Dell Sx280 Motherboard Caps
  • Humphrey1
    • Nov 2008
    • 3
    Could Someone Tell Me If The Caps In The Attatched Pic Should Be 6.3v Or 16v. Thanks Humphrey
  • spaceman
    • Jan 2009
    • 52
    Re: Dell Sx280 Motherboard Caps
    They are 16v on my sx280 and according to Troy Brown at thecapking.com, that's what they should be. I'm actually about to try to replace them along with a few others in the next day or so. If it works, I'll let you know.
    peace
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      the 1500uF caps in those positions are 16v. they are on the 12v rail, so if you put 6.3v caps in there, they will blow almost immediately.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • thinkcentre
        Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
        by thinkcentre
        this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
        What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
        I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
        11-09-2025, 12:39 PM
      • Geeker007
        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
        by Geeker007
        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
        I am new to electronics repair, so my queries could be naive but I am ready to learn.
        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
        01-28-2025, 03:31 PM
      • Julian Bailey
        Dell Latitude 5350 Ultra 7 Motherboard
        by Julian Bailey
        Hi
        I have a Dell Latitude 5350 Ultra 7 Motherboard I am trying to repair that has a blown chip.
        The chip is marked as eHOLH similar to the one I have pictured.
        Any ideas what it does and what the pin outs are as 3 tracks have gone and need to find out what / where they went / did etc.
        Dell PN of the motherboard is 08DCGW.
        Below is the area I am trying to repair:
        Does anyone have a picture of this motherboard in this area they could take and upload?
        Cheers...
        07-03-2025, 11:25 PM
      • TMTGTR
        Need Advice On Which Caps To Buy For Dell Dimension 8300 Motherboard
        by TMTGTR
        The Symptom:
        I own a Dell Dimension 8300 motherboard that will post and get to the black (XP pro 32bit) “We're Sorry Windows did not load” Screen.
        When restarting any option i.e. “Normal” “Safe Mode” etc. Computer re-boots to same screen. I checked RAM with memtest –OK Checked O/S Drive with Victoria -OK
        Upon Inspection:
        I did a physical examination and see that the 6 caps by the CPU are all bulging in various degrees. (See Pics Below).
        I found a YouTube vid with a guy who replaced these 6 caps and the computer works fine....
        05-24-2022, 06:26 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
