Mac Pro 1,1 new PSU no chime or post
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    Tower died right after purchasing new CPUs and RAM (before I could even install). It's been 64bit enabled with SFOTT/Tiamo, and had teh firmware flashed to 2,1, but no new hardware installed yet. I could hear something powering on in the PSU but then it would quickly power back off, with no life shown anywhere else. So I got a 1,1 PSU off eBay and installed it. The thing now powers on, but never chimes or boots or sends any signal to the monitor.
    Here's what I can confirm it does:
    The fans spin at a low, normal, rate (unlike some that are experiencing problems and the fans are running maxed). The red lights on the RAM boards light up as they used to. I can hear the HDD engage and spool up. The white LED indicator light on the power button comes on as normal.
    What I've tried:
    Reseating RAM (the original 4GB, but maybe not in the original order?), reseating the RAM boards, reseating each of the 3 7300 GTs in the PCIe slots. I've also tried unplugging and pressing the SMC button by the top PCIe slot. Should I be doing this while it is on, or off, and for how long do I press it, etc.
    Any advice here would be great. I'd love to get this thing running again or return the hardware I've bought. before the return period is up.
    Cheers
  • DynaxSC
    Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
    by DynaxSC
    I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
    I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
    Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
    Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
    05-04-2025, 12:08 PM
  • survivalbloke
    Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
    by survivalbloke
    Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
    06-14-2023, 11:45 AM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • apos
    a 1707 820-00928 20v 1.8A charging battery boot no screen no chime no fans spin
    by apos
    Hello , i have an a 1707 that is about to blow my mind.I was about to change battery and when i did it suddenly had chime but no screen .I removed keyboards cable from logic board then i had screen .I plugged it again the cable while MacBook pro was on and since then ,no chime no boot, voltages looks ok 20v 1.8A .EDP meter shows no problem ,Thermal camera shows heat on U7210 and U1100.
    Any ideas will be helpful
    Thxxx
    07-13-2023, 07:46 AM
