Windows 10 and issues with the Registry Search function
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Has anyone experienced any problems with RegEdit and Windows 10? Specifically with searching through the registry?
    I got a machine here running Windows 10 and whenever I try using the search function in RegEdit, it seems to go into an infinite loop. Searching the Internet, it seems after some November update to Windows 10, RegEdit seems to have issues with keys longer than 255 characters.
    From what I've read, there should never be keys longer than 255 characters in the registry. With a clean install, fully updated, there's no keys that are over this limit, however, the site said a lot of PCs seem to have this problem. They're not sure where the 255+ keys are coming from. The site I found said RegEdit will search through the registry and work fine until it comes across a key that's greater than 255 characters in length. It'll start eating up CPU resources and go into an infinite loop. When you cancel RegEdit, it's supposed to crash and then restart. When I cancel the search, it doesn't seem to crash.
    Here's an article on the symptom:
    http://www.myce.com/news/windows-10-...ry-keys-78123/
    I believe this is the original article but it's in a different language. I think Deutsch but because I don't speak Deutsch, I do not know for certain:
    http://www.heise.de/newsticker/meldu...02.html?s=ecym
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Windows 10 and issues with the Registry Search function
    Second time searching, RegEdit did in fact crash. It might have crashed the first time but I might not have been paying attention.
    • Spork Schivago
      • Mar 2012
      • 4734
      I think I found the problem keys. They're Microsoft keys I believe and maybe because the hardware could differ on each person's machine, perhaps the error doesn't happen on everyone's machine.
      On the one I'm currently looking at, I can search up to:
      Code:
      {53f5630d-b6bf-11d0-94f2-00a0c91efb8b}\##?#IDE#CdRomTSSTcorp_CDDVDW_SH-S223C________________SB05____#5&7fbcda6&0&1.0.0#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}
      Inside that key is a key called #. Inside the # key is a key called Properties
      The very next key is:
      Code:
      HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\DeviceClasses\{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}\##?#STORAGE#Volume#_??_USBSTOR#Disk&Ven_Generic&Prod_USB_CF_Reader&Rev_1.01#058F63626376&1#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}
      Inside that ke is a key called #. Inside the # key is a key called #, inside the # key is a key called #. It seems to go on forever like that.
      The next key after the CF_Reader one is:
      Code:
      HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\DeviceClasses\{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}\##?#STORAGE#Volume#_??_USBSTOR#Disk&Ven_Generic&Prod_USB_MS_Reader&Rev_1.03#058F63626376&3#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}
      This key has the same issue. Infinite number of # key's.
      With the HKEY_LOCAL_MACHINE key, if you count those characters for the CF_Reader and for the MS_Reader, you'll notice they're 273 characters long.
      The registry, I believe, shouldn't have characters over 255 characters long.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        I've got the same issue on Server 2016 Technical Preview 4
        • Spork Schivago
          • Mar 2012
          • 4734
          So it's just not a problem with 10. Thanks for reporting on the issue Per Hansson. It's been reported to Microsoft, hopefully they release a patch either for regedit or they fix the troublesome keys. I think the troublesome keys would be harder to fix. I'm sure there's some Windows components that probably depend on those keys for something.
            Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
            This is a new item at Electronic GoldMine that has arrived within the last few weeks
            Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
            Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
            https://theelectronicgoldmine.com/products/g28392
            One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
            11-24-2024, 01:25 AM
          • SoulFreeze
            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
            by SoulFreeze
            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
            After repairing the above issue, I realized the following remaining problem,
            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
            The computer recognizes headphones are connected and displays a popup in windows
            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
            06-21-2025, 09:53 AM
          • Salvador Pérez
            Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
            by Salvador Pérez
            Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
            • 0.91V for the GPU
            • 1.7V for VRAM
            • 3.3V and 5V rails 1.8V for the BIOS
            • 0.9V for the CPU and iGPU 1.2V for the RAM
            However, these two coils are not showing any voltage....
            03-10-2025, 11:50 AM
          • Nagyesz
            Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
            by Nagyesz
            I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
            All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
            How can I extend its lifespan? Could reflow help?
            It has ryzen 5 5500h, rtx 2050, no soldered ram.
            Example of the artifacts:
            03-01-2025, 11:11 AM
          • pwnjuice
            Bitlocker issues
            by pwnjuice
            Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
            Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
            Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
            01-06-2025, 05:33 PM
