I8KfanGUI concern
  • stevo1210
    • Oct 2006
    • 4156
    I8KfanGUI concern
    I have a Dell Inspiron 4000 here that had an application called I8KfanGUI installed. This application shows me the temperature and fan speed of my Dell laptop since this program is designed to work only with Dell laptops. I dunno if it has any serious impacts on my laptop. But I've heard that it can ruin my laptop completely?
    Just now the CPU temperature got up to 82c and the fans still didn't run. I had to put the program into "automatic fan control mode" instead of "no fan control, show temperatures" mode. I'm getting nervous about the application, so I've decided to remove it from the laptop. Since I've removed the application, will the BIOS now take over and control the fan speeds like normal? or do I need to do something else before I fry my laptop?
    Thanks.
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: I8KfanGUI concern
    Hi stevo1210
    read ** WARNING: I8kfangui can ruin your GPU!.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • stevo1210
      • Oct 2006
      • 4156
      Well after reading that, I am never even going to touch anything such as I8KfanGUI ever again. Anyway, after I removed I8KfanGUI, I decided to run a CPU burn in application and surely enough the CPU fan ran during the test as it got hot.... so I guess the fan control is back into the hands of the system BIOS.
      Thanks.
      • kikkoman
        • Jul 2007
        • 691
        what about speedfan? i don't have any experience with it running on Dell lappies, but so far i've always been very happy with it.
        "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Ahh yes, speedfan.
          Little more complicated on getting it to control fan speeds. But it works, non the less.
          • Fizzycapola
            • Oct 2006
            • 423
            If you underclock your laptop you may not need the fan to come on. I have mine permanently underclocked until I find an occasion that requires otherwise.
            Rubycon Rubycon Rubycon
            • Yanleb
              LG 60PK550 Logic Control Board EBR63450301
              by Yanleb
              Hi all, I just want to share the repair of my 60PK550-UA TV set.
              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
              C57: 3.30V
              C61:...
              07-20-2023, 12:38 AM
            • harp
              triac phase control 0-100%
              by harp
              Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
              06-02-2024, 09:00 AM
            • tmhobadcap
              Pioneer VSX-522-K remote control not working???
              by tmhobadcap
              I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
              At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
              12-24-2020, 01:44 AM
              Linear Garage Door Opener Control board took a crap install a new control board back normal
              I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
              02-08-2025, 06:52 AM
            • crackedprint
              Sony HCD-HX80R Amplifier Volume Control Problem
              by crackedprint
              I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
              I have tried a Cold Reset as per the service manual.
              I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
              I have looked all the way through the service manual and tried many online...
              01-21-2025, 12:18 PM
