PWM splitter
  • csh
    • Mar 2015
    • 38
    • Croatia
    PWM splitter
    MBO in my main rig at home has only 4-pin fan connector, for the CPU fan. The rest are standard 3-pin.
    Recently i got this PWM adapter and two of these fans.
    In theory it should work fine: fans are drawing power from molex and are controled via PWM signal from the MBO that reads rpm from the CPU fan (old Freezer 64 pro).
    But, after powering up, BIOS reads 1800 rpm on the fan and it really spins faster. After stressing the CPU some time it spins gradually up to 2400 rpm which is close to the specified max: freezer has a fan rated for 900-2200 rpm.
    Swapping the places of new fans didn't help. If i leave only one fan connected (any position, tried with both fans), BIOS reads around 1000rpm at cold start and CPU fan slowly spins up to 2400 rpm.
    With only the CPU fan connected it spins from 950-2300 rpm.
    It seems that winth only one additional fan on the splitter the reading is a bit off by 100-200 rpm, but with all 3 fans it works 1800-2400.
    Any ideas why this setup isn't working?
    • 31286
    Re: PWM splitter
    disconnect the tacho pin from one of the fans - they are canceling each other out.
    • csh
      • Mar 2015
      • 38
      • Croatia
      Re: PWM splitter
      There is not tacho (pin 3) on the connectors to the two case fans. they have only pwr,gnd and pwm (pin 4).
      If i disconnect pin4 that fan would spin at full speed and that is what I'm trying to avoid.
      • emil_t
        RTX3090 working fine but fans not spinning
        by emil_t
        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
        04-12-2024, 06:54 AM
      • b-slayer
        Asus Strix-G15-G513RM fans don't work
        by b-slayer
        I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
        The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
        (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
        (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
        ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
        09-04-2025, 04:58 AM
      • JayPoorJay
        Hot Water Rad - A Few ECU Fans and a Timer Switch
        by JayPoorJay
        Good Afternoon, Good People.
        I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
        I REALLY would appreciate y'alls help.
        This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
        10-29-2024, 12:54 PM
      • spleenharvester
        Ugreen HDMI splitter missing a pulldown resistor
        by spleenharvester
        Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
        I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
        (Not that this is worth the hassle for an...
        09-15-2025, 11:23 AM
      • HammyCheesy
        Lenovo ThinkStation P720 BIOS Request
        by HammyCheesy
        Hello all,
        I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
        When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
        Type: 30BB
        Model Number: S03600
        S/N: MJ07N68C
        Things I have tried:
        1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
        2. Attempted to boot with just a single CPU...
        04-11-2025, 01:02 AM
