Startup chime
Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?06-14-2023, 11:45 AM
by valvashonYet another 19" TV here in the maintenance shop. This one belongs to my 95 year old mom so I'd really like to get it fixed for her.
Samsung UN19F4000AF. Back home for a week, I found this TV in her master bathroom unplugged and not connected to anything. Would start to power up and make about half of the Samsung startup chime, then shut back down.
Brought it back home with me but after having a quick look it no longer tries to start up and does not have the red LED lit in the IR receiver/switch thing.
Power supply is good, tested it on an exact same... -
by estabilitoHi, I've just repaired acer nitro an515-55 with specs:
i7-10750h, rtx2060.
Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
i've tried different bios, different vbios and same behaviour - clean windows install too.
Do you have any idea?08-13-2025, 02:52 PM -
Hi everyone.
Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a... -
by EthanMaiDELL PRECISION 3440 SFF X4N41 10th 25Q256 Slow startup
ST-3L0GZB3
needs cleaning.
Please help me clean up the slow startup dump if you have time. Thank you....-
- Loading...
