power consumption?
  • ivtec
    • Dec 2008
    • 1967
    power consumption?
    Hi guys:i bring up this topic because i came across a forum that discussed the power consumption of Satellite Receivers on Standby,and somebody there said that the receivers consume as much power if receiver stays on standby as it consumes when turned on.So i went ahead did some calculations on my 322 receive,and came up with these numbers,i may be wrong on my calculations correct me if I'm wrong!.
    With my Fluke 87 measured 0.236miliamps turned on,and 0,226
    in standby,
    on standby 120v/0.226=530 Ohms,120x120=14.400/530=0.027watts.
    turned on 120v/0.236=508 ohms,120x120=14.400/508=0.028watts.
    i don't know if these #s are correct, but if they are than the power consumption is very low and is not that bad,if not than this receivers are not green at all,because no matter what kind of equipment they shouldn't waist as much energy on standby as in on mode.So anybody here is an expert enough to refute my numbers?
  • Wizard
    • Mar 2008
    • 2296
    Re: power consumption?
    .226A means milliamps and you multiply by volts to get VA power not divided since this is AC not DC.
    http://en.wikipedia.org/wiki/Volt-ampere
    226mA x 120VAC = 27.1 VA (watts)
    236mA x 120VAC = 28.3 VA (watts)
    So you are only have 1.2W difference. Meant this box is not in true standby, just active to keep catalog updated by downloading and checking via cable.
    These guys are right this seems to be.
    Cheers, Wizard
    • Gianni
      • Jul 2008
      • 681
      • Italy
      I have not tested SAT receiver but DVBT Receiver and I saw that they consume the same power in Stand-by and when they are working (~10W). I did the test in my office with a PFC meter.
      I think these Boxes (SAT - DVBT) just cut the video output while they are in stand-by... but anything else is working for the reason explained by Wizard.
      ivtec I think you have to multiply the result 236mA x 120VAC = 28.3 VA for a coefficient of 0.63, so the active power is ~18W.
      0.63 is the typical power factor value for PSU that have not PFC and 18W seems to me a more realistic value for a SAT Receiver.
      Ciao
      Gianni
      "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
      H. J. Brown
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Joe24
        2070 Super with crazy power consumption numbers
        by Joe24
        Have a Gigabyte 2070 Super with some bonkers power draw readings. Card runs fine, other than some GPU throttling because of the power numbers. But GPU power always reads too high, more than the power reading for the entire card. And VRAM power always reads way too low, along with PCIe and 6-pin power readings. The 8-pin reading seems plausible.
        Typical readout while running 720p Furmark, 8x AA:
        GPU clock: 1590 MHz
        Mem clock: 1750 MHz
        GPU temp: 58.8 °C
        Hot spot: 71.8 °C
        Fan speed: 33% / 1000 rpm
        Mem used: 454 MB
        GPU load: 97%
        02-03-2023, 02:07 AM
        03-31-2024, 02:12 PM
      • SkishyIshy
        Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
        by SkishyIshy
        Hey All,
        I have a Sony 65x900f that I purchased cheap because of a no-power issue.
        I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
        I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
        03-17-2021, 11:44 AM
      • AleMonti
        LG 55EG910V - no power and no standby light
        by AleMonti
        I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
        I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
        The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
        After checking the basics I did the following:
        • I measured all voltages and as expected the only active supply is the 3.5V standby. It
        11-04-2024, 05:02 PM
