Thermal compounds / pads and thermal conductivity.
    master hoarder
    • May 2008
    • 12175
    #41
    Re: Thermal compounds / pads and thermal conductivity.
    Originally posted by Spork Schivago
    The RAM is directly to the right of the CPU. The RAM is so close to the CPU. The CPU heatsink can physically only be mounted one of two ways, but the way it's designed, changing the way the heatsink is mounted doesn't affect anything.
    The fan can only mount on the heatsink on one of two sides. Either the side closest to the power supply, or the side further from the power supply. It cannot be on the side of the heatsink. So we cannot put it opposite side of the RAM. Regardless of where the heatsink fan is attached, the right hand side of the fan always rests on the two slots.
    Ah, I see the picture now.
    The fact that it is an AMD board is part of the reason why, as the CPU heatsink can only be oriented to pull or push air up. So I see why that's a problem now. We had problems like that we a few new Ryzen boards in the last place I worked. It wasn't until Cooler Master released a proper bracket that allowed us to flip the whole heatsink 90° so that we could avoid this problem. So before then, we also often encountered the same problem as you.
    Yup, nothing you can do about it.
    Hopefully, the PSU has a 120/140 mm fan so you can point the CPU heatsink fan to exhaust the hot air through the PSU. Not the best solution, but it should keep the heat out of the case. If the PSU is a good brand, it should take it without any problems.
    APUs aren't really associated with gaming PCs to my knowledge. In fact, I think it's quite the opposite, isn't it? Aren't they generally for low-end systems that are made to surf the net, check e-mails, watch youtube videos and are usually found in tablets and similar devices?
    Not exactly.
    AMD's hope with those APUs at the time was to bring affordable gaming PCs with decent 1080p performance in already released game titles. And for the most part, those APUs did that fairly well, managing 30-40 FPS at 1080p, medium-high settings. Of course when the newer generation of games came out, these APUs could not quite keep up with them.
    So those APUs are good for playing games that came before or right around the same time as the APUs themselves. But any games released after them may not play that well.
    That said, modern high-end CPU and discrete GPU will no-doubt mop the floor with an APU like that. But again, for what it's worth, those APUs did fairly well.
    The PSU needs to be replaced. I tried telling him that. It's going to destroy the motherboard and probably a bunch of other stuff along with it. He won't, not until his PC doesn't start anymore. But by then, it'll be too late, the damage will be done.
    So scratch out what I said above about the CPU fan exhausting hot air into the PSU.
    That said, what brand is the PSU?
    He saw the numbers of cores and the speed of the process, the amount of RAM it had and made an impulse buy without properly doing his research.
    You don't need a very fast CPU these days for gaming. Even a mid-range i5 will be more than enough to run anything with very good frame rates. The GPU pretty much takes care of all that. Slap a GTX 1060/1070/1080 in that PC, and I bet it will fly in games again... though I don't really suggest you do that now if the PSU is some no-name crap. If it is, it might take a 1050 at best, and that's not exactly a high-end gaming video card (though still adequate for a lot of stuff).
    He takes cell phones and tries to root them and put custom firmware on them, and then when he bricks them, he brings them to me. I don't mind helping people, but I haven't been charging him. His girl lost her job or something and they're struggling for money, but how many times do you have to burn your hand on the stove before you learn not to touch the stove, right?
    Yeah, I know that situation.
    You are doing good in helping him - really shows that you are a nice person. That said, be careful, as some people will use that to take advantage of you. When they do, it's time to tell them what's what. And if they complain that you are overreacting or something... that's their problem.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      #42
      ooops i went awol for a few weeks and missed the funn topics on this forum.
      spork, glad u realised the issue wasnt the cpu to heatsink mating surface. in which case changing even to a super heat conductive compound with instant heat conduction (peltier thermoelectric coolers come to mind) wouldnt work either. the problem wasnt at that interface. rather the issue was the heatsink's surface area was inadequate for the tdp required. in which case, upgrading to a bigger heatsink with a bigger heat dissipation surface area is the only solution.
      however, there is a third option which i wanna mention, that is to upgrade to a more powerful fan with better airflow/static pressure. however, that comes at the cost of more noise. if u have sound/noise sensitive (hyperacusis or misophonia) room mates or family members, it rules that out. however, like what momaka said with the thermal paste, a more powerful fan only results in a few degrees lower temperature. that may or may not improve the temperature below the critical threshold.
      i also noticed, this heatsink also allows adding a second fan for push-pull config. i also wanna state for clarity's sake that only results in a few degrees of difference. again, it may or may not improve the temperature below the critical threshold.
      so i hope that answers the question on ways to improve the cooling of a heatsink without replacing the heatsink itself.
      next, regarding the kind of heatsinks u should and shouldnt buy. firstly, i wanna talk about the three reasons why people use aftermarket heatsinks:
      1. u want to overclock
      2. u want silence (much more than the stock heatsink)
      3. u just have too much money to throw around
      there are some heatsinks out there that cater to point #2 but the flip side is that some of them tradeoff cooling performance for silence so if your hardware is overheating obviously u cant have silence. u just have to avoid heatsinks that cater to #2 and just suck it with a noisier/bulkier heatsink or downgrade/undervolt/underclock the hardware to something that runs cooler.
      dont be type #3 that wastes money on an aftermarket heatsink just for the fock of it. the extra money spent on an aftermarket heatsink might just get u better hardware instead. in which case, thats why u do your own research first before buying! any proper and decent aftermarket heatsink review should have the stock heatsink as the reference point. so ppl know why they should buy this heatsink and why they should use it over the stock heatsink.
      • Spork Schivago
        • Mar 2012
        • 4734
        • United States of America
        #43
        Unfortunately, there just weren't any optimal way of doing this, without replacing parts. I went with pushing the hot air through the PSU fan. If I went the other way, the PSU fan would be trying to pull the air from the CPU, the CPU would be trying to pull the air away from the PSU. It's soooo cramped.
        With AMD and these APUs, even if at the time, they could play games on good settings, I don't think anyone can call an APU a gaming processor today. Generally though, the video card tends to do most of the processing. I would think if someone was into video games, a lot I mean, like this guy seems to be, they would be using an add-on video card, running on the PCIe bus at 16x. When games require more processing power, they simply upgrade the video card.
        I just would not consider this system a gaming PC at all. 300$ is what he bought it for. The person who built it, we can assume they paid less than 300$ to build it. I'm thinking maybe 150$ - 200$.
        Some people just see the numbers of cores and the speed of a processor and go nuts! They don't understand things like bottle necks and how a computer actually works. This customer, first thing he did, was max out the APU. Why? Because it was sooooo slow! He kept saying he couldn't understand why it was soooooo slow, it had 12 cores! I said no, some of them are just for the built-in GPU that's in the APU.
        Hard drive was utilizing a lot of processing power. I think the APU couldn't communicate with everything at the same time. With Intel processors, I'd say the CPU has 40 PCIe lanes, for example. I don't know if they're called the same with AMD. But I think his APU just doesn't have enough lanes. So it needs to talk to this hardware for a bit, pause, talk to that hardware for a bit, pause, go back, etc.
        -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
        • Spork Schivago
          • Mar 2012
          • 4734
          #44
          Wow! Does the push-pull configuration really only cool down the system by a few degrees compared to a regular fan setup? With my other friends PC, we set up a push / pull configuration on the radiator and got some insane speeds, like over 4,000RPMs (compared to something like 1,500RPM or 2,000 RPM).
          For the after market CPUs, that's what I was trying to get to. A stock heatsink should cool the CPU, I would think, just fine, unless of course, you're doing something like overclocking it. With that said, I mean if the system was built properly. Obviously, if you're getting no air flow into the case, you're going to have issues.
          I noticed another reason people buy after-market fans. The look. Some people seem to like to show off their cases. Most, if not all, of the people I know locally who are into PCs are into for gaming, so maybe this is just a gaming thing? They have what we used to call back in the 90's, LAN parties. Not sure what they call them now. But you bring your PC to a party, where there's a bunch of other people, who brought theirs, and you play video games multi-player. Last game I did that with was a game called Descent. That was fun.
          There is room in this case for another fan. A case fan. Which would help. I'm pretty sure the customer was using the on-board video card (because he had the APU). I don't think he was using an external video card. An external video card could help, but couldn't it also make the system slower?
          Because it'd end up using x amount of lanes that go to the CPU, right? I don't have a strong understanding of that, just a semi-basic understanding.
          Thanks!
            master hoarder
            • May 2008
            • 12175
            #45
            It depends. (ain't that always the answer. )
            There are three types of gamers: casual, retro, and "hardcore" (the ones which play all the latest games and are seriously into gaming in general).
            The first two don't need the latest or greatest hardware.
            Indeed that is the better way to do it.
            I doubt the PC was slow because of the AMD APU. I build a few of these, and they performed quite well. It's all down to the OS and junkware that the user puts on there. I have computers that are museum pieces and even some of them perform faster than the new multi-core PCs simply because I keep them well maintained.
            Either you are dealing with a HDD that is slow, going bad, or bogged down with crapware.... or all there (I've seen that, and it's usually ridiculous to work on something like that). Just have him put in a better video card when he gets a better PSU and that should get him up to date. A GTX1050 is a good starting point as a low-mid-range video card, with the GTX1060 a very decent mid-range.
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3264
              • Singapore
              #46
              this was from reviews i read on heatsinks that allow push-pull config but come with only 1 fan. when the reviewers added a second fan, it only dropped temperatures by a few degrees.
              however, they didnt use a jet engine type of really high rpm, loud fan. i once had a coolermaster hyper 212 and i changed the stock fan of 1500rpm or so (cant remember the exact rpm of it anymore since i sold the whole heatsink and fan off) with a scythe ultra kaze 3000rpm 120x38mm fan. it only dropped temperatures by a few degrees.
              the only exception i found are the heatsinks for some high end i7 intel cpus. the 4790k was infamous for overheating to 80-90°C even on the stock cooler. the culprit was crappy tim under the cpu heatspreader by intel. intel also uses shitty push-pin mounting for their heatsinks. it warps the board over time and kills the cpu socket bga.
              so i guess the fourth reason u want an aftermarket heatsink with a backplate and is simple to mount is because u want the mobo to last!
              I don't think he was using an external video card. An external video card could help, but couldn't it also make the system slower? Because it'd end up using x amount of lanes that go to the CPU, right?
              it doesnt work like that. im not sure if the igpu in the cpu itself also uses up pci-e lanes but like momaka said, even if the discrete gpu does, the bottleneck would still be elsewhere like the hard drive or software side. a computer system is only as strong as its weakest link, which is why m$ bases its overall system score on the lowest sub-score.
              if the discrete gpu takes up 16 lanes out of 40, there would still be 24 remaining. and im assuming its pci-e gen3? which still gives tens of gigabytes per sec of system bus bandwidth remaining. the math theory seems to indicate that it is highly improbable adding a discrete gpu would slow the system down. that would also be a self defeating prophecy in upgrading to better hardware, no?
                MSI Trident 3 Arctic 9SI-618EU Trident 3 Arctic i7-9700F Specification for Upgrade or Repair
                This specification for the MSI Trident 3 Arctic 9SI-618EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 9SI-618EU boardview and Trident 3 Arctic 9SI-618EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 03:28 PM
              • Gcnewbie
                Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                by Gcnewbie
                Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                I opened the...
                03-29-2024, 06:55 AM
              • Veyron7887
                Laptop overheating after replacement thermal paste
                by Veyron7887
                Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                11-24-2024, 05:08 AM
                MSI Trident 3 Arctic 8RB-092UK Trident i5-8400 Specification for Upgrade or Repair
                This specification for the MSI Trident 3 Arctic 8RB-092UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 8RB-092UK boardview and Trident 3 Arctic 8RB-092UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                MSI Trident 3 Arctic VR7RC-281 Trident i5-7400 Specification for Upgrade or Repair
                This specification for the MSI Trident 3 Arctic VR7RC-281 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic VR7RC-281 boardview and Trident 3 Arctic VR7RC-281 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
