Recommendations: Portable laptop/tablet for texas hot auto shop environment
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    These guys use laptops for the DVS (they have one USB and one wifi diagnostic)
    This Toshiba (CL15) has pretty much had it. I opened it up. Non-upgradable memory or SSD (all soldered). Also...the battery cells have began to expand a bit severely decreasing the battery life (this is due to heat).
    Sooo, anyone know a good, decently affordable solution? I was thinking maybe a Surface Pro 3 with a $69 rugged case, but that still might not solve the heat problem.
    Maybe one of those Core-2 dells from back when that they still make cheap generic batteries for and still have parts on ebay. The fact it's win7 would be a big plus
    Overall something win7 would be a big plus cause without the CSM I can't put it on this CL15.
    probably a new policy of bringing them in after the work day would help, but it can't help the 9-5 heat of that garage
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Recommendations: Portable laptop/tablet for texas hot auto shop environment
    Trusty Dell Precision m6300. Magnesium body can take a beating, big screen which is great for auto diagnostics, replacememt batts are all over the place and cheap....and they love win7. They're a Core2 platform, up to 8gb ram...I don't see that being inadequate. They're cheap on ebay. I put one together for my machine shop owner. Hot abusive environment, hes been using it 4 years without issues.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      fascinating. I think one with a small 128GB Samsung SSD might be the best bet. I'll see what others have to say
      hah but you live in Missouri, this is Texas. 100+F. Gets hot as fuck in there. They just need to learn to put them in the parts room when they're done
      how can it be 8GB, it's ddr2, is there four slots?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        No, just 2 slots. There are 4gb soDIMM's....pricey, but they're out there.
        We get ~100* heat in july & august, but usually in shorter snaps. mid-90's is the average.
        *edit*
        https://www.ebay.com/itm/362327211882
        The price has dropped a little....these used to be ~$100 for a pair.
        Team : 49813
        Join in!!
        Team Stats
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          oh thats right, only supported by some chipsets/cpus (AMD, that has the IMC in the cpu).
          naw. Even 2GB with win7 32 is just fine. These guys are just going to use the VDS program and firefox to look up the codes on the wiki if needed. With the added speed of a SSD, it should be no problem. Hm maybe 3GB
            • 31199
            cant you fit the end of the work-area with a few centrifugal blowers??
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              They have massive fans, still hot as balls
                • 31199
                maybe a double-roof, a trick used on buses & trucks.
                in africa they put a second roof above the first on legs about 12 inches long - the air-gap stops most of the heat from the sun cooking the bus.
                • brethin
                  • Dec 2008
                  • 1907
                  I have 2 of these I could part with if your interested.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    These guys have been there 48 years. Theres no building anything on the current structure
                    brethin if they're in a good condition I might take you up on your offer. Right now I need to consult them to see if a laptop that large would be an issue (most of the current ones they have are pretty small...11-13" screens that are very light
                    • dmill89
                      • Dec 2011
                      • 2534
                      If you need somewhat rugged an older Dell Precision (as TopCat suggested) or Latitude (the higher end ones with the magnesium bodies) or Lenovo T/R series Thinkpad (T430/530 and older) will do and they can be found fairly cheaply. If you need truly rugged there is always the Panasonic Toughbook, newer (anything core-Ix) ones tend to be fairly expensive (at least by used laptop standards, Sandybridge/Ivybridge ones are still generally in the $400-600 range), but if you can get by with something older the Core2Duo ones are fairly cheap ($100-$200 sometimes less).
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        If you can find one rugged enough (add a case?), I'd look at newer atom tablets (bay trail or newer). No fans, no moving parts, and even the cheap ones have plenty of power. Heck, my Asus Transformer T200TA does circles around my older workstations (not the newer ones, but still, for a 12" tablet... ). Used ones can be found for pretty cheap...
                        sigpic
                        (Insert witty quote here)
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          Rat can the battery easily be replaced?
                          Do you think it's possible to put windows 7 on it? I doubt there is a CSM for w7
                          • brethin
                            • Dec 2008
                            • 1907
                            Ok not a problem yes they are both like new, one has a port station dock and the other has a full docking station. I can take some pics and give you specs if they will work for you. just let me know.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Some are easier than others.
                              Windows 8.1 or 10 won't do? My t200ta has 8.1, which easily mods to act like 7.
                              sigpic
                                master hoarder
                                • May 2008
                                • 12175
                                Doesn't matter. These older Dell Precision laptops are built like tanks and will work fine even in very hot environments. So I second what Topcat said.
                                Also, the Dell Latitude E-seires are also extremely reliable - just avoid the ones with nVidia graphics chips. The ones with Intel IGPs are bullet-proof as well. Will run Windows 7 wonderfully with 2-4 GB of RAM. Some of the newer E-series also come with Core i3 and i5 CPUs.
                                There are really the only laptops I consider reliable, along with the Latitude D-series, and maybe certain older Lenovo laptops (again, from the Core 2 Duo era). Everything else is just consumer trash.
                                Nah, tablets are just toys for little kids. No moving parts, but also lots of non-replaceable parts. And limited expansion ports too.
                                • desert-rat
                                  • Mar 2014
                                  • 4103
                                  Yea TX gets warm its AZ that gets hot.
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    Move the "sensitive" parts out of the heat. Is there someplace, anyplace, in the facility that is suitable for human habitation? (even if swamp cooled)
                                    If so, put the "compute" power there and just run a remote display out into the inferno. Presumably, mains power is available so why screw with batteries that will eventually fail? And, something that is JUST acting as a display will have much reduced power requirements (as it's just painting images around on a screen THAT SOMETHING ELSE HAS CREATED... in the habitable portion of the facility).
                                    This is how I address my computing needs in the garage, front/back porches and even on the roof! (Hint: it's already approached 110F, here)
                                    • brethin
                                      • Dec 2008
                                      • 1907
                                      Actually I have 3 of these available, I forgot I had one in my closet, all 3 like new. 2 dockng stations and a port station, 1 external floppy. 2 have widows 10 pro and the other windows 7 ultimate. $400 for it all free shipping.
                                      • desert-rat
                                        • Mar 2014
                                        • 4103
                                        I dont know if this would work for you but they make portable evap coolers . You either pore water in them or hoook them to a hose .
                                          HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 07:10 AM
                                          HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet boardview and Elite x2 1012 G2 Tablet schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 06:30 AM
                                          09-06-2024, 06:10 AM
                                          09-06-2024, 05:46 AM
