virus scanner
    • 31294
    virus scanner
    just stumbled on this - it may interest people.
    http://antiviruslivecd.4mlinux.com/
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: virus scanner
    I havent used antivirus software since probably around the turn of the century. If you're smart with your network & PC, browse smart, and use a good hosts file, you'll be fine. I do keep my eye peeled for strange behavior or oddball services running. never had an issue.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • 31294
      Re: virus scanner
      it's a live-disk - it's for cleaning a system that is already stuffed!
      • junktv
        • Nov 2010
        • 3065
        Re: virus scanner
        Another idea is puppy linux or something on a old thumb drive and install nod32 on it. The down side is it's paid but you could do a trial when you need it. It's what I used on linux when I hosted a server. I thought it was more user friendly than clam or a couple others were were. You can find deals on it also and get 3 year long keys for $30-40.
        I'm not pro so i run a av. Even if you try to browse clean you can still run into crap. It blocked some stuff on ebay the other day. They used a pic for the ad description hosted else where.
          master hoarder
          • May 2008
          • 12175
          Re: virus scanner
          Yeah, it's been a good 6-7 years (or possibly even longer) that I stopped using AV software on my PCs. No more long boot times and annoying high CPU usage. No more virus definition updates at start-up either. Ever since Windows Vista/7 came out, I no longer play around with infected PCs and try to clean them up, because in my experience Windows Vista/7 tends to be much harder to clean up once the virus/malware gets deeply rooted in the OS. With XP, there are many ways to restore just about everything. So for really infected Vista/7 PCs, I just reinstall and call it done.
          • Nitro468
            • Oct 2013
            • 65
            Re: virus scanner
            Play with this.... http://www.pendrivelinux.com/univers...easy-as-1-2-3/
            Plenty of Antivirus and other utilities on it, with download links to many. Some GREAT stuff here...
            • CTekGuy
              • Oct 2016
              • New Zealand
              Re: virus scanner
              i have to say one of my favorite anti virus programs is Avast. i have tried most of the other anti virus programs and for example McAfee seems to let a lot slip past. Nortons is extremely heavy on the system. i have had a little success with 360 but would be my next choice after avast for free anti virus
              • Ascaris
                • Nov 2015
                • 54
                Re: virus scanner
                I agree that usually watching what you do with your 'puter will prevent malware from getting on your system, but there are exceptions.
                Years ago, I was browsing around looking for information on guitar strings or some other such thing. Apparently, the guitar site had been compromised, as it contained none of the content Google had cached, but instead redirected me to some site whose URL referenced pot, but served up only what appeared to be a blank page. Immediately, my security suite (Outpost Suite; firewall/hips/antimalware) software popped up a "do you want to allow this?" message, as it often did.
                Much to my chagrin, I sort of watched as I hit "allow" on the dialog out of habit... and I really was aware of the problem of getting into the habit of saying "yes" all the time, but it was like I was yelling at myself to STOP! in my head while my body was acting on autopilot.
                Obviously, I was aware that my system had probably been infected right then, so I quickly hit the tray icon and set Outpost to block all net access. I unplugged the ethernet cable, cutting the PC off from the world, and when I got back in front of the monitor, Outpost had popped up another dialog. I had Outpost set to the most annoying, paranoid mode possible; it asked for permission for every damned little thing. I hit Block and Terminate, then began disinfecting.
                I looked in the Outpost log to see what I had allowed, and it was the execution of the .exe malware. The second popup was the malware trying to set registry keys to run itself at boot time. I looked at the location and filename of the program that Outpost stopped from writing to the registry, and there I found the malware. It was not running at that point; Outpost had done its job and terminated it. No unusual processes were running that I could see in the Task Manager or in Advanced Process Terminator.
                I scanned that file with Outpost's malware scanner... no hit. I tried a couple more scanners (I have a few at the ready in case I need them, as on-demand scanners only)... nothing.
                I sent that file in to a couple of the AV companies using their usual instructions (zip it with a password to get it past the various gateway email scanners), then restored the most recent backup of my system to be certain it was gone. One of the AV companies got back to me a few days later and said it was a new malware that had been added to their database.
                What had happened is that the malware had exploited a zero-day in the Java plugin-- now it's common knowledge that Java is a huge security black hole (and hardly ever needed anymore), but I was not aware of any such thing back then. After that I just uninstalled Java and haven't looked back.
                The only questionable decision that led to the malware trying to execute was having the plugin set to run automatically. Okay, maybe there were two questionable decisions; I was running Windows XP in administrator mode, which nearly everyone did.
                Otherwise, I didn't go to any dodgy sites, I didn't download and run any questionable files, and I didn't fall for any phishing or other social engineering. I was using Firefox, fully updated, and Windows was up to date too.
                Even though I robotically hit the wrong button when Outpost popped up the dialog, it had still done its job. It alerted me to the presence of malware that otherwise would have gone unnoticed (including by the virus scanners I had), and it blocked the malware from doing anything once it had executed. What was the purpose of the malware? I don't know. I never had to find out.
                • waigy
                  What are these components that detect paper in a fax scanner
                  by waigy
                  PROBLEM SOLVED
                  I DIDN'T REALISE MY SMALLEST SOLDERING TIP COULD JUST FIT BETWEEN THESE COMPONENTS.
                  I MANAGED TO REMOVE THEM WITH NO DAMAGE TO THE BOARD AND I HAVE MY INTENDED END RESULT.
                  On a Possio PM70 portable fax machine which has a scanner that detects when you push a piece of paper into the scanner slot.
                  It is these two small (3mm long) components that detect the paper and start the scanner feed motor which pulls the paper into the scanner.
                  (These are on the circuit board for the keypad and not the main board)
                  I want to disable these as...
                  05-21-2023, 12:50 AM
                • CapLeaker
                  Bearcat 300 scanner no display, has audio and squelch repair
                  by CapLeaker
                  I found an old Bearcat 300 scanner that had no display, but the audio and squelch worked, over at my workplace. This unit has a lot of hours on it. It had some capacitor replacements and other mods done to it too before I found it. To troubleshoot this problem, the usual is to check the +25v and -30V and replace C98 on the main board. That should fix it. There is also a case of a shorted button board (just unplug that ribbon cable and the display should work again). Spoiler alert! Was not the case on this one.
                  My display didn't work, because I had a missing -10V on the display...
                  09-09-2024, 10:24 AM
                • mon2
                  Hunting down a virus in an office
                  by mon2
                  Hi. We have an office client who has been contacted by the local internet provider that one of the office Windows PCs is infected with a virus. The report has been confirmed. Apparently through a remote outside trigger, this virus is performing brute force attacks around the world from this local IP address at varying times. Aside from low level formatting each PC, what is the recommended approach for this case? Running F-prot (suggested by the internet supplier) has come up empty. We are planning to run hijack this. At this time, we do not know which PC is creating this issue. Internet provider...
                  01-09-2025, 09:42 PM
                • SoporteHR
                  DesignJet T1200 MFP scanner (CQ653A). It restarts after minutes of having turned on.
                  by SoporteHR
                  Good morning to all the presents.
                  Receive a warm greeting.
                  I commented and consulted the following (Electronic Technical Level), since doing a search for the team model (CQ653) I did not find anything that references the problem I have.
                  Equipment: HP DesignJet T1200 MFP. CQ653A. Scanner Module.
                  History of the device:
                  The user of the equipment had problems with the lamp, due to this, he proceeded to replace it, but he said that the bulb was damaged, he replaced it and when he turned on the equipment, there was a short circuit...
                  12-04-2018, 08:25 AM
                • fricosu007
                  OBD Scanner Autel AL539 burnt rezistors
                  by fricosu007
                  Could someone help me identify the two rezistors burnt inside this AL539 device from Autel, i cannot find any dissembly pictures and there are a lot of these devices, i hope some of you have it 🙌
                  https://imgur.com/a/b9fGGGk...
                  09-22-2025, 10:58 PM
