My Little Project: Build and/or Rebuild
  • LoTechJoe
    • Apr 2008
    • 8
    ORIGINAL PROJECT: I have two computers. One for every day use, the other is (was) used for audio production. I'm an old radio geek and for a few extra dollars I voice produce ads for radio and TV. See My Profile.
    My first computer (the every day machine) is really starting to show it's age (just like me.) The main board is a Biostar M7VKB with an AMD Duron 750MHz processor and 512 of RAM. I figure it's time to upgrade and build from scratch. Plans are to lose the beige case, go for better graphics, faster RAM and processor, add a DVD, etc. I should have the funds for a project like this in about two or three weeks.
    My original plan was to purchase something like this…
    • Antec Sonata III 500 Case with EA500 Power Supply
      Gigabyte GA-MA770-DS3 motherboard
      (2) Western Digital 160GB SATA Hard Drives
      LiteOn DVD writer
      AMD ADA5600CZBOX Dual-Core 2.8GHz Processor
      Thermaltake CL-P0200 CPU Heatsink & Fan
      Asus Geforce 8600GT PCIe Graphics Card
      Kingston 4GB PC2-6400 DC Memory
      Viewsonic-Optiquest Q91b 19 inch LCD Monitor
      Windows XP Professional x64
    My thought here was to stripe the two hard drives for access speed. I'm not a gamer, so the graphics card should be fine.
    THROW A WRENCH IN THE WORKS: Friday night I notice my second computer had reset the BIOS and was waiting for me to do the setup. I'm thinking WTF! I discover the BIOS is not recognizing my hard drive. Okay, it happens … this machine is over 5-years old and hard drives die. I pop in a fresh new drive, and since the case is open, grab my portable vacuum and clean the dust from the case. That's when I noticed the damaged capacitors on my Asus A7N8X.
    THE PREDICAMENT: Hmm. This is going to change my plans. Money is tight, so I know rebuilding two machines is out of the question.
    Now I am thinking of moving from two separate computers to one. Two computers are nice when both me and my wife want to use the computer at the same time. And … that happens a lot. But, money talks and B.S. walks!
    The revised plans include using my current case (a full size Antec beast,) upgrade the PSU and motherboard, and maybe use that new hard drive as an internal backup to my planed RAID zero array.
    For now, it's back to the drawing board for my wish list. Once I get a better idea of what components I plan to use, I'll post back here for your opinions.
    Joe
    "I'm gonna need a hacksaw" - Jack Bauer
  • stevo1210
    • Oct 2006
    • 4156
    Re: My Little Project: Build and/or Rebuild
    I see that your motherboard has Nichicon HM(M) capacitors. Though they are of a good brand, the HM and HN series of capacitors are prone to go bad. You should replace them and then you'll get a nice working motherboard again.
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • shadow
      • Feb 2007
      • 732
      That is right Stevo, and replacement of the capacitors is actually not very expensive. However you will need to source and buy the capacitors. I would think that would be quite easy given that Topcat (the owner of this website) sells capacitors to those that live in the US. On top of that you need a soldering iron and solder. Lastly you would need some spare time to actually do it.
      Another alternative is to send the board to Topcat and he will recap it and test it for a fee.
      • bgavin
        • Jan 2007
        • 1355
        As a computer servicer, I was an AMD guy for decades. Was. The AMD processors no longer compete with Intel for heat, performance, or price. I've had more than enough grief with asian chipsets and their never-ending stream of compatibility problems. VIA was the absolute worst, but the nForce give me enough problems to make the Intel chipsets look like safe haven.
        The Gigabyte P35 based boards are excellent choices. Many come with all polymer caps; i.e. those with "Durable 2" in the text, or "D" in the model number. GA-P35-DS3 is the one I settled on for my client machines. The forums mention an audio latency problem with late BIOS for the Gigabyte machines, so check that out. An alternative is the MSI P35 Platinum board, which is reputed to not have a latency issue.
        Recapping requires a solder station, not a soldering iron. You have to get the tip to 450 degrees C, or you will have poor results. I use the Hakko 936 for $75 USD, and it works a treat. Obtaining caps is pricey, and aggravating to purchase. If you are only doing 1 board, I urge you to send it to Topcat for top quality work. You will be money ahead sending it to him.
        I've never bought Kingston memory intentionally, when I can get Corsair XMS. You can get quality XMS for DDR2-800 with CAS=4 for a reasonable price. Newegg is offering huge rebates on this memory, making the effective price some $29 USD for a 2x1gb pair. $15 per gig is cheap.
        The stock Intel cooler is sufficient for non-overclocked use. Buy the processor retail package, and the cooler comes is included. You can spend a lot of money on after market coolers. I use the Scythe Zipang on a Core2 Duo E8400. It is overkill but it is indeed quiet. It uses a backing plate to distribute the significant weight of the cooler, so board removal is mandatory. The Intel cooler is stand push-pin and mounted without removing the board.
        • i4004
          • Oct 2006
          • 2029
          no it doesn't. station is surely better(and mostly because you can turn the temp DOWN, not because it has higher peak temp than higher wattage iron, as it doesn't), but 40 or 60w iron will do.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            recapping requires a good iron with good thermal mass.
            it need not be expensive but a $5 harbor freight cheapie wont cut it.
            i have a 60w weller in my toolbox that is used for emergency onsite recaps.
            it costs about $20
            • Newbie2
              • Sep 2005
              • 885
              Don't bug him on the HM-HN caps, their issues were a few years ago and probably Nichicon has improved them now.
              Nichicon did make a little boo-boo on the older 2003-2004 HM-HN caps, and along with the manufacturing boo-boo the Apple iMac and Dell systems they usually came in were in cramped cases with little ventilation, aggravating the original problem and making them fail across the world.
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
              • bgavin
                • Jan 2007
                • 1355
                Of course. Any tool in the hands of a pro always performs better, even crappy tools. My point for the newbie was use a decent soldering device that generates 450C for proper de-soldering. A fine chisel point is a big plus.
                I think of soldering irons as cheap junkers from Radio Shack or Harbor Freight. There are photos in another thread of a newbie blobbing solder on the board due to insufficient heat from using a soldering iron.
                • LoTechJoe
                  • Apr 2008
                  • 8
                  bgavin,
                  Thanks for the input. You have given me a lot to think about. You'll notice the 'D' in the Gigabyte board model I listed. Oddly enough, that was the reason for choosing that model. That's BEFORE I had the problem with the bad caps on my Asus.
                  I have sent the re-build request in to TopCat. I'm sure he'll get back with me as soon as possible. I'm certainly in no rush. I may build from new this time and have T.C. repair the caps on the bad board for a future project. Somewhere down the road, I would love to build a home HD-DVR.
                  Joe
                  • LoTechJoe
                    • Apr 2008
                    • 8
                    It has been a while, but I have used a soldering iron before and yes I will need to get a new one. I know better than to use the old Radio-Shack version that's in my tool box.
                    You guys mentioned the places NOT to get an iron ... what are some of the places to purchase a good one for I.C. use?
                    Joe
                    • i4004
                      • Oct 2006
                      • 2029
                      joe, i wouldn't invest too much in iron if i wouldn't use it too often.
                      the only difference between weller and cheap crap will ultimately be durability, of which you won't care because you won't be repairing mobos all the time.
                      (heck, even if you would, you could buy few cheapos to last you years...).
                      practicing on broken mobos will give you experience and self-confidence.
                      i have weller that i payed about 55$ and i have cheapo that was 10$, and only thing i feel is that weller is overpriced to the max.
                      and that cheapo actually has better stand than cumbersome and weird weller thingie...
                      bgavin:
                      i think it's more about newbiness than about iron, as he has 60W iron.
                      (also, i would give him some credit: if he's a beginner, some of those joints are looking pretty good...for a beginner. with tip cleaning i think he would do just fine)
                      to that extent, here's a video-clip that demonstrates few things i already mentioned.
                      1-clean tip is more important than it's shape. chisel is not a must.
                      (https://www.badcaps.net/forum/showth...9252#post49252)
                      2-wooden toothpick used to clean holes
                      (https://www.badcaps.net/forum/showth...pick#post46122)
                      http://bbsrv.wks.gorlaeus.net/~i4004...oothpick_a.avi
                      (7.11mb)
                      cheap 60w iron used (https://www.badcaps.net/forum/showpo...4&postcount=4), and as soon as i cleaned tip it's working well enough.
                      (you'll notice 1st attempt of getting it out was unsuccessfull....like i said rather high temp. of these higher wattage irons poisons the tip rather fast...that goes for wellers as much as cheapos..only way around it is to decrease the temp, or clean it frequently...)
                      and the end result is not too bad, for a quick demonstration
                      there is one important thing to mention about cheapos.
                      they're really only copper and thin layer of nickel(there really is no iron layer like on more expensive ones), and they probably won't come tinned(more expensive ones probably will).
                      so you'll need to tin it as soon as it can melt the tinol. if you don't, you'll have to use the rasp or alike to clean it (to reach copper).
                      this clips shows how unwettable portions that are left to overheat become
                      http://bbsrv.wks.gorlaeus.net/~i4004...698_lemilo.avi
                      (19.26mb)
                      [to watch these avi clips you need ffdshow with h.264 support enabled...
                      video decoder configuration->codecs->'decoder' for h264 should be libavcodec...if it's not, click on "disabled" and select "libavcodec"->apply->ok...]
                      to end my multimedial presentations, here's difference between new and used iron(same model, same vintage).
                      http://img111.*************/slideshow/player.php?id=img111/3305/1200550191jpw.smil
                      used one was heavilly beaten by rasp, but hey, that's my first iron, produced some time in the beginning of the 80s, and it's still working, and i'm still using it.
                      for a copper without any protection(i removed any traces of iron and chrome early on..hehe...no internet in those days to quickly learn about soldering tip anatomy
                      http://weller.blog.com/1840284/
                      and what not to do) it did pretty well.
                      • LoTechJoe
                        • Apr 2008
                        • 8
                        i4004, very informative post. Thank you for the links.
                        I heard back from TopCat today. The cost of the re-cap of my old board is VERY reasonable. That really sounds like the way to go. I will probably get my new build out of the way first, them send him the board.
                        Joe
                        Joe
                        • ash91
                          Hp pavilion 15 not detect hard drive
                          by ash91
                          Hello gentelmen .... this is my first post and sorry for my bad english,
                          so my proplem is my laptop keep losing hard drive even if i but the
                          hard disk in the cady (the box that can replace the dvd rom with hard disk)
                          when i turn the laptop on the massage that said no boot media found pop on
                          the hard disk is fine and to be sure i try another hard
                          i also update my bios to the last update
                          the 5 volt is present on the hard connector on the motherboard
                          the dvd rom work fine when i but a windows dvd in it
                          also when i boot from flash...
                          06-07-2023, 01:45 PM
                        • madura2010
                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                          by madura2010
                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                          i checked the connectivity of ribbon=good communication with hard and motherboard
                          changed hard disk and checked=3f0 error persist
                          sata power=+5v available
                          Then checked data capacitors=all good
                          Then checked data lines path connectivity to pch=all good
                          reflashed...
                          03-12-2023, 09:09 AM
                        • tmcw
                          PC case - Hard drive rails
                          by tmcw
                          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                          Now, the case is a CiT Gaming Case, and...
                          05-22-2022, 12:04 PM
                        • Dobrowol
                          Dell Latitude 3520 help with bios build/repair
                          by Dobrowol
                          Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                          Steps i done and results:
                          I exported a clean bios from update file via pfs extract.
                          1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                          Result: Dead
                          2. Build clean bios with no changes in ME, new PMC, PCH
                          Result: Dead
                          3. Build old bios with clean ME, new PMC, PCH
                          Result: The same
                          09-22-2023, 02:43 AM
                        • karto95
                          Repairing a Seagate hard drive with damaged logic board
                          by karto95
                          I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                          I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                          If anyone has any suggestions or experience with this...
                          03-21-2023, 04:05 AM
