quaddro
                Problem flashing graphic card bios with spi programmer
                by Quaddro
                Hello..
                i've bricked my old msi 670 card, due to interrupt power while flashing.
                So i want to reflash it again with ch341 spi programmer.
                The source of large collection of bios is from tech powerup.
                The problem is, even i've already found the spesific bios for my card, the size of file from tpu is different from the bios size.
                tpu: 96kb
                file size from spi programmer: 256kb
                What is the difference between both of file?
                Because while i was tried to flash it with as programmer, it cause "error writing"...
                08-03-2021, 09:58 AM
              • what_1282105
                Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                by what_1282105
                Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                02-14-2025, 07:27 PM
              • H34TO
                ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                by H34TO
                Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                06-17-2025, 07:17 AM
