Free non-working Dell 2405FPW for parts
  • ucdzombie
    • Nov 2013
    • 54
    I have a non-working Dell 2405FPW 24 inch monitor with everything. The inverter board, T-con board, and the LCD screen should be in good working condition. The power board may need more work. The logic board is probably fried. My repair isn't going anywhere. So I'm offering my monitor for free. Local pick up or you'll pay the shipping fee. Either way PM me and I'll tell you more.
  • ucdzombie
    • Nov 2013
    • 54
    Re: Free non-working Dell 2405FPW for parts
    Picked up. Not available any more.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • Garret Matt.
      DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
      by Garret Matt.
      I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
      Thank you in advance for any assistance you can render.
      Inductor In question. Buzzes like...
      06-20-2025, 01:21 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
