ATi Radeon 9600 AGP missing capacitor
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Hello, I am in need of the value of a "missing" SMD capacitor on an ati radeon 9600 AGP 128MB made by club3D.
    The capacitor is labeled C595.
    You'll find pictures in the attachments.
    Thanks, for any info and advice... and yes, I fucked up while taking the heatsink off
    Keyboard not detected, press F1 to continue...
    • 30930
    Re: ATi Radeon 9600 AGP missing capacitor
    most likely .1uf
    it looks like it's across the power.
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Originally posted by stj
      most likely .1uf
      Could be, the two on it's left are 165nF.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3261
        • Singapore
        it looks like its just an smd mlcc used for emi/noise supression. these caps are usually non-critical to the running of the video card. it just makes the video card cause less interference to tv/radio signals. they usually have an overkill of these emi/noise supression smd caps on pc boards so one less is not going to make the video card, computer or any other nearby appliance blow up or anything.
        i had a second hand 9800 pro video card that had a cracked smd mlcc behind the molex connector that was causing a short. (read on wikipedia that when mlccs go bad, they typically go short) it tripped the short circuit protection of the psu on a power on. busted out my soldering iron and pulled the cracked smd mlcc off, put it back in and it powers on and works flawlessly again. i am typing this on the 9800 pro machine. been running it for several months without the smd mlcc and never experienced any problems.
        u can still replace it tho, if u are anal about having a pristine video card. also, try to get those plastic or rubber tip covers or cushions for your needle nose pliers. those are useful to prevent "accidents" from screwing up components on your pc boards.
        • reaper57
          • Sep 2014
          • 216
          • Norway
          Thanks, for the information and advice!
          About how I broke it off. I usually use tweezers, but the one on my desk were too big and the smaller ones weer like 1-2 meters away, but I was being lazy and got this pry tool, that's normally used for opening phones and tablets. And probably the most shitty part was that I had already replaced the thermal paste... but had forgotten about it
          • reaper57
            • Sep 2014
            • 216
            • Norway
            Btw, I just realized that every other ram chip on the card has that capacitor. What I'll do is desolder one of them tomorrow and check it's value!
              master hoarder
              • May 2008
              • 12164
              • Bulgaria
              +1
              Especially if those caps are near a RAM chip or on the reverse side of the GPU.
              Of course, not all MLCCs are non-critical, though. Some are used in the charge-pumps of the VRM controller for the RAM and/or GPU. Get that one knocked off, and the card won't run for sure.
              But in the O/P's particular case, that ceramic cap looks like it's just extra filtering for the RAM chip next to it. So it should work without it no problem.
                AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                10-01-2024, 12:46 PM
                AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                10-01-2024, 01:07 PM
                AMD Radeon RX 470 / RX 580 Schematic & Board View
                The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                10-01-2024, 12:52 PM
              • MeetingIncapable
                Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                by MeetingIncapable
                I am new to repairing computer electronics, so excuse any mistakes I make.
                A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                I wanted to replace the capacitor, but I have two questions:
                • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                • How do I determine the rating/value of this capacitor? or something
                05-04-2024, 09:56 AM
              • fab13
                Missing capacitor - Radeon HD 7850 2Go- Which values to choose?
                by fab13
                Hello to all
                I have a Sapphire HD 7850 2 go
                I would like to have a little information about a capacitor to add and its value.
                This graphics card turns on with fan running but no display in HMDI ouch.
                After checking on the boardwiew exact and precise and I have only the boardview.
                Indeed, it misses 3 capacitors of size 0402 of which 2 on the line +1.8 Volts is C1700 in 1 uF and 1 in C1704 on the line +1.8 V in 0.1uF
                Finally, the C2208 at 0.1uF on the +MVDD line
                My question is : However I do not have a 0.1uF capacitor...
                01-03-2022, 01:41 PM
