Search for specific strings and display only those strings in Linux
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hi! I have a string like this:
    Code:
    192.168.2.2 192.168.2.3 192.168.1.122 192.168.2.4 192.168.2.5 192.168.2.6
    I want to be able to search that string and only display the 192.168.2.* entries. How can I accomplish this in Linux? I will not know ahead of time how many entries there are or what order they go in. In my example, 192.168.1.122 is the third string, but it might not always be.
    I have tried, unsuccessfully:
    Code:
    cat fake_ips | grep "192.168.2."
    This shows the entire line, including the 192.168.1.122. I need the line minus the 192.168.1.122
    Code:
    cat fake_ips | awk '/192.168.2./'
    This has the same effect as the grep command.
    Code:
    cat fake_ips | awk '/192.168.2./ {print $1}'
    This is close, but obviously only prints the first string found. Looping through the variables doesn't help either, because at least one of them will contain the strings I do not want (192.168.1.122 in my example).
    I am sure there is a way to accomplish this, but I am having trouble finding it.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • petehall347
    • Jan 2015
    • 4448
    Re: Search for specific strings and display only those strings in Linux
    Ctrl f
    sorry dont have a clue ...
    • petehall347
      • Jan 2015
      • 4448
      out of interest what is the project ?
      • Spork Schivago
        • Mar 2012
        • 4734
        Code:
        cat fake_ips | grep -o "192\.168\.2..."
        comes really close, but it displays each string on a new line, whereas I need them all returned on one line.
        I am writing a script to automate editing a config file for two...so ctrl-f wouldn't really work here. Thanks though!
        • Spork Schivago
          • Mar 2012
          • 4734
          I customize my Linux machines in a certain way. I have various aliases setup, I use nano so I have a .nanorc file setup, I run an ssh server, but I only listen on the local area network and on a non-standard port, I have various icons setup on my Gnome desktop, various programs that will always be installed, etc...
          I have created a bash script that automates all of this, minus the sshd config file, because the IP addresses change.
          So, I am trying to obtain the IP addresses of the various systems in the script at run time, have the bash script search the sshd_config file, and replace the default ListenAddress with one that only has the private IP addresses.
          • petehall347
            • Jan 2015
            • 4448
            i know nothing about scripting . i stopped at programming amstrad shit in the 1980.s ...
            i didnt know if ctrl f could be invoked within the script . was only joking anyway .
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Try pipping it through "strings" first.
              Learn regex, it helps on every platform.
              Follow the white rabbit.
              • petehall347
                • Jan 2015
                • 4448
                as i thought well beyond my knowledge of copy paste and certain easy things to remember . good luck with sorting it out .. am sure someone else will have more input than myself here .
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  I forgot about strings! I have tried learning regex a few times but that shit is confusing to me!!!! It seems to be extremely powerful, I just can't seem to grasp the expressions.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    I can't seem to pipe it to strings. strings wants a filename, and my example was poor. The pattern I'm looking for comes from stdout, not a file.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      Strings wants a filename?
                      Let me give you an example here.
                      Code:
                      cat BIOS.BIN |strings | grep -i .....-.....-.....-.....-.....
                      Will pull a Windows key from a BIOS image.
                      EG:
                      Code:
                      cat Acer_bios.BIN |strings | grep -i .....-.....-.....-.....-.....
                      Will output:
                      Code:
                      MWGVN-CRM3B-THJMB-00000-XXXXX
                      Also:
                      Code:
                      man regex
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        I was using strings wrong. I was using it like:
                        Code:
                        cat fake_ips | strings "192.168.2."
                        Using your example produces the same unwanted output (the entire line, including the 192.168.1.122).
                        I believe I found a way using tr.
                        Code:
                        hostname -I | grep -o "192.168.2..." | tr '\n' ' '
                        or, using my fake_ips example,
                        Code:
                        cat fake_ips | grep -o "192.168.2..." | tr '\n' ' '
                        Thanks!
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Grrr, still not quiet right. With the grep -o "192.168.2..." it's only pulling up to two wildcard numbers at the end. If I have IP addresses with three, it won't grab them. If I add a third dot, then it pulls the 1 from the next string if the first string has an ending digit that's only 1 or 2 digits long.
                          So I try grabbing the IPs using ifconfig, but it's pulling in the broadcast. So I try searching for a range:
                          Code:
                          cat fake_ips | egrep "192.168.2.[2-254]"
                          But this isn't searching for a range. It shows 192.168.2.2, .5, and .4! Not 192.168.2.2 - 192.168.2.254
                          I try it with grep as well and same results. What am I doing wrong there? From what I've read, it should work.
                          • petehall347
                            • Jan 2015
                            • 4448
                            are the spacing's correct ? sorry my limited knowledge .
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              petehall347,
                              Yes, my spacing was correct. I goontron's advice about the regex, because I felt this was probably the only way to accomplish this. Without regex, the way grep works, I ran into issues. the [2-254] was searching for numbers 2-2 and 5, 4. The final solution came from this website:
                              https://www.regular-expressions.info/numericranges.html
                              Code:
                              cat fake_ips | grep -o -E '192\.168\.2\.([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-4])\b' | tr '\n' ' '
                              It explained why I was obtaining the numbers I was obtaining from my range search with grep, but also showed me how to properly use the range search and word boundaries. The command above prints out the contents of fake_ips to stdout and then pipes it through to grep, which only displays the strings found (-o), and uses the regex expression (-E) to search for numbers 0-9, 10-99, 100-199, 200 - 249, and finally 250 - 254. The \b is the word boundary that says don't do a partial match (so a number like 192.168.2.254 doesn't show up as 192.168.2.25). The \b says make sure there's nothing else attached to the string.
                              What a learning experience! I really thought I knew how to use grep, boy was I wrong!
                              • lucaszmn
                                by lucaszmn
                                Problem:
                                Initial Findings:
                                • I concluded that the
                                08-12-2025, 03:01 PM
                              • hinisa
                                Xiaomi router freezes at boot after re-capping
                                by hinisa
                                I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                07-08-2023, 05:58 AM
                              • bastien
                                OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                                by bastien
                                It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                                This is the new database for FlexBV
                                it's optimized to work with it
                                by using board ID has Default name, give us the opportunity,
                                to use other diode board data with sibling board or family board
                                I Merged the whole data (optimal)
                                A2991 A2992 M3 -> -> 2 Entries diode data M1
                                A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                                A2442 A2485 A2779...
                                03-18-2025, 08:03 AM
                              • tsavpyn
                                Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                by tsavpyn
                                Dear all,
                                I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                Now I have a problem that I am unable to dump my BIOS into bin file.
                                My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                I searched for FPT but there is no Linux version and none of them work.
                                I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                I would really appreciate it if anyone...
                                05-28-2024, 11:18 PM
                              • mr.malcom
                                HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                by mr.malcom
                                this is a very strange Problem:
                                Notebook hang instantly on Boot. BIOS is accesable.
                                Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                i have tried:
                                - only one RAM Stick, another working RAM, both RAM channel
                                - BIOS Flash to newest Version F.50, BIOS Reset
                                - Memtest86 hang instant at Test 2
                                - HP UEFI Diagnostic wont find...
                                02-26-2022, 05:19 AM
