CPU running overly hot.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: CPU running overly hot.
    Originally posted by Mikeyboy2007
    updated, still pretty high.
    Speedfan still could be a problem according to this post.
    http://www.tomshardware.com/forum/31...00-temperature
    PS. Speedfan reporting 6V on the 12V rail seems to indicate speedfan is still buggy either for your chipset, bios, bios settings, motherboard and/or OS.
    Try another program as suggested in the link above.
    PS. Your BIOS readings are likely correct.
    --- begin sig file ---
    --- end sig file ---
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      ok thanks. ive just realised too that my bios needs updated and also been advised elsewhere to download Asus AI Suite 2 so gonna do that also, will update my findings.
      • dj_ricoh
        • 2073
        or you have to take the plate off !
        then clean it and use thermal paste
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          this is the info i got from CPU-Z
          Processors Information
          Processor 1 ID = 0
          Number of cores 4 (max 8)
          Number of threads 4 (max 16)
          Name Intel Core i5 2400
          Codename Sandy Bridge
          Specification Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
          Package (platform ID) Socket 1155 LGA (0x1)
          CPUID 6.A.7
          Extended CPUID 6.2A
          Core Stepping D2
          Technology 32 nm
          TDP Limit 95.0 Watts
          Tjmax 99.0 °C
          Core Speed 3209.6 MHz
          Multiplier x Bus Speed 32.0 x 100.3 MHz
          Stock frequency 3100 MHz
          Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
          L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
          L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
          L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
          L3 cache 6 MBytes, 12-way set associative, 64-byte line size
          FID/VID Control yes
          Turbo Mode supported, enabled
          Max non-turbo ratio 31x
          Max turbo ratio 34x
          Max efficiency ratio 16x
          Min Power 60 Watts
          O/C bins +4
          Ratio 1 core 34x
          Ratio 2 cores 33x
          Ratio 3 cores 33x
          Ratio 4 cores 32x
          TSC 3110.1 MHz
          APERF 3292.5 MHz
          MPERF 3110.0 MHz
          Temperature 0 35°C (95°F) [0x40] (Core #0)
          Temperature 1 42°C (107°F) [0x39] (Package)
          Power 0 32.42 W (Package)
          Power 1 28.55 W (IA Cores)
          Power 2 n.a. (GT)
          Power 3 3.87 W (Uncore)
          Voltage 0 1.27 Volts (VID)
          so if im correct the package says it should be running at 42oC but its only running 35oC so its actually running cooler ? am i correct ?
            • 31094
            did you correct the bios settings for 100% fanspeed?
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              #26
              not sure how to do that cant find the setting, having a read through some forums just now, seem to be running alot cooler though. using freeware called Speccy it says my CPU is running between 32-35oC which is alot better than 92oC
                • 31094
                reboot the computer and hold down the "DEL" key usually.
                that or "F2"
                  MSI Trident 3 Arctic 9SI-618EU Trident 3 Arctic i7-9700F Specification for Upgrade or Repair
                  This specification for the MSI Trident 3 Arctic 9SI-618EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 9SI-618EU boardview and Trident 3 Arctic 9SI-618EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-12-2024, 03:28 PM
                  20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                  by sam_sam_sam
                  I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                  At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                  Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                  04-09-2023, 08:04 PM
                  MSI Trident 3 Arctic VR7RC-281 Trident i5-7400 Specification for Upgrade or Repair
                  This specification for the MSI Trident 3 Arctic VR7RC-281 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic VR7RC-281 boardview and Trident 3 Arctic VR7RC-281 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  MSI Trident 3 Arctic 8RB-092UK Trident i5-8400 Specification for Upgrade or Repair
                  This specification for the MSI Trident 3 Arctic 8RB-092UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 8RB-092UK boardview and Trident 3 Arctic 8RB-092UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                • Ugur87
                  MacBook Air M4 A3240 Brand New Water Damage no Image
                  by Ugur87
                  I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                  Yesterday, 01:09 PM
