HDD issues.
Re: HDD issues.
The firmware doesn't "scatter" any data. The OS determines where the data are written. AV drives incorporate the ATA Streaming feature set which allows the drive to skip difficult sectors whereas a typical desktop drive will become bogged down with error recovery. The philosophy is that AV applications can tolerate missed video frames or audio dropouts.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
The ROM does not decide where the data goes. No drive "scatters" data. The OS tells the drive to write to LBA n, and the drive then writes to LBA n. However, the drive has a "translator" which determines how the logical blocks are mapped to the drive's physical CHS addresses. Even so, the data are still laid down in serpentine fashion, in LBA order, except for the grown defects. Please read the Tracks and Zones article. It was written by a Seagate employee who is a highly regarded member of the data recovery community.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
I'm not aware of any modern file system that doesn't allow for fragmentation, but then I haven't looked much beyond Microsoft. In fact that last time I saw a file system that would only write files in contiguous space was in the 1980s.
PATA has a speed limit related to the selected UDMA mode whereas SATA can transfer data at a much faster rate, especially for SSDs. You would only use IDE compatibility mode for legacy OS-es or in the absence of a suitable SATA driver. For example, some HDD manufacturers' firmware updates are delivered via DOS based utilities which sometimes have trouble communicating in SATA mode.
As for glass platters, the data recovery guys often relate horror stories about shattered platters, or platters that have suffered a prolonged head crash, to the point that all the oxide has been scraped off and the platters have become transparent.
https://upload.wikimedia.org/wikiped...iled_Disks.png
http://www.nitroware.net/images/stor.../deskstar2.jpgComment
Re: HDD issues.
http://www.howtogeek.com/115229/htg-...defragmenting/
It's a little old, 2012 I think, but it's still valid. I'm not sure how the newer file systems in Linux deal with fragmentation, like Btrfs (B-Tree File System or Binary Tree File System).-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
I split off the SSD discussion into this new thread:
https://www.badcaps.net/forum/showthread.php?t=49114"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Re: HDD issues.
Thank you.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
by SoulFreezeHi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
After repairing the above issue, I realized the following remaining problem,
Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
The computer recognizes headphones are connected and displays a popup in windows
Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer... -
by NagyeszI have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
How can I extend its lifespan? Could reflow help?
It has ryzen 5 5500h, rtx 2050, no soldered ram.
Example of the artifacts:
...03-01-2025, 11:11 AM -
by pwnjuiceCustomers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with...-
by SkgodHey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
Black screen, freeze
The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
So can anyone tell me what would be the possible cause?... -
by RudolflHi all
I have one of those machines. Clevo PC70DP.
Machine starts, but turns off quite quick. Just before turning off one can hear fans are spinning at high speed. Can be turned back on again right away.
So, feels like overheat problem.
I cleaned up fans and heatsinks and replaced thermal paste. I can now see CPU runs cooler and machine stays on for longer, but still same.
Few more findings:
1. on-board NVIDIA card is not found. Not showing up in Windows or in BIOS.
2. I tried to run CPU stress test. CPU stays at about 65 degrees. Works...Today, 01:43 AM - Loading...
