The filename, directory name, or volume label syntax is incorrect
  • boyebaran
    • Sep 2015
    • 249
    • iran
    hi to all
    i have problem when i want to open folder in a memory stick .
    The filename, directory name, or volume label syntax is incorrect"
    error massage.
    file is very important and i need open it.
    please advise me.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: The filename, directory name, or volume label syntax is incorrect
    I think your USB is malfunctioning as all the files and directories are corrupted and CRC error mismatched .
    One thing for sure , it's not a reliable device anymore ...
    • boyebaran
      • Sep 2015
      • 249
      • iran
      it happened when i want to transfer file to other hard disk (by cut&paste).
      memory tape is silicon power cf 32gb 200x
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Well , it didn't copy anything , or at least , as physically damaged , couldn't complete the transferring in a complete manner ..
        Try repairing the USB from "CMD" Command :
        https://www.youtube.com/watch?v=DkHbka7_XPo
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Boyebaran; About the important file , you can recover it from the original source , even if it is deleted . There are many free programs that can do the job ...
          • boyebaran
            • Sep 2015
            • 249
            • iran
            tnx jiroy.i am using card recovery
            • karthur
              Vizio D65x-G4 Volume changes on its own
              by karthur
              On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
              It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
              06-05-2025, 08:13 AM
            • crackedprint
              Sony HCD-HX80R Amplifier Volume Control Problem
              by crackedprint
              I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
              I have tried a Cold Reset as per the service manual.
              I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
              I have looked all the way through the service manual and tried many online...
              01-21-2025, 12:18 PM
            • BigOof
              Marantz SR5007 popping on volume change and mute in Direct Mode
              by BigOof
              I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
              12-12-2024, 06:15 AM
            • Storyteller12
              Samsung Soundbar Q900T Cuts Off if Volume above 30
              by Storyteller12
              I have this soundbar and when I turn it on it works until I turn the volume above 30.
              Then the display show “PROT” protection and shuts off.
              I can turn it right back on and it works until volume hits 30 again.
              There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
              I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
              It will play fine for hours with volume...
              03-21-2023, 12:31 PM
            • dragometin
              Hitachi 40HYC42
              by dragometin
              TV Model: Hitachi 40HYC42
              Power Supply: 17IPS71
              MainBoard: 17MB95M
              Panel: VES400UNDS-2D-NO3
              When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
              I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
              Is there any variants on 17IPS71 power supply's?
              UART output pins 10 and 12 on scart connector:
              Code:
              12:24:04.595
              08-08-2024, 05:53 AM
