VMware ESXi
  • bgavin
    • Jan 2007
    • 1355
    VMware ESXi
    VMware is giving this away for free now. This is the Hypervisor (HAL) that does virtualization.
    It is a command line interface, etc, but the price is right. ESX/ESXi is the faster version than VMware Server, because there is no host OS.
    I'm curious if anybody is playing with this yet.
  • Gibon378
    What caused the BSOD?
    by Gibon378
    Hello there!
    I was doing some usual stuff, browsing the internet, listening to music, coding, etc. and my computer froze. It looked like the website couldn't process the request (logging into the account, there was the loading symbol) and it took a few seconds, then my computer totally froze except for the mouse cursor. It lasted for about a minute and I got the BSOD. It happened yesterday and today (just now).
    I managed to get the MEMORY.DMP content, but I don't really understand it. Could somebody help me?
    Code:
    ************* Preparing the environment for Debugger
    06-23-2023, 06:20 AM
  • harp
    command to run Fn + [left arrow]
    by harp
    I look to find some simple solution to execute Fn+left arrow once at winxp startup... It might be some simple specific command aplication, or batch script, or some C code (I have C compiler, but thats it)... can anyone help with idea or solution? On internet can find some sofisticated programs that can do such things and much more, but I not interested to load it to system for that.... ... ... If you interested in what is purpose... I have some bug or so on my laptop, and on every shutdown reset backlight to maximum, just flash one moment before go off... on next boot backlights is stuck to...
    07-13-2025, 03:39 PM
    MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
    Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
    The nonvolatile...
    10-07-2024, 04:55 AM
  • klugec
    KVA2 RTX 2060 Super 8GB Desktop artifacts
    by klugec
    Hello (sorry for my bad English),
    I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
    Mods shows me the following error:
    Code:
    MODS start: Thu Feb  1 19:16:00 2024
    Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
    02-01-2024, 10:58 PM
  • ruletero
    Acer a515-43 low battery charge voltage
    by ruletero
    Hi
    Acer A515-43
    LA-H801P
    Fail: Does not charge battery, has low voltaje on connector.
    Laptop didn't want to turn on, only charge led blinked.
    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
    10-24-2022, 02:31 PM
