Out of space. Upgrade tips needed.
  • pentium
    • Mar 2006
    • 2778
    Re: Out of space. Upgrade tips needed.
    Well I meant for the connection to the hard drive but by the looks of it, I could only use 50 pin drives. No thanks. Too slow for me.
    Find Nedry!
    Check the Vending machines!!
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      Originally posted by pentium
      I know I am waking the dead here but how would this do?
      I keep on forgetting if SCSI 2 was 50 or 68 pin though.
      It was 50 pin: you'd have to buy some 68 -> 50 pin adapters and I don't think there is enough space inside this enclosure. If you plan using 50 pin drives then you can use up to 9 GB drives, so this option isn't much useful too.
      In short: don't buy it unless you've an old 486 hanging around.
      Zandrax
      ------- Update:
      Damn: I didn't noticed page 2!
      So discard this message.
      Have an happy life.
        Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook 16 Specification for Upgrade or Repair
        This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-07-2024, 05:20 AM
      • estabilito
        Tips geting oxidized when using wick
        by estabilito
        Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
        i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
        Temperature: 350-365celsius
        station: jbc cd-2bqe
        Wick: edsyn
        flux: warton hf rework jelly
        Do you have any tips?...
        04-12-2025, 11:55 AM
        12-31-2023, 06:04 AM
      • eccerr0r
        failing hard drives after sitting for years...
        by eccerr0r
        With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
        Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
        Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
        03-02-2023, 10:33 AM
      • abajor
        Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
        by abajor
        I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
        I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
        The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
        Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
        04-23-2024, 11:43 PM
