5.25 floppy
  • ozzy214
    • Nov 2013
    • 319
    • usa
    5.25 floppy
    I am going through all my computers here. I cant not find any that will run 5.25 floppy drive. I have as old as socket 775 p4 sli board and a asus p5q se plus..my current rig. None of them have 5.25 floppy support in the bios.
    Anybody have any ideas? I was looking on ebay and can only find 3.25 usb floppies, no 5.25 floppies.
    I even tried a am2 board in a factory HP and same thing,
    See, I have a bunch of floppies that I want to test for resale. As well as drives.
    Anyone have any ideas?
    I used to run a lot of e scrap and sell to the gold buyers. But sources dried up, so doubt I will see any p3's with support anytime soon.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: 5.25 floppy
    Did you Try to enable , in the bios , the option of Floppy B , usually it is disabled and it is the one who support 5.25inch in older machines , as well as the option of swapping Floppy drives option = Yes ?
      • 31089
      Re: 5.25 floppy
      linux can ignore the bios and read any hardware you specify.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Re: 5.25 floppy
        It's still a problem if the board doesn't have a 34 pin connector...
        Dang, I still have (a lot of) boards with floppy support, talk about obsolete hardware :-(
        • dmill89
          • Dec 2011
          • 2534
          Re: 5.25 floppy
          I've got a socket 754 board (an ECS 755-A2 with a sis 755/964 chipset) that supports dual-floppy and 5.25", probably the newest I've seen that actually supports dual-floppies (both 3.5" and 5.25" at the same time), some newer boards may still support a 5.25" as a single drive though. Socket 370 boards and older are probably most likely to support dual-floppy and 5.25" but there are some newer boards that do as well.
          Floppy connectors aren't "that obsolete", there are a few (very few) new boards that still have them, and they were very common up through the Core 2 Dou/Quad socket 775 era (even if the system didn't have a FDD the board usually still had a connector for it), my Gigabyte EP45C-UD3R (Intel P45 chipset socket 775) board is the newest one I have with a FDD connector.
          • ozzy214
            • Nov 2013
            • 319
            • usa
            Re: 5.25 floppy
            I solved the issue. Found a old custom built...appears to be unsure.....socket 7 board in a tower complete with everything including isa scuzzi card.
            Gonna try and install xp on it or run xubuntu live off a usb stick. Use PLOP obviously so it can boot USB LOL!
            Yes it is correct, some newer boards do have floppy connector. But 5.25 support is not there. Only 3.25 and 3.50 support. My Asus p5q se plus I been running since 2008 and have updated with newer tech voer the years does have a FDD connector. But no 5.25 support.
            I just got lucky I buy scrap off of my competitor that stole most of my scrap business with higher pricing. And there was a perfect machine to play with!!
            See, people do still use 5.25 floppies. Enthusiasts, collectors, etc. Hell Commodores use them. Hence why I need something to test floppies and drives for resale.
            Apperantly no longer they make 5.25 disks, but people still buying. Hell I just sold NOS IBM 3.25 floppies for 35 shipped just two days ago. LOL!
              • 31089
              Re: 5.25 floppy
              the bios cant tell what type of drive you have, the setting is just for booting and "advising" the o.s. what drive it may be.
              if you have an award bios, you can re-enable all the older options wih a bios editor.
              • ozzy214
                • Nov 2013
                • 319
                • usa
                Re: 5.25 floppy
                OK then maybe the floppy drive i been playing with is no good. I tried 3.25 and 3.50 setting. Windows 7 comes up and loads the floppy drives. But all drives does is spin, doesnt try to read. MMM
                  • 31089
                  Re: 5.25 floppy
                  does the head(s) move to seek the tracks?
                  maybe you need to change the jumpers - modern pc's are not 100% SHUGART compatable.
                  that's why you cant use un-modified pc drives in an ST or Amiga.
                  • ozzy214
                    • Nov 2013
                    • 319
                    • usa
                    Re: 5.25 floppy
                    Nope head doesnt move. I dont see any jumpers on it to be honest.
                      • 31089
                      Re: 5.25 floppy
                      make & model?
                      • ozzy214
                        • Nov 2013
                        • 319
                        • usa
                        Re: 5.25 floppy
                        Mitsu mf501c-318u
                          • 31089
                          Re: 5.25 floppy
                          well it's a lot newer than i expected.
                          it should just work - once the o.s. has been told what it is.
                          (1.2meg high density double-sided)
                          • ozzy214
                            • Nov 2013
                            • 319
                            • usa
                            Re: 5.25 floppy
                            It doesnt. OS install 3.25 drivers and thats it.
                            • ozzy214
                              • Nov 2013
                              • 319
                              • usa
                              Re: 5.25 floppy
                              How do you tell windows 7 its 5.25 floppy 1.2meg?
                              I grabbed another drive off the shelf and this one actually seems to work. But cant read any disks i feed it
                              • jiroy
                                • Jun 2016
                                • 2416
                                • Lebanon
                                Re: 5.25 floppy
                                It's time then to do some cleaning . If you can disassemble the unit properly , you can clean the lenses . You'll find of course lot of dirt and dust to remove
                                The cable connector of floppies , or the older ones at least connect all kinds of inches , if it recognize one kind , then it will recognize the second forcely , provided the related options in Bios are not disabled . If , there are no options of enabling or disabling , then , by default , the windows is forced to recognize em ..
                                  • 31089
                                  Re: 5.25 floppy
                                  i dont use windows.
                                  maybe your disks you cant read are not high density.
                                  • ozzy214
                                    • Nov 2013
                                    • 319
                                    • usa
                                    Re: 5.25 floppy
                                    Well I learned something interesting. I have the bios set to 3.5 and 1.44mb floppy. On the boot menu it tries to boot the floppy. So obviously bios sees it, but cant boot due to nothing on disk.
                                    I just installed dual boot xp/windows 7 on one box and both os say their is no disk present.
                                    So Im lost. How could the bios see and try to boot the disc? But both os cant see disk?
                                    • jiroy
                                      • Jun 2016
                                      • 2416
                                      • Lebanon
                                      Re: 5.25 floppy
                                      It's very simple .. the bios detects the device and windows 7 cannot locate its proper drivers , or let's say appropriate ones . Notice here that systems with 64 bit are harder to identify old devices than the 32bit ones . Some devices are 100% compatible , meaning , it is plug and play , an others need a certain driver from manufacturers ..
                                      Try to locate the 5.25 inch in control panel , does it show there ?
                                      • ozzy214
                                        • Nov 2013
                                        • 319
                                        • usa
                                        Re: 5.25 floppy
                                        Windows 7 sees it as 3.5. I think its a bios limitation, because I installed xp and it cant pull data or format. I then tried zubuntu live and it said somethign about cant mount and bad blocks. So guess this box cant read it
                                        So going to have to fire up the dinosaur and try that!
                                        • eccerr0r
                                          It's 2025: do you know where your 5¼" floppy drives are?
                                          by eccerr0r
                                          Oh wow.
                                          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                          Weird. Seems the PC drive is having trouble clamping...
                                          07-07-2025, 12:49 AM
                                        • Stefan Steff
                                          HP Elitebook 840 G5 strange behaviour, need ideas...
                                          by Stefan Steff
                                          I finished my work for this year, so I'm free until January 6th.
                                          My last task it's unresolved and I'm looking for ideas for the return in January.
                                          So what's about...
                                          This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
                                          My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
                                          No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
                                          The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
                                          12-24-2024, 05:50 AM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • ZoneMind6006
                                          Ideas on what's going on with this T480s
                                          by ZoneMind6006
                                          It's already computrace disabled and all that good stuff, W25Q80V and W25Q128V seem fine. The issue is powering the thing on, the fan will spin for about a half second and if power is kept in, it continues to do so in intervals. If I place the battery in, it will show orange for just a sec, now interestingly, if I place a charger in both the TB port and charging port at the same time it will turn white or charge until completion, how odd, but it won't boot. Any ideas?
                                          12-13-2023, 07:44 PM
                                        • Topcat
                                          Need to find a 34-Pin Motherboard Floppy Header
                                          by Topcat
                                          Looking for some floppy headers.....searching the usual sources (digikey/mouser/etc) until my eyes bled, I couldn't seem to find such a beast. Yes, the silly 34 pin floppy header for a PC motherboard....
                                          Why? Well, I was given a bunch of Optiplex 330's, which are useless systems these days....and despite what some have said, they do not respond well to the E5450 c0 stepping LGA771 Xeon mod, tried several, it never worked. They're in a standard BTX case, so I tossed some $5 Optiplex 380 boards in them I picked up on ebay, which will run ANY 5400-series Xeon with hard mods + firmware........
                                          06-25-2020, 10:50 AM
