A failing RTC/CMOS battery can cause certain hardware to not appear
  • japlytic
    • Oct 2005
    • 2086
    On a Dell Studio Slim 540s, I sometimes had the problem of certain hardware sometimes not appearing under certain circumstances , such as the USB 3.0 expansion card in the PCIe slot, and even an onboard device being the 1394 controller, despite the latest known BIOS update being installed - at one stage, the computer could not display video from the video card in its PCIe slot, despite OS loading activity.
    When I lubricated and reseated the devices on the connectors in question, I took the opportunity to check the RTC/CMOS battery - it was at 2.7V and warranted replacement.
    So far, a new battery fixed this problem, and you may be aware that many modern PCs store PNP (Plug & Play) information in battery-backed extended CMOS RAM (2KB to 4KB, possibly more) - apparently, corrupt PNP information was causing the devices in question not to be recognized under certain circumstances.
  • dqtech
    lenovo thinkpad t420 wont turn on when cmos battery attached
    by dqtech
    please help...this lenovo thinkpad t420 early problem is short 19v...after replace short capacitor all working fine...but, when i attach cmos battery on motherboard this laptop wont turn on, power button not respond....it only work without cmos battery....power button and cmos battery is in good condition...i try replace new cmos battery but problem still persist...any idea?...
    06-16-2023, 03:56 AM
  • magistertc
    CMOS battery drains quickly
    by magistertc
    This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
    as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
    Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
    Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
    configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
    07-06-2024, 09:55 AM
  • rumpumpel1
    ThinkPad T470 does not power up with CMOS battery attached
    by rumpumpel1
    I have a ThinkPad T470 that will not boot when the CMOS battery is plugged in.
    With only the fan, a RAM module and a USB-C monitor attached, but no CMOS battery, it starts up normally, i.e. after about 90 seconds and two reboots, it stops with a message to press F1 to enter date & time.
    If the power is switched off and a CMOS battery is inserted, it restarts as described above. However, after switching it off and on again, it does not turn on. It draws almost no current and shows no sign of life.
    I used a different CMOS battery and checked the components around the battery...
    04-27-2023, 10:46 AM
  • valente222
    DELL Inspiron Mb FDI55 LA-J081P REV 1.0 A00 error batery CMOS
    by valente222
    Hello everyone, I have this DELL computer. problem when turning on it does not show an image. Diagnostic LED indicates CMOS battery failure. I measure the battery and 3v is fine. When turned on with battery CMOS consumption of 240mA. By removing the CMOS battery it can consume 800mA and sometimes gives an image when it wants. This happened after a while of installing an SSD. Will ME be corrupted by Windows?...
    03-15-2024, 10:28 AM
  • GIGA10
    Gigabyte G5 KE Clearing CMOS won't reset BIOS Admin password
    by GIGA10
    Hello everyone. I'm not sure if this post belongs in this section? If not, please kindly move it to right section Mod/Admin.
    I have a Gigabyte G5 KE laptop and I have forgotten the BIOS Admin password. I can enter BIOS menu but when trying to enter BIOS settings it ask for my password which I have forgotten. I can boot also in to Windows 11. I have tried to clearing CMOS by removing the CMOS battery for 10h. I have tried also to remove both power battery and CMOS battery and bridge the CMOS 2 pin connector on the motherboard. Then when booting I get a message that NVRAM has been...
    12-23-2022, 03:31 AM
