Acer Extensa E261
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Acer Extensa E261
    Hi all
    today I bought this PC for a friend's cousin for € 234 and I want to know if someone here has experience with it.
    I couldn't open it because I don't want to lose the warranty (the PC isn't mine ).... so I really don't know what is inside.
    I don't like Acer and for what I have heard the customer support is not very good.
    Here the technical description:
    Model Extensa E261 PS.E26C0.I02
    Bundled OS Linux
    Case Type Micro Tower
    Processor Speed Pentium® Dual Core E2140 1.6 GHz
    Chipset SIS 672 Express chipset with SIS 968
    Integrated videocard SIS MIRAGE 3+ GRAPHICS max 256 MB
    Memory Std. 1 GB DDR2 SDRAM
    Memory Max. Up to 4 GB
    Memory Speed 400/533/667 MHz
    Hard Disk Capacity 160 GB
    Hard Disk Controller Serial ATA
    Optical Storage DVD-SuperMulti Serial ATA
    Slots / Bays
    Slots - PCI 2 x PCI
    PCI-Express 1 x PCI Express x1 1 x PCI Express x16
    Audio Sound Integrated high-definition audio
    Ports / Interfaces
    USB Ports (Rear) 4 x USB 2.0
    USB Ports (Front) 2 x USB 2.0
    PS/2 Ports (Keyboard,Mouse) 2 x PS/2
    Audio Ports 6 x Audio jacks
    RJ 45 1 x RJ-45
    Card Reader
    Power Supply 250w
    TIA
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Acer Extensa E261
    I hope your friend does very basic tasks with the pc: this is a real POS.
    The chipset is the main weak point for two reasons:
    - it supports only single channel addressing for ram: the reduced bandwith slows down the cpu by a 20-30% depending on benchmark used;
    - the Mirage is an integrated graphics even weaker than Intel ones and driver support is awful both on Windows and Linux: Linux users, even Ubuntu ones, must ask the correct driver directly to the Sis employee who writes it because Sis ships it only to OEMs and hope it'll still work when the new distro release comes out. Screw you Sis
    If there are no seals, open the case and inspect carefully capacitors and the psu: best warranty is preemptive recapping here. Other thing you can do is expanding the ram to at least 1 GB and buying a graphic card: even a low one offers a substantial boost over the Mirage and doesn't hog the cpu any further like the integrated graphic does; a GeForce 7300 or an Ati 2400 / 3450 should do the trick for 30-40 euro, avoid the 8400 due to well known manifacturing defects. nVidia has still the best graphic Linux driver around, ATI is reaching its level but it's not a quick process.
    BTW, I already showed you that a 250 euro config could be substantially better than this one ...
    Zandrax
    Have an happy life.
    • Gianni
      • Jul 2008
      • 681
      • Italy
      Thanks for your feedback.
      I have bought this computer for a person that will do simple tasks like browsing, write CD/DVD and photo editing.
      At the moment he has Win95 on a Pentium 200MHz and he uses it only to play with some basic games. Probably he doesn't really know how to use a PC... so I think this one is enough powerful for him.
      I proposed him a configuration similar to the one you have written, it was a 280€ because I didn't find the same hardware.
      With some compromise, the cheapest solution I could make starting from your proposal was 260€... but wasn't cheap enough for him .
      I told him that I don't like Acer but he wanted it so he got it.
      I searched a review on internet but I didn't find anything very serious regarding what's inside.
      I have installed WinXP HE and seems stable and fast.
      It has 1GB already; I can't install a videocard because there are seals on PC, if I break them I lose the warranty.
      Ok let's hope it last long... otherwise I will open it after warranty period.
      Ciao
      Gianni
      P.S.: the fucking warranty is lost even if you use a different OS from the one installed by Acer
      H. J. Brown
      • Scenic
        o.O
        • Sep 2007
        • 2642
        hmm...
        if this guy still used a Pentium 200 i guess that system is a bit too "high-end" with too much cost-cutting :/
        i dont know any italian hardware online shop... so i used "alternate" to get a rough price for the system..
        something i would've put together..:
        Mainboard (incl. CPU):
        intel D945GCLF (intel Atom 1,6GHz) -> 58€
        Case:
        Asus TM-B12 µATX Case -> 19€
        HDD:
        Hitachi Deskstar 7K160 160GB SATA HDD -> 34€
        RAM:
        Kingston ValueRAM 1GB DDRII-667 -> 16€
        or
        Kingston ValueRAM 2GB DDRII-667 -> 31€
        DVD-RW:
        LG H20NS Super Multi (SATA) -> 27,90€
        i didn't add a power supply because i dont know much about the (cap-) quality of HEC, Chieftec, and Sharkoon (which are below 35€ on alternate) and alternate doesn't have Fortron Source PSUs in stock. Seasonic S12II-330HB (330W, 52€) would be a little overkill (price-wise)
        well.. for calculating everything together i've chosen a Chieftec GPS-350EB 350W for 33€..
        With 1GB RAM: 188€
        With 2GB RAM: 203€
        and this, using known good manufaturers only (except the Chieftec PSU .. i dont know anything about that one, but it seemed more promising compared to a HEC)
        its too late already... but keep something like this in mind for low-end basic-task pcs if you have to build one of those again
        • Scenic
          o.O
          • Sep 2007
          • 2642
          damn... i hate this 10min. edit limit -.-
          edit: Graphics card (intel GMA950), Sound and LAN are onboard.
          Graphics card uses Shared RAM, but it's DirectX9 capable and even gets 632 points in 3DMark03 on this intel Atom board (which is quite good for onboard graphics)
          • i4004
            • Oct 2006
            • 2029
            chieftec is ok.
            • Gianni
              • Jul 2008
              • 681
              • Italy
              Thanks Scenic and i4004.
              For sure if I need help I will ask here, but this time I had no choice... the guy had preferred a known brand instead of build a custom PC.
              This week I'm a little bit busy than usual and I have small time but ASAP I will check the price here where I buy HW to see if they are different from your.
              Ok there are other places where I can buy... but selling PC is not my job and as I charge few euros to do this service I prefer to buy everything in one place.
              To summarize: when you deal with someone that doesn't know the subject... or he trust you at 100% and follow your suggestion... or it is better for you, after you have warned him, to do what he wants so if something doesn't work it is not your responsibility.
              Ok I have to go now, I hope to get back on Badcaps soon.
              Ciao
              Gianni
              H. J. Brown
              • Newbie2
                • Sep 2005
                • 885
                That Extensa E261 is a VERY BASIC computer with only a Pentium Dual Core E2140 1.6GHz processor (it's cheap Acer so no overclocking to at least run that E2140 at 3GHz for better performance), 1GB of RAM, 160GB hard drive, and junk SiS integrated graphics.
                It would be suited only for basic Internet browsing and e-mail, on an operating system such as Windows XP Home Edition or Professional. Vista on that would run on it, but it WOULD BE SLOWER THAN A SNAIL.
                My gaming PC:
                AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                ASUS M4A77TD AMD 770 AM3 Motherboard
                PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                ASUS Xonar DG 5.1 Channel PCI sound card
                Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                Antec Three Hundred Mid-Tower Case
                Microsoft Windows 10 Pro 64-bit
                Microsoft Windows 7 Ultimate SP1 64-bit
                • zandrax
                  Hit and miss
                  • Dec 2007
                  • 1157
                  • Italy
                  @ Gianni: I understand you had your hands tied: no chance in dealing with a stubborn "client", I know, and a too low budget to buy something better with Italian prices; a light upgrade (mobo, cpu, ram) is impossible too because you can't keep anything from the old Pentium (except the keyboard if it's a sturdy one). Nevertheless, I'd have second thoughts in buying an Intel based pc with a Sis chipset.
                  @ Scenic: Italian best prices are near the one you reported. Best prices, usually in different shops
                  My favourite prices search engine is Trovaprezzi (litteraly: The price finder), but it covers most but not all shops.
                  Looking into detail, the Atom board costs at least 72 euro, the Asus case is unavailable and entry level ones cost about 20-25 euro, ram and hdd have comparable prices (sometimes slightly lower, usually slightly higher), the DVD-RW is 5 euro cheaper but the psu 12 euro more expensive. Your configuration would have costed about 30 euro more here: cheaper then the Acer but not by much.
                  @ Wizard: it's a budget machine for someone which can't tell you the difference between his new box and the preveious Pentium he used. I think performance wasn't the most important thing: price was. And noone is so crazy to put Vista on it (though a v-lited version could run quite nice, the standard one would be too slow), at least because Aero would scary the owner .
                  Zandrax
                  Have an happy life.
                  • Gianni
                    • Jul 2008
                    • 681
                    • Italy
                    It's so late and within 5 1/2 hours I have to get up... but I have done my homework and here what I have found:
                    Intel® D945GCLF 58€
                    MIDDLE TOWER INWIN EM002 BLACK/SILVER NO PSU 26€
                    DESKSTAR 7K160 160GB SATA 38,60€
                    DDR2 1GB 667MHZ PC2-5300 CL5.0 KINGSTON 13.70€
                    DDR2 2GB 667MHZ (PC2-5300) 24,90€
                    DVD S-ATA GH20NS10 RETAIL BLACK 20,60€
                    Chieftec GPS-350EB 44.90€
                    Total With 1 GB 201.8€
                    Total With 2GB 213 €
                    These are the best price I have found but as I wrote I can find them at separate stores.
                    I was not able to find the Asus cabinet so I have chosen the cheapest one.
                    If I add extra costs (delivering for PSU is 12€) at the end I can save few euros compared to Acer Extensa.
                    For me it does make no sense to spent time searching for best price just to save few euros when you have to order parts at different stores unless you have not extra costs or you can buy directly at the shop.
                    Thanks again for your suggestions, they are gold for a newbie like me
                    Gianni
                    H. J. Brown
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      @ Scenic: [...]
                      sounds more like the D945GCLF2
                      biggest difference is the dual-core Atom CPU.
                      the D945GCLF without the 2 at the end has a single-core Atom and it's price dropped about 20€ when the GCLF2 found its way into the shops..
                      the only reason why i've chosen the Asus tower is that it was the cheapest non-noname case. any (µ)ATX case would do the job..
                      well.. a bit cost-cutting would be possible (A-DATA RAM or a cheaper Samsung or Lite-On DVD-RW drive for example) but i had some problems with those brands lately so i dont really like to use them for anything anymore (especially the Samsung and Lite-On drives.. some of them died within the first 3 months of use :/ )
                      like i said... the PSU is one of those parts where i don't know much about the entry-level units...
                      i prefer to put seasonic, fortron or delta PSUs in my custom built PCs.. but in this case (where price matters and the sys won't even fully load a 250W PSU) this would be kinda overkill...
                      like on the Asus case.. almost any PSU (with a 4pin P4 plug) would do the job... the only thing i would worry about would be the caps..
                      well... at least you can get some sleep... :/
                      i've spent the whole night reading articals (articels ?! whatever..) about some electronics stuff until i realized what time it is :O
                      its 5:03 AM right now... going to bed now wouldn't make sense as i wouldnt get up at 8:00 AM
                      this is going to be a hard day .__. *yawns*
                      • i4004
                        • Oct 2006
                        • 2029
                        interesting thing: chieftec is delta.
                        hehe...
                        https://www.badcaps.net/forum/showth...light=chieftec
                        i think even some sleep is better than no sleep.
                        true.
                        but one can probably find a cheap enough web-shop and get it all from there.
                        the one i use here also has cheapest prices anywhere in this country..hehe...
                        stuff+delivery is always cheaper than me going to city and buying it there(prices are higher, fuel is expensive....)
                        • zandrax
                          Hit and miss
                          • Dec 2007
                          • 1157
                          • Italy
                          @ Scenic: don't worry, I only tried to look for all components you found. I know there are slightly cheaper alternatives in some cases.
                          You're right about the motherboard: the search engine reports even partial name corrispondence, so I found only two shops selling the D945GCLF2. Didn't bothered to check the name ...
                          If I don't sleep about 8 hours a day, I'm usually going to waste the following morning in trying to keep me awake and doing very little work: articles and knowledge are important, but life is more
                          @ i4004: happy to learn Chieftec psus are made by Delta. Another brand to suggest.
                          Zandrax
                          Have an happy life.
                          • Gianni
                            • Jul 2008
                            • 681
                            • Italy
                            At the end I have found someone worse than me
                            I wake up every morning at 10 past 6, excluding Saturday and Sunday, and usually I go to bed after midnight and sometimes I stay up till 2 in the night.
                            5 years ago I could sleep one 3 hours per day, now it's hard to do it and when happens, like this week, that I stay up till 2 in the night for 2 days... I have to sleep till 10 on Saturday morning. I think I'm getting old
                            By the way I was so tired the other day that I wrote 5 1/2 hours instead of 4 1/2 hours
                            You are right but I'm an old fashion man, I like to touch things with my hands and I like to look at people in the eye when I buy something.
                            @ zandrax: I would like to sleep 8 hours... but in this way I would be able to do only 2/3 of what I have to do.
                            Yesterday night I have delivered the Acer Extensa, the guy was happy because it is very silent and fast, the old PC was like an helicopter.
                            Ciao
                            Gianni
                            H. J. Brown
                            • Fizzycapola
                              • Oct 2006
                              • 423
                              Yeah thats a good system.
                              If his old system were plastic pliers. The new system virgin forged metal pliers. Buying modern PC's is like buying hammers. I went to buy a hammer recently to bang in some tacks. The guy shows me his hammer section. The cheapest hammers £15 going upto around £35. Well unless an undercover hooker gives you a free service coincendentally after leaving the store whats the point, the special rubber finishes on those hammers tarnishes easily and after a year they look unhygienic, I bought the cheap shop special hammer £2 and did all my diy with a full wallet smile.
                              Rubycon Rubycon Rubycon
                                ACER Extensa Extensa E264 Extensa E2200 Specification for Upgrade or Repair
                                This specification for the ACER Extensa Extensa E264 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa Extensa E264 boardview and Extensa Extensa E264 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-12-2024, 03:36 PM
                                ACER Extensa M2710 Extensa M2 i3-6100 Specification for Upgrade or Repair
                                This specification for the ACER Extensa M2710 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa M2710 boardview and Extensa M2710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                09-12-2024, 03:30 PM
                                ACER Extensa M2710 Extensa M2 i5-6400 Specification for Upgrade or Repair
                                ACER Extensa X2610G Extensa X2 J3060 Specification for Upgrade or Repair
                                This specification for the ACER Extensa X2610G can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa X2610G boardview and Extensa X2610G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
