OneNote 2007
  • vancelarson
    • Dec 2015
    OneNote 2007
    Every day even after i have repaired the folder by deleting the old cache and letting it rebuild by reopening the folders subsequently. It happens even when the system is not in use but the program is open. i am using .net framework 4.0. After I repair it works until the next morning and then the error message greets me when I turn on the screen. By the way we are sharing our one note files and all parties were getting the error at first. After the fix you suggested, that we all knew about and that we all tried 2 of the 5 five people using one note stopped getting the error, and 2 only get it every other day while I get it every day.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: OneNote 2007
    There was text in this post? I stopped at the avatar.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      Re: OneNote 2007
      Lol
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Re: OneNote 2007
        I'm currently sitting in Starbucks and I could not read your post because the person sitting next to me keeps looking over at my laptop and when they saw your avatar they looked away quickly. They think I don't notice but I do...
        • ulisesbaxter
          • Dec 2015
          Re: OneNote 2007
          -Exit OneNote.
          -Find the corrupt section file via Windows Explorer (probably in Documents-->OneNote Notebooks).
          -Make a backup copy of this file just to be safe.
          -Shift+right-click the original file and select "Copy as path".
          -Click Start and select Run.
          -Type onenote.exe /forcerepair, then a space, then Paste the path to the corrupt file.
          Alternative variants are:
          ****SPAMWICH LINKS REMOVED****
          • tony359
            2007 Macbook logic board fault
            by tony359
            Good day all,
            I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
            Once the fan was swapped, I installed an OS and it worked fine.
            The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
            Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
            If I see that right, I have missed VCORE on L7100 (page 59)....
            01-23-2025, 06:59 AM
          • camelion
            All password for asus series 2007
            by camelion
            All password asus 2007
            2007-01-01 abldabla
            2007-01-02 aaaa4aba
            2007-01-03 aa219daa
            2007-01-04 ab4hbbla
            2007-01-05 ahaalo0b
            2007-01-06 aabbaaal
            2007-01-07 aabb00ld
            2007-01-08 a1ddo10d
            2007-01-09 aoaadaab
            2007-01-10 aoaabadb
            2007-01-11 bb12lhl0
            2007-01-12 b4h4a1al
            2007-01-13 laaa0adb
            2007-01-14 daobobl2
            2007-01-15 d10bdba1
            2007-01-16 dodl1ad1
            2007-01-17 dlaaallc
            2007-01-18 ba12lla9
            2007-01-19 bch4abdb
            2007-01-20 0a04oaba
            2007-01-21 0aaadbaa
            2007-01-22...
            06-06-2013, 01:59 PM
          • MicroSMD Lab
            MacBook Air A1932 2019 display remains black after reopening the lid
            by MicroSMD Lab
            Hi, I'm bumping this topic because I have a similar situation but the one I'm working on, the display remains black after reopening the lid. If I disconnect the battery and boot with the charger everything works until I close the lid. If I shut down with the lid open and press the power button everything works. It came in for liquid damage with a burnt audio board. I think the hall sensor in the right speaker is faulty, but I didn't do any tests yet. I'm interested in having the sleep function work with one sensor until I get the replacement speaker (assuming the speaker hall sensor is defective....
            05-21-2023, 04:38 PM
          • dkneyle
            Weltron 2007 UFO (vintage) - setting bias and crossover
            by dkneyle
            Currently restoring a Weltron 2007. Have replaced all the small signal and driver transistors in the the power amp stage. In theory I need to reset the bias and crossover. The service manual provides no guidance. Anyone got any thoughts about how to do this?
            [These were amazing looking all-in-one systems from the 70s.]...
            02-26-2022, 06:16 AM
          • Retro140
            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
            by Retro140
            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
            06-18-2023, 06:13 PM
