Fan power issue
  • stevo1210
    • Oct 2006
    • 4156
    Fan power issue
    My Inspiron 4000 laptop is working fine at the moment but.... the secondary motherboard fan which is about 1 inch in diameter doesn't work at all..... even when very hot and the CPU fan is running at high speed.
    The *dead* fan however works perfectly when connected to a 5V power source when I tested it with my ATX power supply, which means it's not dead and is well alive.
    I however managed to track down the problem and it is that the fan connector for the secondary fan doesn't have any voltage coming out of it at all.
    I need to find another 5V power source on my Inspiron 4000 motherboard and I don't even know where to start. The fan is rated at 5V at 0.3W.... doesn't say how many amps unfortunately.
    So where can I source out a 5V power source on this motherboard to make the secondary fan work?
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Fan power issue
    It's DC and it does say how many amps it is [indirectly].
    Use Ohm's Law and do the math. - Volts and Watts are all you need.
    Clue:
    http://www.angelfire.com/pa/baconbacon/page2.html
    Mann-Made Global Warming.
    - Dr Seuss
    • Krankshaft
      • Jan 2007
      • 2328
      Re: Fan power issue
      It is possible that the fan connector is driven using PWM via a switching transistor.
      If this transistor failed open you will have no voltage to the fan.
      Trace the positive terminal to the transistor and do a diode check test.
      If the fan wasn't variable speed disregard the above statement.
      If worse comes to worse and you can't find a 5V source you can always find a 12 volt one and install a little TO-92 voltage regulator to get the +5 volts.
      You could always tap off the power jack as well.
      • stevo1210
        • Oct 2006
        • 4156
        Re: Fan power issue
        I did the math and it's 0.06amps, which equates to 60mA. Should I splice the +5V wires of the CPU fan and connect the positive wire to that line? or is that down right dangerous since I could burn something? The CPU fan is 5V, 0.1A, 0.5W.
        • stevo1210
          • Oct 2006
          • 4156
          Re: Fan power issue
          That's what I think happened and I'm quite certain of it. Now even if that transistor is dead, I won't have the appropriate tools to remove it let alone install or source a new transistor.
          • stevo1210
            • Oct 2006
            • 4156
            Re: Fan power issue
            Is the CPU fan connector able to handle the secondary fan along with the CPU fan or is that going to blow it?
            • Krankshaft
              • Jan 2007
              • 2328
              Re: Fan power issue
              If the CPU fan is variable speed and most laptop ones are.
              You have to be concerned about exceeding the current the PWM transistor can supply. You don't want two dead fans.
              Look for a 5 volt source on the HDD or DVD drive connecting ports solder the wire directly to the pins where they solder to the PCB. That should be a convenient tapping point.
              You do intend to solder a wire right? If you're looking for some easy to tap off wire to splice into I think you're out of luck.
              • stevo1210
                • Oct 2006
                • 4156
                Re: Fan power issue
                Yeah I'm going to solder the wire. I think I'll see if the DVD drive has any 5V current to it.
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Re: Fan power issue
                  I'm sure you can get a pinout for the DVD connector somewhere. Hopefully it will save you some time.
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Re: Fan power issue
                    Hmm.... do any of you guys know where I can get a pinout for the optical drive connector for this laptop? it uses the common optical drive found in Latitude C series and Inspiron 4xxx series laptops.
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Re: Fan power issue
                      The 2.5 HDD pinout is more standard here:
                      http://www0.more-solutions.co.uk/support/hardrives.html
                      Pin 42 for +5V and 43 for GND should do it.
                      Be sure to test the points with a multimeter just to be sure.
                      The pin count starts from the right in the picture top row odd bottom even.
                      Ignore the 4 pin grouping at the far right thats for master / slave selection.
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Re: Fan power issue
                        Thanks for that. I have one problem though, my laptop HDD connector is like that, but it connects to the motherboard in a different way which is impossible to solder onto. So I decided to go and have a look at the connector which the optical drive connects to and I found like 4x 5V channels on there with the multimeter? I don't even know which one of those channels I should be using? Any ideas?
                          master hoarder
                          • May 2008
                          • 12170
                          • Bulgaria
                          Re: Fan power issue
                          In case you need more options, I think USB ports also have 5v. Most should be able to handle up to 500mA. I'm not sure which pin would be the 5v supply, though, so you'd have to check that.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: Fan power issue
                            I think USB would be better.
                            Putting a motor on power to HDD with no EMI/Noise filters not such a great idea.
                            - Dr Seuss
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              Re: Fan power issue
                              I just got done crimping a RJ50 to USB data cable for my APC UPSs. No way I was gonna pay 30 bucks for something I can make for 3.
                              When I was checking the pinouts to make sure everything was right it hit me USB for the 5 volts. Guess you beat me to it PC .
                              The USB A pinout is simple pin 1 is +5V and pin 4 is ground.
                              http://pinouts.ru/Slots/USB_pinout.shtml
                              Look at the diagram with the A next to it.
                              If the USB port is surface mount soldered and not through hole you'll just have to solder to the gull wings (the pins that solder to the surface of the board).
                              • stevo1210
                                • Oct 2006
                                • 4156
                                Re: Fan power issue
                                Done and done. I soldered a cable into the +5V line of the USB connector and she seems to be fine now. All fans work. Though I do have one question.... whats a good glue that I can use to stick that cable I just soldered?
                                I tried hot glue but it doesn't stick very well. I have a tube of Silastic which is a sillicone.... I know this sticks well.... but it is conductive or not?
                                Thanks.
                                • stevo1210
                                  • Oct 2006
                                  • 4156
                                  Re: Fan power issue
                                  I take that back. My glue gun is crappy and it basically spews everywhere once switched on even without pressing the trigger. I think I'll need to get a new glue gun to do the job properly.... but is hot glue the *correct* thing to use in order to stick stuff to a circuit board? it is conductive? and what is the melting temperature?
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    Re: Fan power issue
                                    I use O2 safe silicone RTV.
                                    Hot glue is NOT suitable! I had TV done with these and they wreak havoc on through-hole solder joints on the PCB in specific areas (where high freq subsonic vibration (like 15.7KHz and bit of heat that makes hot glue creep in first year to few years), and pulling connectors off slopped with this hot glue is a bear.
                                    Hot glue in that said situation broke the solder joint between lead and the solder. It is documented, the same joints that didn't have this glue survived far longer. RTV is correct way to do this and does dampen vibration better and doesn't cold/warm-flow.
                                    Cheers, Wizard
                                    • stevo1210
                                      • Oct 2006
                                      • 4156
                                      Re: Fan power issue
                                      Originally posted by Wizard
                                      I use silicone RTV.
                                      Cheers, Wizard
                                      My silastic tube says RTV 732.... does that mean anything? does this stuff eat through metals or is conductive or anything dangerous like that?
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        Re: Fan power issue
                                        I either use transmission RTV or ultra black, or clear RTV. Just a little. So you have air flow thru a notebook.
                                        Cheers, Wizard
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
