Need a BartPE w/ virus scanner
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    I need a bartPE disk with a virus scanner on it for a laptop that has a virus that crashes everytime a virus scanner finds it.
  • Harvey
    • Apr 2007
    • 264
    Re: Need a BartPE w/ virus scanner
    Ultimate Boot CD for Windows http://www.ubcd4win.com/index.htm
    Includes
    AntiVirus Tools
    AVG Free 7.5.503 Excellent full featured freeware AntiVirus software
    AVPersonal 7.04 Good full featured freeware AntiVirus software
    Avast! Tool 1.0.211 Scans for a limited number of viruses
    Kaspersky VRT Free virus Removal Tool from Kaspersky
    McAfee Stinger 2.6.0 Scans for a limited number of viruses Applications
    • Toasty
      • Jul 2007
      • 4171
      Sounds like memory is infected with virus...
      Hiren's Boot CD 9.6, 9.7 or 9.8 - ClamWin AV free GNU license
      HawkPE-42 - ClamWin or McA...
      or
      Avast! will do a boot time scan once installed.
      I'd download and run ComboFix from a Flash drive in Safe Mode before the others.
      Happy hunting!
      Toast
      veritas odium parit
      • bgavin
        • Jan 2007
        • 1355
        Link to Avira
        This one is a Linux kernel with scanner.
        It also detects root kits.
        The CD image is updated constantly.
        • waigy
          What are these components that detect paper in a fax scanner
          by waigy
          PROBLEM SOLVED
          I DIDN'T REALISE MY SMALLEST SOLDERING TIP COULD JUST FIT BETWEEN THESE COMPONENTS.
          I MANAGED TO REMOVE THEM WITH NO DAMAGE TO THE BOARD AND I HAVE MY INTENDED END RESULT.
          On a Possio PM70 portable fax machine which has a scanner that detects when you push a piece of paper into the scanner slot.
          It is these two small (3mm long) components that detect the paper and start the scanner feed motor which pulls the paper into the scanner.
          (These are on the circuit board for the keypad and not the main board)
          I want to disable these as...
          05-21-2023, 12:50 AM
        • CapLeaker
          Bearcat 300 scanner no display, has audio and squelch repair
          by CapLeaker
          I found an old Bearcat 300 scanner that had no display, but the audio and squelch worked, over at my workplace. This unit has a lot of hours on it. It had some capacitor replacements and other mods done to it too before I found it. To troubleshoot this problem, the usual is to check the +25v and -30V and replace C98 on the main board. That should fix it. There is also a case of a shorted button board (just unplug that ribbon cable and the display should work again). Spoiler alert! Was not the case on this one.
          My display didn't work, because I had a missing -10V on the display...
          09-09-2024, 10:24 AM
        • mon2
          Hunting down a virus in an office
          by mon2
          Hi. We have an office client who has been contacted by the local internet provider that one of the office Windows PCs is infected with a virus. The report has been confirmed. Apparently through a remote outside trigger, this virus is performing brute force attacks around the world from this local IP address at varying times. Aside from low level formatting each PC, what is the recommended approach for this case? Running F-prot (suggested by the internet supplier) has come up empty. We are planning to run hijack this. At this time, we do not know which PC is creating this issue. Internet provider...
          01-09-2025, 09:42 PM
        • SoporteHR
          DesignJet T1200 MFP scanner (CQ653A). It restarts after minutes of having turned on.
          by SoporteHR
          Good morning to all the presents.
          Receive a warm greeting.
          I commented and consulted the following (Electronic Technical Level), since doing a search for the team model (CQ653) I did not find anything that references the problem I have.
          Equipment: HP DesignJet T1200 MFP. CQ653A. Scanner Module.
          History of the device:
          The user of the equipment had problems with the lamp, due to this, he proceeded to replace it, but he said that the bulb was damaged, he replaced it and when he turned on the equipment, there was a short circuit...
          12-04-2018, 08:25 AM
        • fricosu007
          OBD Scanner Autel AL539 burnt rezistors
          by fricosu007
          Could someone help me identify the two rezistors burnt inside this AL539 device from Autel, i cannot find any dissembly pictures and there are a lot of these devices, i hope some of you have it 🙌
          https://imgur.com/a/b9fGGGk...
          09-22-2025, 10:58 PM
