CF-25 toughbook CPU question
  • gdement
    • Jan 2007
    • 690
    Re: CF-25 toughbook CPU question
    Panasonic might have a manual giving a complete procedure for how to get everything installed. I know that was the case with Compaq when I was dealing with similar issues.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      Originally posted by pentium
      Well this is interesting.
      During the partitioning and formatting stage in the NT installer it could only see 8Gb of disk space but I just tried partitioning and formatting using the Windows 2000 installer and not only did it format fine but it also saw all 10Gb of space.
      It's nice to see that (at least the installer) Windows 2000 will use the whole drive however like mentioned above, this toughbook is a little underpowered for Win2k.
      I'll try installing NT and see what happens.
      I had this same problem installing NT workstation on a Virtual Machine. You have to make one partition like 2gb in size, install it on that, then format the rest of the hard drive.
      • pentium
        • Mar 2006
        • 2778
        They don't.
        Find Nedry!
        Check the Vending machines!!
        • Wizard
          • Mar 2008
          • 2296
          for this same reasons, I don't own Panasonic TVs except for dvd and anything that I don't care to replace. But to depend it on for over 120 bucks item like TV, etc. no way.
          What is important, how good service you can get for a said expesnive item.
          Cheers, Wizard
          • Scenic
            o.O
            • Sep 2007
            • 2642
            i had lots of problems when i tried to install NT4 onto an old laptop (Celeron 366).
            partition crap like you described above..
            i finally managed to install it...
            i made a 2GB FAT partition, installed NT4 onto it, and converted it to NTFS from within that NT4..
            all other methods didn't really work..
            oh and BTW...:
            NT4 SP6a
            http://www.microsoft.com/downloads/d...DisplayLang=en
            driver for basic USB support (USB 1.1 only)
            http://home.arcor.de/danclenator/nt4/progs/usb.zip
            Diskeeper NT Lite (defrag tool as NT4 doesn't have one by default)
            http://home.arcor.de/danclenator/nt4...eeperlite1.zip
            FAT32 driver for NT4
            http://home.arcor.de/danclenator/nt4...-fastfat32.rar
            another one
            http://home.arcor.de/danclenator/nt4/progs/fat32.zip
            IE6.0 SP1 (some programs need this to be installed)
            http://www.microsoft.com/downloads/d...b-20b602228de6
            Microsoft Management Console (MMC) 1.2 (needs at least IE5 installed!)
            http://home.arcor.de/danclenator/nt4/progs/mmc.zip
            • pentium
              • Mar 2006
              • 2778
              Thank you for those links.
              I only have the SP4 cd.
              Find Nedry!
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                #27
                Install the translator driver before any OS or you won't access the disk above 8 GB. If you need it, I can zip the disk and post it tomorrow.
                One bad side of NT4 is you can't slipstream the Service pack as in Windows 2000 upwards: there are some hacks about replacing some files with the SP ones, but the discover of replaceable files is a long trial and error process with a lot of BSOD during the install or (worse) immediately after that and works only on NT Terminal Server. Best thing is getting a NT 4.0 with SP6 cd image and install from that.
                I'd keep a 2-3 GB partiton for 98: it can be handy for running recent programs which don't run at all on NT (mainly multimedia ones, since NT is limited to DirectX 3).
                Zandrax
                Have an happy life.
                • jpdoe
                  • May 2007
                  • 237
                  #28
                  Hi, Zandrax.
                  About the NT4 SP6 ISO... Have you ever come across a real one? All those I've seen are hacked install cds not made by microsoft.
                  Thanks in advance.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    there are no NT4 CDs with a servicepack higher than 1.
                    they are all either without a SP at all, or with SP1.
                    everything else is a "hacked" version..
                    oh.. and zandrax...
                    DirectX 5 is the last one
                    http://home.arcor.de/danclenator/nt4/progs/dx5nt.zip
                    its not official, and this won't boost the count of working games that much, but hey.. better than DX3 lol
                    some other stuff:
                    Flashplayer 9
                    http://home.arcor.de/danclethefirst/...ashplayer9.zip
                    Windows Media Player 7.1 (needs SP6a and IE6 installed!)
                    http://home.arcor.de/danclenator/nt4/progs/WMP71nt4.exe
                    the WMP is in german. can't find the english version ATM (link is dead)
                    • jpdoe
                      • May 2007
                      • 237
                      #30
                      hi, scenic.
                      Thanks for the tip!
                      Great resource, http://home.arcor.de/danclenator/nt4
                      • gdement
                        • Jan 2007
                        • 690
                        #31
                        I don't actually recommend this, but in case you want to do it:
                        If you want the Win98 interface on NT4, you can install the "active desktop update" which is offered when you install IE4. I'm not sure where to get it online nowadays but I can post a copy if needed. It might actually be on your SP4 disc.
                        You can also install it from IE5 and IE6, but not as easily. You can just upgrade to IE6 afterwards and active desktop will stay.
                        This gives you all the conveniences that started with Win98, such as being able to drag and drop on the start menu, the quick launch thing, etc. Basically it replaces the Win95 shell with internet explorer doing everything instead.
                        However, unless you really hate the old shell then I don't recommend doing this. It puts a major hit on performance.
                        The Win98 style interface is much slower and consumes more RAM, undermining much of the reason for installing NT4 in the first place. Still, it probably won't consume as much memory as if you installed win2k, and it's much more stable than 98.
                        • zandrax
                          Hit and miss
                          • Dec 2007
                          • 1157
                          • Italy
                          #32
                          @ jpdoe, Scenic: I wrongly recalled that my NT 4 cd was shipped with SP6, I had to check it to be sure it isn't;anyway it would have negated my previous speech about hacked slipstreams Senile dementia 60 years in advance or simple lack of sleep?
                          @ Scenic: damn hackers, they discovered how to put DX5 for NT! Now I can play Age of Empires 1, Carmageddon, Driver, MDK and others
                          WMP 7 can run on NT just by modifying the installer and skipping the ASPI requirement: never tested for cd audio playback, old Winamp versions (such as 2.95) are IMHO better. MDGX hosts the english version.
                          @ gdement: I know IE integration is memory hungry and quite slow, but you can always install 98 with 98Lite (free edition has Chubby install which doesn't install IE) and later add IE6 plus other unofficial Service packs and programs you like. My retropc is a Pentium 100 with 32 MB of ram and my customized 98: only Opera is slow because it swaps a lot after 3 tabs, other programs work fine so the final result isn't disappointing.
                          Zandrax
                          Have an happy life.
                          • pentium
                            • Mar 2006
                            • 2778
                            Oh god.
                            Usually when you try to run a graphic program (Like Half-Life) at something smaller or larger than the physical size of the panel, the LCD controller makes it so that the image still runs fullscreen.
                            Well I fired up Half-Life at 640 x 480 (800 x 600 with only ~1Mb VRAM? Expect FPS rape) and instead of it doing exactly that it just gave me a black screen with the game running at 640 x 480 (actual size) in the upper left corner. Needless to say it was hell to play the game then as everything was so damn small.
                            I also seem to have an issue with Doom. The colors are all wrong but it does not seem to happen with other DOS games or apps.
                            Find Nedry!
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              some projects never work out...
                              old laptops are buggy like that
                              maybe the hardware is going out- it might not be software
                              search ebay for newer stuff- put a bit in and see what you can find (see my signature)
                              ik tough books are supposed to be really nice, but a buissness laptop will do you fine as long as you take care of it (dont smash it on the ground when you get mad, etc.)
                              remeber you still have a hd to use, and the power cord might work with other stuff
                              somtimes you gotta move on
                              i do know micron transport trek 2 was good
                              I had one that until an idiot killed the screen, ran win 2000 no prob- they take up to 256mb ram and come with upgradeable PII 366 processors (dixon core, the fastest PII)
                              Larry the teenage computer surgeon
                              sigpic
                              (Insert witty quote here)
                              • gdement
                                • Jan 2007
                                • 690
                                #35
                                Oh god.
                                There might be a key combination to toggle that. But I've never had a Panasonic laptop.
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Yeah, it's usually Fn + T but that does not work here. It's actually quite strange but I'll blame the BIOS anyways.
                                  Find Nedry!
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2642
                                    BTW: IIRC those thingys also came with a touchscreen...
                                    edit: for the stretched/non-stretched display, try FN + the F-Keys
                                    • jinu_j
                                      by jinu_j
                                      Hi
                                      05-03-2025, 10:51 PM
                                    • mikey5791
                                      by mikey5791
                                      Hi to all forum members,
                                      12-26-2024, 04:55 AM
                                    • MidnightRoller
                                      Can a resistor lose resistance after hot air?
                                      by MidnightRoller
                                      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                      02-02-2022, 11:46 PM
                                    • artvandalai
                                      What resistor ohm will work better to repair this waterpik?
                                      by artvandalai
                                      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                      01-05-2025, 04:10 PM
                                    • chth96
                                      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                      by chth96
                                      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                      Since then, This AC/DC adaptor have been out of order.
                                      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                      And Is there any possibility that it will suddenly explode as well as to be out...
                                      12-03-2023, 04:40 AM
