Award BIOS Settings Backup?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, I've tried to find programs that allow me to save the current BIOS settings I've setup into a file so they can be restored if the BIOS gets cleared
    I have been unable to find any such utils (some very recent mobos have the options in the BIOS tho, like my Maximus Formula)
    But is it not possible to edit what setting get used when the "load optimized defaults" is selected in the BIOS?
    I had a look with MODBIN6 but could not find the option to do it tho
    The mobo in question is an old Epox 8RDA3+ with Award BIOS v6.00PG
  • gustie
    • Dec 2008
    • 76
    Re: Award BIOS Settings Backup?
    sounds like you want genie bios like on DFI boards - you can save four different profiles for different settings - i think other board vendors should do this...
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
    • bgavin
      • Jan 2007
      • 1355
      I use MODBIN6 to configure the Optimal and Safe settings on client BIOS for KG7-era boards. I've not done this with current boards, due to fear of MODBIN6 not knowing how to handle current BIOS. It has been a long time...
      The editing process is somewhat tedious, but self-explanatory as you go through each settings. You *must* do this in a pure MS-DOS environment and FAT32 hard disk. When you are all done, you save to a .BIN file that you can load (flash) into the BIOS. IIRC, it creates a copy on the hard disk, then reloads it back to the chip.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Oh ok, I'll have to have another look then
        Guess I just missed where to do it...
        Thnx
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Ahh yea, now I get how it works
          Mobo modded fine, I changed all the values under "SETUP DEFAULT" in MODBIN6 to my liking
          It works great!
          And on second notice it helped a bit to swap the 3v Lithium battery on the mobo too, it was completely dead
          Ahh well, more beer, yes please
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • Conste
            Clevo W25CEW doesn't save Bios settings / shutdown issue
            by Conste
            Hello together,
            I have a Clevo W25CEW (Terra 1541) with some strange symptoms:
            1. I cannot save Bios settings by pressing "save settings" in the bios. By pressing "save & exit" it will save the settings.
            2. I can boot normally (UEFI installation), but when I shut the machine down and start it after a few seconds again it will show resume from hibernation and shutdown after POST, just before windows would boot. Then it will go back to factory settings and my UEFI installation will not boot!
            Already changed the CMOS battery...
            09-01-2021, 10:34 AM
          • YG007
            Asus BIOS How To Reset To Default Settings?
            by YG007
            Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
            I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
            06-05-2023, 08:22 PM
          • DiddiAb
            BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
            by DiddiAb
            Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
            I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
            03-11-2023, 03:15 AM
          • Chris_stand
            Clevo PD50PNN won't boot after BIOS Backup
            by Chris_stand
            i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
            At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
            Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
            But the...
            04-28-2023, 03:08 PM
