Switching PSU noise on +12V for CPU
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    Re: Switching PSU noise on +12V for CPU
    Weird. I cannot find 16V caps on this Foxconn M/B, maybe it does not have prefiltering and depends on the PSU to do all the filtering?
    I also checked the ATX24 power plug. Holy crap, I see 600mV droops on this wire that aren't visible on other wires.
    And those fake Nichicons. I tried repeatedly rapidly manually charging/shorting one of them, yes the cap starts getting warm. Maybe expected, but when I set my bench PSU to about 14V I see about 300mA leakage on a 16V cap. This is NOT right...
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      Hmm...Since my Sencore also has a "reform" function, I wonder what it will do with these leaky caps....
      I need to stick it in a blast chamber and see what happens when I let it reform for a while. This cap shouldn't be all that old...
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        Thinking outside the box, it makes perfect sense when you consider those are fake caps...
        Not 16V rated at all.
        FWIW, I have "torture tested" several Nichicons out of various equipment I junked. I applied 18V to several PW, VR, and HM 16V caps, from 100u to 4700u, and after a few minutes, leakage in most cases was below 10mA, with the 4700u/16V VR ultimately withstanding 20V with less than a mA of leakage.
        Again, these were used caps from junk equipment.
        Legitimate "16V" caps are usually formed to withstand 20V; the old datasheets would list these as 16V rated/20V surge.
        As for the fake caps, they'll have whatever printed on their sleeve that looks or "feels" good, depending on their intended use (mobo, SMPS, etc).
        "pokemon go... to hell!"
        EOL it...
        All style and no substance.
        guilty,guilty,guilty,guilty!
        guilty of being cheap-made!
        • Wester547
          • Nov 2011
          • 1269
          • USA.
          Originally posted by stj
          16v is too low for a 12v line - even if a few people will now start flaming me over saying it.
          also, if that cap has been sitting for over a year it may have started to depolarize.
          i had that the other day, dug out a working board that i stored a couple of years back,
          powered it up - BANG - fucking teapo 6.3v cap on the 5v rail!!
          replaced the bitch and a matching one with a pair of 16v rubycon's
          The Teapo capacitor likely bulged because it's crap and no other reason. Teapo capacitors are sometimes known to outgas without ever having _any_ bias applied to their plates (in storage). It does hold true that capacitors from crap brands (nevermind counterfeit capacitors) are more likely to be overrated, not just in terms of voltage and capacitance but in terms of ripple current in the datasheets (which in and of themselves tend to be amuck with sloppiness and inconsistent values).
          And IMHO, if 16V was really too low for the +12V input (or output), for wet electrolytics, expedited failures, even from good brands and series, would be more commonplace. Leakage current does augment as you approach the rated voltage, and that in turn causes the consumption of electrolyte to rise so as to correct defects (even those minor) in the oxide layer (reforming). I like the fact that those recent HMs survived voltage torture testing. I wonder if any KZG could survive and brave the same challenge?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            I hooked up one of these fake caps to my Sencore with 15V reform voltage. Currently it's leaking at 2.8mA, so at least it seems a bit lower than when I was testing with my bench psu. Measuring the voltage with a DMM it looks the Sencore is at 11.8V, so perhaps it hasn't gotten up to the voltage where it was leaking really badly.
            The only "good" think is that this cap does read 3300uF±20% at 3500uF... but the voltage rating is really wrong.
            Oh BTW, the fake cap took less than 10 minutes of bias at 12V to vent. I pity whoever actually used these as 12V filter caps...
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              OH FUN!!!
              After about 8 hours, the cap that I stuck on my Sencore decreased to 1300µA leakage... Voltage went up to 13V...
              BUT it BLOATED!!! It'll explode any time now!
              This is NOT a 16V cap!
              And fun... I just noticed these fake Nichicons that I have, they're all sorts of different capacitors from different manufacturers. Looks like the counterfeiter used caps from all companies, so you never know who made that counterfeit. Will have to setup another thread...
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                You've been on BCN since 11/08/2012 and you're just figuring that out?!
                EOL it...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  Look if you don't want to respond, you don't need to respond. No sense in personal attacks which are absolutely the most useless posts around.
                  In any case, to reduce a counterfeiter's costs, one would expect to stick with one large lot and not actually mix them. Or at least have enough of them such that they are very uniform to any one seller.
                  This is not as uniform as I expected, when I first looked at these they appeared mostly the same (I did notice one anomaly the first pass), until the closer inspection now I see even more within the same batch.
                  Once again I expected these to at least be close to spec and not blow up in 10 minutes; 10 weeks or 10 months, maybe. After all Dell did not see their computers blow up in 10 minutes else it would have been caught in burn-in.
                    03-31-2024, 02:12 PM
                    07-01-2024, 06:34 AM
                  • tony359
                    by tony359
                    11-28-2023, 05:18 AM
                  • MegaZAC
                    Onkyo TX-SR805 noise in one channel
                    by MegaZAC
                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                    There's some logic behind it. As soon as I select an input I get only left...
                    04-23-2025, 10:09 PM
                  • courtcircuit
                    Philips HTS8000 home cinema noise problem
                    by courtcircuit
                    Hello
                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                    Removed each of tyhe boards
                    02-08-2025, 08:22 AM
