Out of space. Upgrade tips needed.
  • pentium
    • Mar 2006
    • 2778
    Re: Out of space. Upgrade tips needed.
    Well I meant for the connection to the hard drive but by the looks of it, I could only use 50 pin drives. No thanks. Too slow for me.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      Originally posted by pentium
      I know I am waking the dead here but how would this do?
      I keep on forgetting if SCSI 2 was 50 or 68 pin though.
      It was 50 pin: you'd have to buy some 68 -> 50 pin adapters and I don't think there is enough space inside this enclosure. If you plan using 50 pin drives then you can use up to 9 GB drives, so this option isn't much useful too.
      In short: don't buy it unless you've an old 486 hanging around.
      Zandrax
      ------- Update:
      Damn: I didn't noticed page 2!
      So discard this message.
      Have an happy life.
      • Shredder11
        BoardViewer Files Needed For M-Audio Ozonic Firewire Keyboard Audio Interface + Any Repair Tips
        by Shredder11
        As per title and also any tips on what to test first would be welcome on fixing this keyboard, which worked 100% and then upon the next power on, no display or response from keys, buttons, sliders, dials etc. However the Firewire audio interface section still works.
        Thanks.
        10-14-2025, 01:42 PM
        Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook 16 Specification for Upgrade or Repair
        This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-07-2024, 05:20 AM
      • eccerr0r
        It's 2025: do you know where your 5¼" floppy drives are?
        by eccerr0r
        Oh wow.
        As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
        Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
        Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
        Weird. Seems the PC drive is having trouble clamping...
        07-07-2025, 12:49 AM
      • estabilito
        Tips geting oxidized when using wick
        by estabilito
        Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
        i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
        Temperature: 350-365celsius
        station: jbc cd-2bqe
        Wick: edsyn
        flux: warton hf rework jelly
        Do you have any tips?...
        04-12-2025, 11:55 AM
        Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
        by sam_sam_sam
        I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
        I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
        12-31-2023, 06:04 AM
