Dell Zino
  • Onerous
    • Aug 2013
    • 6
    • United Kingdon
    Dell Zino
    Has anyone had one?
    Has anyone had the orange light of doom and repaired the Zino?
    Have a zino 400hd, that was set up as my media server. Sometimes used to take a few unplugs and replugs to start, now nothing but the white to amber light.
    Any ideas where to look. Can't see anything damaged on the motherboard. Have replaced the power supply and both work. Resoldered the power jack to the motherboard and worked once.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • expertreader
    Dell 5520 not booting up - on light comes on momentarily
    by expertreader
    Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
    Hi all, looking for some help to get started on troubleshooting without schematics
    I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
    I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
    • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
    • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
    • i have measured 16.5V available at the capacitor
    10-19-2025, 08:20 PM
  • multimesut
    Dell 2007FPB Yellow Light Problem
    by multimesut
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
    11-13-2024, 07:00 AM
  • zwect
    Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
    by zwect
    I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
    Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
    Here is the original BIOS dump from the 25R256JVEN chip.
    09-11-2024, 05:54 PM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
