no icons no taskbar on bootup
  • travistee
    • Sep 2008
    • 68
    When I boot up the system I get the choices of users, then it doesn't get past the background image. Nothing else happens. No icons , no start butten, etc.
    However it doesn't happen everytime.
    It was working ok for a few weeks.
    System has XP Home on a disk that was cloned from a Sony Vaio laptop.
    Most of the sony apps were uninstalled.
    A new XP key was used.
    The laptop had SP2, SP3 was installed on this one
    Asus P5K-E
    Asus AIsuite with NOS for overclocking is being used, set to auto.
    Details of what happened:
    1. could not get into administrator account.
    2. got into limited account that was never used before.
    3. tried administrator account again, and got in.
    4. set up a second administrator account.
    5. could not get into all three of them.
    6. tried again and got into the original administrator account.
    7. running anti virus etc.
    8. Also having a problem getting it to boot from the CD. It recognizes the CD
    but doesn't see any files on the CD in explorer.
    I ran some AV/AM but it didn't find anything yet.
    Ran CA, A2free, Adaware, ESET online scanner, spybot
  • Toasty
    • Jul 2007
    • 4171
    Re: no icons no taskbar on bootup
    Turn off AI NOS overclocking, see what happens.
    Turn off any overclocking adjustments in BIOS.
    Does it/Can you get into safe mode?
    veritas odium parit
    • Scenic
      o.O
      • Sep 2007
      • 2642
      if you're on the desktop without icons and stuff, open the taskmanager (ctrl alt del), file -> new task -> explorer [enter]
      you may need to kill the zombie-explorers first.. but this usually works..
      sometimes the explorer just fails to start for no apparent reason, so all you get is an empty desktop without icons & the taskbar.. (works fine when doing it manually like described above though..)
      BTW: reading about all the other bugs, i'd say it's time for a fresh XP install..
      • travistee
        • Sep 2008
        • 68
        Actually it is a fresh xp install.
        It was a repair install over the original which came from the laptop.
        I have the NOS off now. Its all default bios now, except for the boot sequence.
        When I press F8 to try to get into safe mode, I get choices of which disk to boot from but it doesn't go into safe mode.
        What are these zombie explorers?
        Should Av get rid of those.
        So far my AV/AM cant find anything.
        I think this started after I tried to set the audio to analog.
        I disabled HDMI in bios, and reinstalled the sound software.
        My video card has HDMI.
        It was setting the bios back to HDMI enabled by itself, so I left it that way
        and uninstalled the sound software. This didn't help.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          with zombie-explorers i meant the explorer.exe's in the taskmanager which are running, but don't show up (if there are any..)
          edit: when on empty desktop
          • travistee
            • Sep 2008
            • 68
            I think the problem was caused by conflicts with the audio drivers.
            I have a Palit video card that has HDMI, and sound on the mobo.
            The ATI installation for the video card installs its realtek audio drivers which was ok when I used the HDMI.
            When I wanted to change to analog sound and not use the HDMI I installed the soundmax drivers for the mobo.
            That caused the conflict that apparently caused the problem.
            I don't know why it started up properly sometimes.
            It seems ok now.
            • pantherts
              • Mar 2009
              • 73
              travistee, just to let you know, the reason you are getting the F8 boot from device prompt is because Asus has that function key mapped for the boot selection screen on the motherboard. What you have to do if you ever want/need to access Safe Mode in the future is wait until after the main BIOS post screen disappears and then start clicking F8. This will allow the BIOS initialization to do its thing and when you press F8 after this Windows will have taken over and it will prompt you with the Safe Mode options. In short, wait until after the main BIOS screen disappears then start pressing F8.
              • PITERPENY
                iCloud macbook account M1
                by PITERPENY
                I've been wondering for a few days now. Where is the account information stored on a MacBook with an M processor?! Previously, this information was written to the T1, then to the T2. Serial numbers in the EFI chip. I'd like to know how this is implemented on M processors. Is the account on the SSD or on the chips that are on the processor itself?!
                09-29-2024, 07:45 AM
              • reformatt
                Windows 11 Start menu/Taskbar hanging
                by reformatt
                Couple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
                First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade...
                04-23-2024, 10:16 PM
              • alltvrepairs
                QE55Q0TAT BN94-15361X copy account data to hew main board
                by alltvrepairs
                Hi
                Got a new board to repair dead set.
                ​​​​customer had some paid accounts that wants to reuse from old board as he has no more access to the original email account for some iptv and other services like Disney etc. Are these stored in spi flash?
                I guess they are in a Samsung account storage area.
                Tks
                02-22-2024, 11:31 AM
              • webhost
                Google account asus chrombook C214MA-BU0769
                by webhost
                Hello Guys
                Can You help me to remove google account on this bios
                Asus Chromebook
                Motherboard : C21MA MAIN BOARD R2.4 PCB MADE IN CHINA
                model : C214MA-BU0769
                SN : NBNXCV03S54545A
                CN : LZC6
                MFD: 2022-11
                thank You in advance...
                04-08-2025, 03:22 AM
              • red4
                How can i modify microsoft account login on install
                by red4
                I have a problem, I would like to modify the logo and the text of the connection to the Microsoft account during the installation, is this possible? if yes , whats is the way i should follow? this would be done as in the attached image
                https://ibb.co/hsGhQWg
                Thanks to the person who gonna help me
                Ps: Sorry for my english
                10-26-2023, 02:44 AM
