Use a system image backup on another computer?
+ More Options
Posts
  • caphair
    • Nov 2011
    • 1249
    I've read many articles online on how to make a system image backup using the built in tool in windows 7 but many say I can't restore on another pc with different hardware.
    Yet this is exactly what I need to do. I'm going from a slow old laptop to a much newer faster one. But I have way too many files/programs that would be a pain to reinstall.
    Is this possible? If so could someone give me detailed steps to take to achieve it? Thanks in advance
    • 30952
    Re: Use a system image backup on another computer?
    your in for pain, it wont "just work" for either windows OR linux.
    the main issue is the drivers it will boot with.
    most can be sorted *if* you can see the screen!!
    so the first thing you need to do is change your video-driver/card settings to VESA or Generic.
    or similar wording.
    and drop the resolution to something like 1024x768 with a framerate of 70-something Hz.
    so it's going to run on any hardware - even if it's poor.
    then copy the drive and put it in your new hardware.
    first boot may be a bit tricky, but once your in, you can search new hardware, set your gpu & display res etc.
    • caphair
      • Nov 2011
      • 1249
      or similar wording.
      Anything else to change before trying or just display? I’ve tried booting on the new laptop with the hard drive from older one but it went into trying to repair windows which is eventually failed and wouldn’t let me in
      • Spitz
        • Oct 2010
        • 95
        Originally posted by caphair
        Anything else to change before trying or just display? I've tried booting on the new laptop with the hard drive from older one but it went into trying to repair windows which is eventually failed and wouldn't let me in
        Its the chipset drivers that are usually the issue. If you are going from an intel environment to an amd then it is sure to fail. They are located under system devices in device manager. You can try to uninstall them in the old system and then try to boot in the new system. The problem is it is hard to uninstall them because the system stops working. If you can get rid of the old drivers then windows will start loading new drivers. You can also try changing them to pci standard generic windows drivers and then try to boot in new system. I does not always work.
          • 30952
          or maybe you can fix the install on the new machine with DaRT - but i never tried.
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            I'm surprised about the Linux comment... I can pull a "system disk" out of a *BSD machine and throw it in another machine (same "architecture") and get it to boot pretty easily -- often without resorting to a "GENERIC/INSTALL" kernel.
            Sometimes, there are problems with particular driver incompatibilities -- but, those can be tweeked on the command line at boot time (enable foo; disable baz; etc.). Most of the bootstrap will take place with a generic "vga" video driver so you can watch the drivers loading and see which one is:
            • causing the machine to hang, or
            • causing the video to go wonky
            Reboot (nothing will have been altered on your disk by the failed boot) and enable (or disable) the appropriate driver on the command line (before typing "boot"). Lather, rinse, repeat.
            I probably hand-carry a system disk to a foreign machine at least once a week, this way.
            Windows is far less forgiving. And, stores too much cruft ON the system disk (can you spell "registry"?) even if you choose to install your application on some "non-system" disk (e.g., D: ). So, you can't "fix" the system and leave your apps in place.
            OP should create an image of the disk in question (Clonezilla being easiest approach THAT WON'T TOUCH HIS ORIGINAL). Verify he understands how the image process works by trying to "restore" the image to a "blank" (sacrificial) disk installed in that machine -- verify it works properly.
            Then, screw around with moving the disk (or the copy) to the "new" machine.
            IME, its easier to just reinstall all the apps on the new machine than it is to expect the system to be "stable" when it was built elsewhere.
            [Yes, this is painful. It takes me WEEKS to move apps to a new machine, get licenses updated, set all the options/preferences the way they were, etc. But, the new box is usually pretty stable after having done it "right"!]
              • 30952
              you can move linux around or swap gfx cards,
              but only if your booting to a shell.
              if you try to start the x-server with the wrong driver referenced in xorg.conf it will exit with an error code.
              that's fine, but if your setup boots into X11 then you end up in an init loop with it constantly crashing the x-server and then trying to start it again.
              you have to switch consoles with [crtl][alt]F2 and fix it from the shell.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                ^ Not had that issue. Went from a Poweredge 2900, to an Asus board and NVidia graphics in a custom build, to a T520, to a P52 without the X server ever having issues with the same OpenSuse install.
                Follow the white rabbit.
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  That's the difference, then. I run my *BSD boxes as servers and run X on (diskless!) X Terminals (or X servers under Windows, Slowaris, etc.). In that way, my user experience is largely the same regardless of whether I'm "connected" to a dinky little dual core Atom (with crappy video hardware) or a multicore Xeon.
                  In that way, none of those "clients" need to have ANY user interface hardware installed (keyboard, mouse, display) -- nor the hassle of configuring different X servers on each box -- yet can still be useful.
                  [Learned that lesson running real server hardware and having to put up with crappy LOCAL video hardware]
                  Also makes it considerably easier to cut and past stuff between OS's.
                    • 30952
                    yes, i remember the days when "server" meant you got a videocard with nothing more than a 512k frame buffer on it.
                    i still have one somewhere, i used to strip them for the ram.
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      Most of the boxes I'd seen had on-board video (some low-end radeon). But, the options for upgrading the video (with an add-in card) were limited to PCI or PCI-X.
                      Additionally, fan noise is almost always hellacious so you want to be as far away from the box as possible (e.g., in another room). This just makes a "remote console" all the more appealing.
                      And, of course, there are other boxes that don't have expansion provisions that can play a role in your shop. E.g., I use a little Optiplex FX160 as my DNS, NTPd, xfs, lpd, syslogd, local MX, ftpd (to capture UPS logs), RDBMS, etc. It uses so little power and is so small (USFF) that I can afford to run it 24/7/365 tucked under a dresser (where a monitor and keyboard would take up far too much room). If you're already used to talking to hosts remotely, then there's no issue talking to it using the same mechanisms (its just a wee bit slower owing to its lack of balls)
                        • 30952
                        i like fans - if it sounds like a hovercraft i'm happy.
                        • brethin
                          • Dec 2008
                          • 1907
                          You can download and create system restore for Windows 10, if you want to save your data I suggest you do a BACKUP.
                            • 30952
                            he does not want fucking 10 - nobody does!
                              master hoarder
                              • May 2008
                              • 12170
                              QTF!
                              Sorry for not providing more useful information regarding the original post.
                              I've had some Windows 7 installations work just fine on different hardware and others not work at all. The one that I had most success with was some pre-activated (i.e. probably illegal) copy of Winodws 7 Home Prem. that I found on a used HDD I bought off of Craigslist. I didn't know the HDD was empty, so I plugged it in a Pentium II PC with 256 MB of RAM and off it went to boot and install drivers (took near damn forever, but actually worked ). Then I took the same HDD, just for giggles, and installed onto a different Pentium 4 PC with 1 GB of RAM. It booted again and installed drivers nearly flawlessly. Just had to manually force the VGA drivers. But since this was a 32-bit Windows 7 version (read: no enforced driver signing), I had no problems with that either.
                              • brethin
                                • Dec 2008
                                • 1907
                                600+ Million users would disagree with you.
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  You realize how many people have gonorrhea?
                                  You think it's by choice?
                                    • 30952
                                    lol, but you cant format your bloodstream!
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      And you come to that conclusion how -- because 600M people are using it?
                                      Specious reasoning -- just because you're using something (because you had no other WINDOWS choices when you purchased that NEW computer) doesn't mean you WANT to be running it!
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1865
                                        or similar wording.
                                        Um.... he can image the drive then run Paragon Adaptive Restore after it finishes imaging.
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        Core i5-3470 3.60GHz
                                        16GB DDR3-1600
                                        Samsung SH-224AB DVD-RW
                                        Delux MG760 case
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
