.wim image recovery
  • japlytic
    • Oct 2005
    • 2086
    .wim image recovery
    On a Dell laptop, I had to replace the hard drive since it was having problems.
    At first, I tried to get a download for a Windows 7 recovery image by entering the Product Key (required) of the Dell laptop, and it did not work; most likely being a key for an OEM copy of Windows.
    When I found the factory.wim image on the recovery partition on the original hard drive (hidden then subsequently unhidden) of the Dell (undamaged), I found the following instructions to reinstall, and I had no problems with Windows activation, since the recovery image used was from the original computer.
    The Microsoft Windows AIK (Windows 7 - free download from Microsoft, which I already have) installed (and all instructions worked) OK under Windows 10, but I had to change at least one command line since I installed the AIK in a location other than its installation default.
    Here are the instructions:
    https://emeneye.wordpress.com/2012/0...-using-imagex/
    https://emeneye.wordpress.com/2012/0...e-with-imagex/
  • Compgeke
    • Feb 2014
    • 524
    Re: .wim image recovery
    For future use, http://mirror.corenoc.de/digitalrivercontent.net/ are proper links for the original MS ISOs. Torrents might seem sketchy but they are the real thing (I've used before).
    Easier than dealing with imagex .
    • japlytic
      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
      by japlytic
      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
      Tried (only with keyboard/mouse connected):
      • BIOS + database update
      • Using latest Windows 11 image built with official image creation tool
      • Previous setup version for Windows 11 installer
      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
      06-19-2025, 04:59 PM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • maviwec184
      Toshiba L50-B-1U8 no image before windows
      by maviwec184
      Hi!
      I have a Toshiba L50-B-1U8 that while booting it show no image. The screen turns on though.
      During this phase if I press F2 it doesn't come out of the booting process and I have to turn it off in the power button. I'm assuming it enter the bios menu, it just doesn't shows it on the screen.
      After the booting phase it starts loading windows and the image shows up normally after that. In windows everything is normal and every hardware component works fine.
      The problem is only during the booting process before loading windows.
      It...
      02-07-2023, 10:12 PM
    • David Gee
      Bios Request HP 17-CN0023DX
      by David Gee
      I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
      I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...
      05-03-2025, 09:58 AM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
