XP SP3 Network Install.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Does anyone have a direct download link for Windows XP SP3, the full network install? I need it but Microsoft has taken it down. When I try downloading from the Internet Archive, it always fails before it reaches 100%. This is probably the 6th time I've tried downloading from them. Sometimes it makes it to 9MB or so, other times to around 200MB - 240MB.
    It's 316MB in size. Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: XP SP3 Network Install.
    I have it. I'll upload it to the server tomorrow and give you the link to it. Yes, it is 316mb.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Spork Schivago
      • Mar 2012
      • 4734
      You are a freaking life saver Top Cat! I'll let you know if I find a copy before then. I swear, I must of downloaded that file at least 300 times over the years! And now, I can't find a single copy anywheres!!!!
      Thank you!!!!!
      • Sparkey55
        • Jan 2010
        • 1523
        Try majorgeeks.com
        • Spork Schivago
          • Mar 2012
          • 4734
          A little update! I found a working SP3 (316MB) from a different Microsoft link. I just need to find a SP1 download now so I can install SP3. Thanks!
          • Spork Schivago
            • Mar 2012
            • 4734
            Originally posted by Sparkey55
            Try majorgeeks.com
            I just tried Majorgeeks.com and didn't find anything.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              I have that too. its 133mb. I delete NOTHING!!
              Team : 49813
              Join in!!
              Team Stats
              • Spork Schivago
                • Mar 2012
                • 4734
                Do you think you could do me a favour and maybe check the SHA1 checksum for me? Or any SHA checksum? For the SP1 I mean? I think I found a copy, but when I go to install it, it errors out, saying some crap about the key is invalid and it thinks it's a pirated copy of XP. It has a COA sticker on the back and came from a hospital so I highly doubt it's illegal.
                I'm thinking of just trying a fresh install of XP SP3 tomorrow. Just not too certain I'll be able to activate. Do you know if the activation servers are still up?
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  I got 133.93MB, SHA-1 ab432b250669927ede664738a5e9799161003c23.
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    It is there, you get it by using the left pane to navigate, Microsoft> windows updates> service packs, etc. Use the Majorgeeks source for downloads not Microsofts who are the authors.
                      • 31015
                      this is a handy site
                      http://www.oldapps.com/
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        Yes it is but they have been getting some take-down notices for some of it.
                        • Sparkey55
                          • Jan 2010
                          • 1523
                          If Spork would learn how to use a web search engine or ftp search he would not need to ask for these common files.
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            https://www.badcaps.net/forum/showpo...7&postcount=54
                            better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              I don't have a Microsoft category in the Left Pane. I even tried using the Search function below the left pane, looking for the service packs...
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                I do know how to use a web search engine and ftp search. I had tried searching for the XP SP3 KB number, the actual filename, in double quotes of the service pack, etc. Every return just seemed to point to the old Microsoft servers. All I could think of was maybe people got in trouble for sharing the download and Microsoft might of just wanted them to link to it.
                                The two copies of SP3 that I did find, both only downloaded 200MB of the file and then stopped. It didn't error out or anything. It's almost as if the two sites who had copies just had truncated versions or something. Every time I tried running the 200MB version, it just refused to run.
                                I even tried downloading it on a different machine with a different OS. Same 200MB. I finally found a site that had the 200MB version but also said Microsoft put the service pack back up on their servers. I tried that link, and sure enough, I got the 316MB file. Thanks for the help.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Thank you!
                                  • Sparkey55
                                    • Jan 2010
                                    • 1523
                                    Just to show you that it is on majorgeeks. http://www.majorgeeks.com/files/deta...ce_pack_3.html
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      Thank you Sparkey55. I just couldn't find it on there. I even showed a picture showing that I didn't have the Microsoft category on the left that you had and the search function didn't return any files. I no longer need it though, but thanks for sharing.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        After you posted the link, I noticed it was under System Tools -> Windows Update ->Microsoft Windows XP Service Pack 3 Final
                                        • piernov
                                          NVidia bumpgate
                                          by piernov
                                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                          May complete this post at a later date with more details.
                                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                          03-27-2021, 10:34 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • davg
                                          Home network connection problem
                                          by davg
                                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                          03-06-2021, 07:13 AM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
