As the thread title suggests, this thread is about posting mods that you have done to your GPUs / video cards in order to improve their cooling. This could be anything, such as a simple modded VGA BIOS and/or heatsink replacement, to more intricate works like liquid cooling systems, special voltage mods, and etc.
The only reason I decided to make this into a separate thread rather than continue posting in the Ghetto Mod thread is that here, you can post *any* GPU cooler mods and not just necessarily “ghetto” ones. Also, this way, it should be easier to find the mods in case anyone else wants to try them or wants to get ideas on how to improve GPU cooling in general.
In my opinion, a lot of graphics card failures can be prevented if the temperature is kept lower. Generally, I try to keep things under 60°C whenever possible (and for some cards even lower, if known to have more issues). This applies even more to problematic GPU and chipset series, such as nVidia GeForce 6, 7, and 8 for example. After all, enough of us have seen those GeForce 6150/6200 chipsets fail to agree that improved cooling can help things.
That being said, I will start with one of my home-brew coolers that I made for an ASUS Radeon 9200 SE (“slow edition” … I know, don’t laugh!) 64 MB AGP video card. Here is how the card looked originally:
https://www.badcaps.net/forum/attach...1&d=1530570530
This video card was in my first own gaming computer back in the early 2000’s, and hence I have a bit of a sentimental attachment to it. Therefore, I wanted to make sure it’s cooled well, even though it is a Radeon R200 series-based (RV280) video card, and these just don’t suffer from failures and artifacts (mostly due to the GPU being an oldschool wire-bond chip.) Nevertheless, the card’s stock cooler would always get pretty much scorching hot during gaming, so I always had an 80 mm fan running and pointed at it back in the day. But since I have so many Xbox 360 CPU and GPU heatsinks that I have no particular use for, I figured this trusty old video card could get a slight upgrade. Why not, right?
So here’s the result of that:
The new heatsink fit like a glove. I just needed to make minor cuts in two of the corners in order to get around various components on the board. Other than that, there wasn’t much else to this mod. Like many of the early Radeon video cards, screw distance is standard 55 mm diagonally for this card and only 2 screws hold the cooler. Speaking of which, here is what was under the original one:
ASUS didn’t use much thermal compound and it was the cheap white stuff. Surprisingly, though, it was still all very moist. I guess my early cooling mod with the 80 mm fan back in the days has paid off.
With the new heatsink I made above, the video card will still get pretty toasty without any fans or other active cooling, but not as much as with the stock cooler, thanks to the largely increased surface area. And adding even a slow-turning 80 mm fan running at 5V is enough to keep it cool.
Unfortunately, this video card is too old to have any temperature monitoring, so I couldn’t probe how much cooler it is running than before (Normally, I like to make temperature graphs of before and after). But if I had to guess, the original heatsink would probably run around 50-60°C under full load. With the modded Xbox 360 GPU rev 2 heatsink above, I don’t think the card goes above 50-55°C without active cooling, based on touch. Of course, the room temperature can affect those readings quite a bit too. But I did my tests in the same day with same room temperature, which was around 22°C / 73-74°F that day.
Also, here’s a GPU-Z screenshot, just because I always like to include it:
And that’s all I got for this one. More mods to come later – I have made a pretty big library of my mods, with pictures and whatnot. Actually, this has turned into sort of a hobby for me – video card cooler modding – if there is even such a thing, lol. But I do know that member ChaosLegionnaire is the other person here who likes doing this stuff too and we frequently correspond to each other about it over PMs. So let’s see if there are more of you out there that like doing this.
(And if the thread goes popular enough, maybe we can sticky-it. )
 … I know, don’t laugh!) 64 MB AGP video card. Here is how the card looked originally:https://www.badcaps.net/forum/attach...1&d=1530570530
						 Your Video Card Cooling Mods
		 ), I'm pretty sure you won't have problems with that.
  As usual, I took off the old cooler and measured the screw distance. It is 55 mm diagonally, which is a bit unusual for nVidia (normally they use 80 mm diagonal 2-screw pattern on older cards.) Speaking of which, here is the old cooler on the bottom side:
  i was using it in a horizontal atx case and there was a ventilation vent on the side near the leftmost pci slot. so i put a thermaltake 80mm smart case fan there and it brought the temperatures down a lot but it also brought with it a lot of noise because it was a 4800rpm fan!
 i was using it in a horizontal atx case and there was a ventilation vent on the side near the leftmost pci slot. so i put a thermaltake 80mm smart case fan there and it brought the temperatures down a lot but it also brought with it a lot of noise because it was a 4800rpm fan! ). So we will see how long (or not) they will last (or not x2
 with the fan at 7v and with an ambient temp of 30°C, the idle temp was 38°C. at max load during gaming, the temps reached 51°C. excellent temps i must say!
 with the fan at 7v and with an ambient temp of 30°C, the idle temp was 38°C. at max load during gaming, the temps reached 51°C. excellent temps i must say! so that was a pretty fun exercise converting much hated by me passive heatsinks into active ones.
		 - that's with the fan barely turning too.
